YBR 125 exhaust split... options?
zark
PostPosted: 19:46 - 10 Jun 2014    Post subject: YBR 125 exhaust split... options? Reply with quote
So the exhaust on my YBR sounds dreadful... and I've possibly found out why!
What are my options? Is gun-gum putty or the repair bandage any good as a stop-gap?
Should I bung some cash at a garage to get it welded up?
Where's good for a replacement? (2007 year)
Its due its mot in a couple of weeks (typical) so I guess I'll need a new one sooner rather than later...? Just thinking about a temporary repair as its still in daily use.
https://i972.photobucket.com/albums/ae205/zark_photos/Mobile%20Uploads/IMG_20140610_180451.jpg
gavcarter
PostPosted: 20:26 - 10 Jun 2014    Post subject: Reply with quote
Looks like its pretty much about to snap in half. You can TRY to gun-gum + bandage but - it will look shite and wont last all that long looking at that hole!
Welding there is little point as it rotted to hell and the metal near the weld will likely go shortly after.
Pattern part, or half decent 2nd hand will be a good option.
Little point in aftermarket performance systems unless there entirely stainless steel and your just buying so it doesnt rust again....
Carvel
PostPosted: 20:34 - 10 Jun 2014    Post subject: Reply with quote
https://www.watsdyke.org.uk/wp-content/uploads/2012/02/tin-can.jpg
https://c3270052.r52.cf0.rackcdn.com/packing-week-duct-tape4.jpg
Ben90
PostPosted: 20:43 - 10 Jun 2014    Post subject: Reply with quote
A quick ebay brought this up. Fairly cheap if its genuine.
Yamaha FZ6 S2
zark
PostPosted: 21:19 - 10 Jun 2014    Post subject: Reply with quote
Yeah, saw that...
And just bought it Razz
Let's hope I can get round to doing bigbiketests before it falls apart!
I take it a new gasket and probably new bolts and its a straight swap? Its the original one that's bust... 7 years/25k miles... can't complain I suppose
Thanks for the find,
ADSrox0r
Look closely at the joint, it's rusty as fuck under there you can see someone has just lashed a coat or two of VHT paint on to make it look tidy.
zark
PostPosted: 21:22 - 10 Jun 2014    Post subject: Reply with quote
Oh great....!
Cheap for a reason then?!
PostPosted: 21:38 - 10 Jun 2014    Post subject: Reply with quote
Better than what you've got.
Start getting penetrating oil on the studs ASAP.
Bean tin bodge until it arrives, bit of gun gum or silicone sealant (yes, the cheap stuff from Tesco), couple of jubilee clips or just twist-tightened wire as recommended by Che Guevara.
The last post was made 11 years, 237 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 56.11 Kb
