Gear selection issues
petalbriefs
PostPosted: 11:26 - 14 Jun 2014    Post subject: Gear selection issues Reply with quote
Just recently I seem to be having real trouble selecting gears at times.
Sometimes it wont go into first from neutral and sometimes it wont change down at all from whatever gear I am in.
I cant think of any common factors, seems to happen when hot or cold, I end up really stamping on the gearchange.
Its a real pain in the arse at times, got stuck at some traffic lights the other day cos it wouldn't go into first, had people having to drive around me Embarassed
Its a CBR125 07my
Any ideas please? Idea
trevor saxe-coburg-gotha
PostPosted: 11:31 - 14 Jun 2014    Post subject: Reply with quote
How long since last oil change?
I also find a well-cared for chain helps.
petalbriefs
PostPosted: 11:35 - 14 Jun 2014    Post subject: Reply with quote
I bought 5/6 weeks ago and the dealership I bought it from serviced it before I bought it, so last oil change would have been then.
How regularly do I need to lubricate the chain?
gavcarter
PostPosted: 11:40 - 14 Jun 2014    Post subject: Re: Gear selection issues Reply with quote
Its a CBR125 07my
Surprisingly easy to work on if it comes down to it. There is a small chance, if the bike has been dropped, or if you have stamped on the gear selector a bit too much you have bent the arm on it (the bit inside the bike).
What is MORE likely is it all needs a damn good clean!
Look at the gear selector and follow the arm back to the kickplate ( where foot peg is attached). There should be one STRAIGHT rod that connect the foot lever to the engine lever, if its bent, twisted that wont help at at all and needs straightening.
Other than that, take the rubber boots off each end of the rod and give the joints a good clean + fresh grease before putting the boots back.
Where the gear level passes through the kickplate, there is a split pin and a washer holding it in. You need to remove the kick plate, (2 allen bolts) then you can remove the split pin from the gear selector and drop it off the kick plate and the shaft on it a good clean, also clean the hole it goes into on the kick plate. Fresh grease again.
re-install, making sure to bend both legs on the split pin in opposite directions.
Linkage should all move as it should now, nice and easy not notchy or with much force.
If that fails, tighten the clutch cable a bit and call me a c*nt Very Happy Laughing Laughing Laughing
Teflon-Mike
tl;dr
PostPosted: 13:56 - 14 Jun 2014    Post subject: Reply with quote
Hmm, sorry to be a synic; but Trevor did ask when was the last time the oil was changed... NOT how long ago do you THINK the oil was changed... Dealers may have done no more than checked the oil level.
Next; 5/6 weeks... doesn't really tell us much. Oil change intervals on bikes can be short, on small bikes with small oil capacities, very short, as in 1250 miles short... that's a whole summer's sunny day bimbling for some riders; a months commuting to another, or a week-end out and about to some-one else.
What's the oil change interval in the hand-book? How many miles have you done since you had it?
AND... either way; get the book, get a spanner or two and do your OWN oil change any way, so you KNOW its been done, and when.
Following on from Gavs suggestion you look at the gear-lever.... your selection troubles wouldn't have started slightly co-incident with your 'chased' incident and dropping the bike would they?
Re-inspect the lever; it could be bent, the pivot pin could be bent, or loose, the adjuster-rod could be loose. Common that a random selector problem can be a floppy lever.
Also, its a 'rear-set' lever with linkage; a 'cheap' linkage being a commuter bike in a frock; and it's 7 years old. Good chance that the ball-joints have corroded/worn out. When you look at it you may notice that there are small holes in the middle of the linkage cups.. this is so you can squib a little chain lube in them when you lube the chain... probably never done.... and Bike could be due a new gear-lever assembly....
Next, as Trevor says working back down the line; chains is important; if you remember your CBT you ought to be checking chain tension every time you ride; chain ought then be adjusted every few hundred miles, and lubed at the same time, or weekly, whichever is the sooner.... so by current reckoning possibly 6 tensions and lubes behind the times if not touched since you got it.
AND... like most small bikes; gear selection made worse by slop in the transmission, and the added slop of oft unknown of or ignored 'cush-drive-rubbers'. These live in the rear wheel hub, behind the sprocket, and are basically blocks of rubber that fit between paddles on the sprocket carrier and webs in the wheel hub, and transmit drive between the two, but give some cushioning 'compliance'.
At seven years old these are probably due a replacement as they age harden regardless; but short lived on learner-legals, hammered by newbies with less than gentle clutch control, frequently 'over-shifting'*, often clumsily, and doing lots of slow speed manouvers, practicing for Mods.
I STRONGLY reccomend you do a precautionary replacement of them.
(JM grumbled of gear selector problems on his CBR when he had it couple of years back; when we had a look there was about a 3mm gap between each rubber block! Fixing that and he reckoned it completely changed both gear selection and the bikes 'responsiveness'... it can make a really big difference, and its SO cheap and easy to do)
Cush Drive Rubbers from Dave Silvers, get genuine OEM parts, not after-market rubbish or you may as well not bother; are about £15. Easy DIY fit, using bikes standard tool kit; all you have to do is take the back wheel out; then lift the sprocket carrier off the wheel, take out old bushes, and fit new ones; put carrier back on, put wheel back in... adjust chain.
Little bit of time, and we are talking a couple of hoirs here, for an oil change, CDR replacement, chain tension and a little bit of tweeking & Tightening on the gear linkage, lubing clutch cable, adjusting clutch, and other basic fettling, as reccomended by the Haynes manual, perhaps a Sunday Mornings work... and you will
a) eliminate variables if not 'problems'
b) get to know your bike
c) get to know basic bike maintenance
d) make your bike a WHOLE load nicer to ride
Maintaining a bike is as much part of owning one as riding; they need a LOT more regular attention than cars, and they do not like being neglected... they are a bit like women in that Wink
* TIP:- 'Over-Shifting' making more gear-changes than needed. Common Newbie fault; changing up too early, and riding in too high a gear, not letting engine 'rev'; so denying throttle control and 'responsiveness', as well as making work, and adding wear and tear to bike making too many unnecessary up-shifts, that then beg as many unnecessary down shifts, which also need to be compressed into shorter period during braking/slowing down, making more work, making riding harder, less smooth and adding wear and tear to bike.
Avoid over-shifting; use revs not gears; stretch out gear-shifts, give yourself more time to make shifts; make fewer shifts... a LOT of 'shift issues' are likely to go away, as you are making them simply from shifting when you dont need to and its less helpful.
Az
PostPosted: 14:25 - 14 Jun 2014    Post subject: Reply with quote
I'd service your bike as there's a good chance the dealership never actually serviced your bike. I remember my CBF would be harder to get into 1st from neutral when it was due a service. I used to simply let go of the clutch lever, pull the lever back in attempt to put it back into first again. I'm not sure why that worked, but it seemed to do the trick.
I lube my chain once a week (every 250miles).
CaNsA
PostPosted: 14:29 - 14 Jun 2014    Post subject: Re: Gear selection issues Reply with quote
Ignore everyone else, and adjust your clutch cable.
baldy
PostPosted: 15:30 - 14 Jun 2014    Post subject: Reply with quote
Or shift one gear at a time instead of coasting to a stop and trying to shift down through them all.
One day i will rule the world, just not today.
Islander
PostPosted: 15:40 - 14 Jun 2014    Post subject: Re: Gear selection issues Reply with quote
This ^^^.
Always start with the basics. Thumbs Up
petalbriefs
PostPosted: 17:10 - 14 Jun 2014    Post subject: Reply with quote
Just been to Halfords.........Wish me luck!!! Mr. Green
Nobby the Bastard
Harley Gaydar
PostPosted: 17:51 - 14 Jun 2014    Post subject: Reply with quote
A problem with gears not selecting (if there is the right amount of oil in there) is usually down to the clutch. On yours it's probably cable driven.
I'm surprised that no-one has suggested adjusting that....
Triumph Sprint ST 1050
petalbriefs
PostPosted: 18:07 - 14 Jun 2014    Post subject: Reply with quote
Is this too much slack?
https://vimeo.com/98219140
thomp1983
PostPosted: 18:10 - 14 Jun 2014    Post subject: Reply with quote
is that at the tightest point in the chain? what does the book specify for tightness?
gavcarter
PostPosted: 18:47 - 14 Jun 2014    Post subject: Reply with quote
I have, way up there ^^
gavcarter
PostPosted: 18:53 - 14 Jun 2014    Post subject: Reply with quote
If that the tightest point of the chain then no.
Assuming its not just the angle of video, you have about 35mm of travel ( look at bottom of chain, push up and look at bottom of chain again - not the top)
manual says 25-35mm so I would adjust it back to 25mm rather than wait for it to stretch again.
petalbriefs
PostPosted: 18:55 - 14 Jun 2014    Post subject: Reply with quote
[quote="thomp1983"]is that at the tightest point in the chain? what does the book specify for tightness?[/quote
I think so, never looked at one before, book says between 25-35mm, this looks like more than that to me but the rear axle nut is tight as a nuns under draws!!
Just wanted opinion of more experienced bike fettler's!
On the upside, I have changed the oil, so that's one less thing to worry about!
Now on to that pesky clutch cable.............. Thinking
gavcarter
PostPosted: 19:03 - 14 Jun 2014    Post subject: Reply with quote
Measure one point ( as you have) move wheel around a bit so you get a different section chain under the swingarm, measure that bit, move wheel etc etc.
tightest part of the chain is the section of chain that doesn't move as far as the rest....
As for rear wheel nut, get a spanner on the nut, pull it with one hand anti-clockwise ( just hard enough to get some pressure on it - dont need to try and undo it with one hand, and give the other end of the spanner ( end thats not on the nut ) a short, sharp tap with a hammer ( or just give it a good old girly clout Wink )
petalbriefs
PostPosted: 19:16 - 14 Jun 2014    Post subject: Reply with quote
Tried all that but its just rounding the nut off, I moved the chain around too chain still looks a little loose to me but I'm no expert, maybe I'll take it in somewhere to get it checked properly.
Gonna have a go at the gear change rod that you suggested checking earlier, looks straight to me but giving it a clean and lube cant hurt.
gavcarter
PostPosted: 19:25 - 14 Jun 2014    Post subject: Reply with quote
adjust it to 25mm ( the lower end of whats allowed ) and it will look a lot better, probably quieten down a fair bit too.
What size spanner or socket are you using on it?
PostPosted: 19:49 - 14 Jun 2014    Post subject: Reply with quote
That chain looks a little loose but not much at all if the wheel is off the floor.
Don't stamp through the gears, no matter how much you're struggling with the change. It's not necessary and you'll only bend something important.
busbar
PostPosted: 21:51 - 14 Jun 2014    Post subject: Reply with quote
I bought my YBR a month or so ago, 2012 model, low mileage, service history and well-looked after. After completing my CBT, and in my first few days of riding, I noticed a couple of times I attempted to pull away in neutral when I was sure I'd kicked down into first, but I put it down to me being a newbie numpty. Then one evening, when in neutral, I tried to kick down into 1st and it simply would not go in, much to the frustration of the driver behind me. I eventually got it to go in, probably with a combination of rocking the bike and/or letting the clutch out some way. I then read on this forum about the benefits of a properly-adjusted chain and an oil change. So that weekend I did both and guess what? Not one neutral-to-first problem since.
talkToTheHat
PostPosted: 20:37 - 17 Jun 2014    Post subject: Reply with quote
Take it to a independent garage, they'll have the nut undone in a few minutes. Watch out for the nuts and bolts made of cheese. I did that to the rear spindle nut of a 125, and the sump plug of my 535.
A smear of copper grease on exposed and hard to undo nuts and bolts is often useful the next time you attempt disassembly,
A hexagonal (not bi-hex or 12 point) socket or if you can't get a socket in there a hexagonal ring spanner (rare as hell) is your friend.
As suggested above check the ball joints of your shift linkage are running smoothly, use wd40 to free them up, let the wd40 run out or wipe it off, then apply a squirt of engine oil 10w40 or similar.
Check the adjustment of your clutch cable.
PostPosted: 20:58 - 17 Jun 2014    Post subject: Reply with quote
I'd ride with that slack but be changing it as soon as I got 5 minutes alone, it isn't going to kill you but it does only get worse and likely cause more wear.
If you want to start doing your own work, I'd suggest getting a decent set of sockets, even the halfords pro kit is quite nice, I've still got it and I'm ham fisted. You'll want a decent bar of some description top undo the rear nut, I just use an old piece of exhaust if I don't have a long bar, my dad has plenty and I may have borrowed one a while ago Whistle
PostPosted: 21:35 - 17 Jun 2014    Post subject: Reply with quote
It's not too tight anyway, which might have been the issue.
Now, did you actually get around to adjusting the clutch cable? There's an adjuster on the bars, it's just a case of unscrewing it a bit in order to take up most of the slack in the cable. Takes longer to type than to do it.
There will be another adjuster at the engine end, but you don't need to mess with that unless you've run out of adjustment at the lever end.
Teflon-Mike
tl;dr
PostPosted: 22:32 - 17 Jun 2014    Post subject: Reply with quote
No Roger... you adjust cables at the actuator end, where the thicker, longer adjuster is, not the lever end; lever adjuster is just to set the 'free-play'.
The last post was made 11 years, 297 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 140.07 Kb
