| petalbriefs |
 petalbriefs Traffic Copper
 Posted: 11:26 - 14 Jun 2014 Post subject: Gear selection issues |
Just recently I seem to be having real trouble selecting gears at times.
Sometimes it wont go into first from neutral and sometimes it wont change down at all from whatever gear I am in.
I cant think of any common factors, seems to happen when hot or cold, I end up really stamping on the gearchange.
Its a real pain in the arse at times, got stuck at some traffic lights the other day cos it wouldn't go into first, had people having to drive around me
Its a CBR125 07my
Any ideas please?  |
| trevor saxe-coburg-gotha |
| petalbriefs |
| gavcarter |
 gavcarter Could Be A Chat Bot
 Posted: 11:40 - 14 Jun 2014 Post subject: Re: Gear selection issues |
| petalbriefs wrote: | Just recently I seem to be having real trouble selecting gears at times.
Its a CBR125 07my
Any ideas please?  |
Surprisingly easy to work on if it comes down to it. There is a small chance, if the bike has been dropped, or if you have stamped on the gear selector a bit too much you have bent the arm on it (the bit inside the bike).
What is MORE likely is it all needs a damn good clean!
Look at the gear selector and follow the arm back to the kickplate ( where foot peg is attached). There should be one STRAIGHT rod that connect the foot lever to the engine lever, if its bent, twisted that wont help at at all and needs straightening.
Other than that, take the rubber boots off each end of the rod and give the joints a good clean + fresh grease before putting the boots back.
Where the gear level passes through the kickplate, there is a split pin and a washer holding it in. You need to remove the kick plate, (2 allen bolts) then you can remove the split pin from the gear selector and drop it off the kick plate and the shaft on it a good clean, also clean the hole it goes into on the kick plate. Fresh grease again.
re-install, making sure to bend both legs on the split pin in opposite directions.
Linkage should all move as it should now, nice and easy not notchy or with much force.
If that fails, tighten the clutch cable a bit and call me a c*nt  |
| Teflon-Mike |
 Posted: 13:56 - 14 Jun 2014 Post subject: |
Hmm, sorry to be a synic; but Trevor did ask when was the last time the oil was changed... NOT how long ago do you THINK the oil was changed... Dealers may have done no more than checked the oil level.
Next; 5/6 weeks... doesn't really tell us much. Oil change intervals on bikes can be short, on small bikes with small oil capacities, very short, as in 1250 miles short... that's a whole summer's sunny day bimbling for some riders; a months commuting to another, or a week-end out and about to some-one else.
What's the oil change interval in the hand-book? How many miles have you done since you had it?
AND... either way; get the book, get a spanner or two and do your OWN oil change any way, so you KNOW its been done, and when.
Following on from Gavs suggestion you look at the gear-lever.... your selection troubles wouldn't have started slightly co-incident with your 'chased' incident and dropping the bike would they?
Re-inspect the lever; it could be bent, the pivot pin could be bent, or loose, the adjuster-rod could be loose. Common that a random selector problem can be a floppy lever.
Also, its a 'rear-set' lever with linkage; a 'cheap' linkage being a commuter bike in a frock; and it's 7 years old. Good chance that the ball-joints have corroded/worn out. When you look at it you may notice that there are small holes in the middle of the linkage cups.. this is so you can squib a little chain lube in them when you lube the chain... probably never done.... and Bike could be due a new gear-lever assembly....
Next, as Trevor says working back down the line; chains is important; if you remember your CBT you ought to be checking chain tension every time you ride; chain ought then be adjusted every few hundred miles, and lubed at the same time, or weekly, whichever is the sooner.... so by current reckoning possibly 6 tensions and lubes behind the times if not touched since you got it.
AND... like most small bikes; gear selection made worse by slop in the transmission, and the added slop of oft unknown of or ignored 'cush-drive-rubbers'. These live in the rear wheel hub, behind the sprocket, and are basically blocks of rubber that fit between paddles on the sprocket carrier and webs in the wheel hub, and transmit drive between the two, but give some cushioning 'compliance'.
At seven years old these are probably due a replacement as they age harden regardless; but short lived on learner-legals, hammered by newbies with less than gentle clutch control, frequently 'over-shifting'*, often clumsily, and doing lots of slow speed manouvers, practicing for Mods.
I STRONGLY reccomend you do a precautionary replacement of them.
(JM grumbled of gear selector problems on his CBR when he had it couple of years back; when we had a look there was about a 3mm gap between each rubber block! Fixing that and he reckoned it completely changed both gear selection and the bikes 'responsiveness'... it can make a really big difference, and its SO cheap and easy to do)
Cush Drive Rubbers from Dave Silvers, get genuine OEM parts, not after-market rubbish or you may as well not bother; are about £15. Easy DIY fit, using bikes standard tool kit; all you have to do is take the back wheel out; then lift the sprocket carrier off the wheel, take out old bushes, and fit new ones; put carrier back on, put wheel back in... adjust chain.
Little bit of time, and we are talking a couple of hoirs here, for an oil change, CDR replacement, chain tension and a little bit of tweeking & Tightening on the gear linkage, lubing clutch cable, adjusting clutch, and other basic fettling, as reccomended by the Haynes manual, perhaps a Sunday Mornings work... and you will
a) eliminate variables if not 'problems'
b) get to know your bike
c) get to know basic bike maintenance
d) make your bike a WHOLE load nicer to ride
Maintaining a bike is as much part of owning one as riding; they need a LOT more regular attention than cars, and they do not like being neglected... they are a bit like women in that
* TIP:- 'Over-Shifting' making more gear-changes than needed. Common Newbie fault; changing up too early, and riding in too high a gear, not letting engine 'rev'; so denying throttle control and 'responsiveness', as well as making work, and adding wear and tear to bike making too many unnecessary up-shifts, that then beg as many unnecessary down shifts, which also need to be compressed into shorter period during braking/slowing down, making more work, making riding harder, less smooth and adding wear and tear to bike.
Avoid over-shifting; use revs not gears; stretch out gear-shifts, give yourself more time to make shifts; make fewer shifts... a LOT of 'shift issues' are likely to go away, as you are making them simply from shifting when you dont need to and its less helpful. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Az |
 Az World Chat Champion
| CaNsA |
 CaNsA Super Spammer
| baldy |
 baldy World Chat Champion
| Islander |
 Islander World Chat Champion
| petalbriefs |
 Posted: 17:10 - 14 Jun 2014 Post subject: |
Just been to Halfords.........Wish me luck!!!  |
| Nobby the Bastard |
| petalbriefs |
 Posted: 18:07 - 14 Jun 2014 Post subject: |
| thomp1983 |
 thomp1983 Crazy Courier
| gavcarter |
| gavcarter |
 Posted: 18:53 - 14 Jun 2014 Post subject: |
If that the tightest point of the chain then no.
Assuming its not just the angle of video, you have about 35mm of travel ( look at bottom of chain, push up and look at bottom of chain again - not the top)
manual says 25-35mm so I would adjust it back to 25mm rather than wait for it to stretch again. |
| petalbriefs |
 Posted: 18:55 - 14 Jun 2014 Post subject: |
[quote="thomp1983"]is that at the tightest point in the chain? what does the book specify for tightness?[/quote
I think so, never looked at one before, book says between 25-35mm, this looks like more than that to me but the rear axle nut is tight as a nuns under draws!!
Just wanted opinion of more experienced bike fettler's!
On the upside, I have changed the oil, so that's one less thing to worry about!
Now on to that pesky clutch cable..............  |
| gavcarter |
 Posted: 19:03 - 14 Jun 2014 Post subject: |
Measure one point ( as you have) move wheel around a bit so you get a different section chain under the swingarm, measure that bit, move wheel etc etc.
tightest part of the chain is the section of chain that doesn't move as far as the rest....
As for rear wheel nut, get a spanner on the nut, pull it with one hand anti-clockwise ( just hard enough to get some pressure on it - dont need to try and undo it with one hand, and give the other end of the spanner ( end thats not on the nut ) a short, sharp tap with a hammer ( or just give it a good old girly clout ) |
| petalbriefs |
 Posted: 19:16 - 14 Jun 2014 Post subject: |
| gavcarter wrote: | | petalbriefs wrote: |
Tried all that but its just rounding the nut off, I moved the chain around too chain still looks a little loose to me but I'm no expert, maybe I'll take it in somewhere to get it checked properly.
Gonna have a go at the gear change rod that you suggested checking earlier, looks straight to me but giving it a clean and lube cant hurt. |
| gavcarter |
 Posted: 19:49 - 14 Jun 2014 Post subject: |
That chain looks a little loose but not much at all if the wheel is off the floor.
Don't stamp through the gears, no matter how much you're struggling with the change. It's not necessary and you'll only bend something important. ____________________ a.k.a 'Geri'
| busbar |
 busbar Two Stroke Sniffer
 Posted: 21:51 - 14 Jun 2014 Post subject: |
I bought my YBR a month or so ago, 2012 model, low mileage, service history and well-looked after. After completing my CBT, and in my first few days of riding, I noticed a couple of times I attempted to pull away in neutral when I was sure I'd kicked down into first, but I put it down to me being a newbie numpty. Then one evening, when in neutral, I tried to kick down into 1st and it simply would not go in, much to the frustration of the driver behind me. I eventually got it to go in, probably with a combination of rocking the bike and/or letting the clutch out some way. I then read on this forum about the benefits of a properly-adjusted chain and an oil change. So that weekend I did both and guess what? Not one neutral-to-first problem since. |
| talkToTheHat |
| P.addy |
 P.addy Red Rocket
 Posted: 20:58 - 17 Jun 2014 Post subject: |
I'd ride with that slack but be changing it as soon as I got 5 minutes alone, it isn't going to kill you but it does only get worse and likely cause more wear.
If you want to start doing your own work, I'd suggest getting a decent set of sockets, even the halfords pro kit is quite nice, I've still got it and I'm ham fisted. You'll want a decent bar of some description top undo the rear nut, I just use an old piece of exhaust if I don't have a long bar, my dad has plenty and I may have borrowed one a while ago  |
| Rogerborg |
 Rogerborg nimbA
 Posted: 21:35 - 17 Jun 2014 Post subject: |
It's not too tight anyway, which might have been the issue.
Now, did you actually get around to adjusting the clutch cable? There's an adjuster on the bars, it's just a case of unscrewing it a bit in order to take up most of the slack in the cable. Takes longer to type than to do it.
There will be another adjuster at the engine end, but you don't need to mess with that unless you've run out of adjustment at the lever end. ____________________ Biking is 1/20th as dangerous as horse riding.
| Teflon-Mike |
The last post was made 11 years, 297 days ago. Instead of replying here, would creating a new thread be more useful? |
