Talk to me about VFR 800s. edit. Deposit paid, pickup Friday
carlosthejack...
PostPosted: 18:33 - 14 Jun 2014    Post subject: Talk to me about VFR 800s. edit. Deposit paid, pickup Friday Reply with quote
Finally got the missus on the back of the Hornet. From initially shitting herself to the point of hanging on for grim death, she relaxed and ended up really enjoying it. FIrst thing she said when we got back was"You're getting a bigger bike". Plumped for a VFR 800, but owt I need to know on the 02-05 models?
duhawkz
PostPosted: 18:40 - 14 Jun 2014    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=290965
It's mostly about the VTec models.
Itchy
PostPosted: 18:41 - 14 Jun 2014    Post subject: Reply with quote
There is an urban legend which nobody knows is true or not.
About the VTEC valves, Honda's workshop manual apparently says it requires 10 workshop hours to adjust the valves.
Bill who was a Honda dealer says buy the 750 and pre VTEC cam gear versions.
Peter a mechanic whom I trust thoroughly won't touch a VTEC with a barge pole.
A bike seller (who was pushing a VFR on me) said with valves don't ever touch them unless they need doing.
Arches Andy says Hondas never need their valves doing anyway.
K has NEVER done her valves. I did my CBR600 valves twice over the life of the bike.
PostPosted: 18:51 - 14 Jun 2014    Post subject: Reply with quote
I did the valves on my last gear driven VFR750 for the first time at 45k miles. They were all within tolerance.
I swapped the cams on my latest (Japanese import) VFR750 for a UK spec set out of a used engine manufactured three years later than mine. I had to buy 2 shims.
Valve clearances, certainly on the gear driven cam models, are not an issue
spnorm
PostPosted: 10:09 - 15 Jun 2014    Post subject: Reply with quote
I used to be a very active member of the VFR club (led ride outs and organised tours etc.) and the VFR guru Dave Roberts (aka "Greenvfr" - sadly killed by a SMIDSY in 2012) used to say that a heard ridden VFR would need its valves adjusting at the 16 or 32k service. He worked on dozens of the things for club members.
I checked mine at 32k and they were still all within spec, although a couple of the exhaust valves would have required adjustment at the 48k service.
I hated the VTEC engine on the 02-05 model and only kept mine for 4 months/6k miles before buying my 2000 model back. I'd recommend either buying a late pre-VTEC model or a 2006 onwards VTEC with the improved VTEC transition.
PostPosted: 10:21 - 15 Jun 2014    Post subject: Reply with quote
I've seen many reviews that claim the VFR750 was the best bike in the world for an allrounder. They added an extra 50cc and never harmed the thing. It all went wrong with the Vtech though I read. Go for the pre Vtech ones.
Maimboy
PostPosted: 12:32 - 15 Jun 2014    Post subject: Reply with quote
I've got a VTEC and it's just SUPER. I know the 750/800 don't have the valve clearance check hassle, but I think they look old and dated so f*** them. Mine's at 56K and the clearances have never been checked - if it goes pop, I've saved enough to buy another engine.
However... I don't think it's a great choice if you're regularly carrying a pillion, it's just not spacious enough.
duhawkz
PostPosted: 15:36 - 15 Jun 2014    Post subject: Reply with quote
I suppose it depends how big you are. I had the vtec and there was plenty of room for me and the missus and luggage.
I really liked mine, the only down side was the weight, they're a tad on the lardy side. I didn't find a problem when it was moving, just when you trying to paddle it backwards or in tight spaces. Embarassed
I found it quite top heavy and it doesn't have to lean over very far for it to tip over
Photo whore time
https://img.photobucket.com/albums/v720/duhawkz/PICT0330.jpg
Alex A
PostPosted: 16:20 - 15 Jun 2014    Post subject: Reply with quote
Maimboy wrote:
I know the 750/800 don't have the valve clearance check hassle, but I think they look old and dated...
Honda don't seem to agree. Their latest 2014 VFR800 looks rather like a facelifted VFR800Fi model, and borrows almost nothing from the VTEC design.
I bought a VFR800Fi recently. I was quite disappointed, and sold it after about a month. It felt heavy, a bit gutless, and was generally uninspiring to ride. The motor wasn't nearly as turbine smooth as the VFR750 I had 6 years ago. Granted, it had 50k on the clocks and the suspension was tired, but I wouldn't bother again. I'd buy something simpler and more effective.
Nyarlathotep
PostPosted: 18:38 - 15 Jun 2014    Post subject: Reply with quote
I have a 2008 vtec. Had it from new and it has about 24k on the clocks now.
Good bike, my wife prefers it as a pillion bike to some more traditional tourer types.
From 2006 on the vtec transition was made smoother and there were some cosmetic tweaks, but otherwise it's largely the same as yours.
Things to watch out for? Charging problems - mine is in the garage at the moment waiting for a re-wound generator to be fitted as the reg/rec went and killed it.
Otherwise the exhaust system is stainless steel but the brackets are mild steel and rust away (look at the low point of the exhaust near your right footpeg). When they go, replace them with cheap generic stainless brackets. The heat shield below the catalytic converter will suffer the same fate also. When that starts to fall apart, rip it off, chuck it away and forget about it.
Oh and when you are trying to ride more gently with a pillion you'll probably find the fuel injection is too "sharp" off a closed throttle, making it jerky. Either fit a power commander and get it mapped to suit, or just (as I did) get used to it - they're all like that!
sidewinder
PostPosted: 18:42 - 15 Jun 2014    Post subject: Reply with quote
I've been looking a vfrs myself. Some say the 750 is a better. Bike?
carlosthejack...
PostPosted: 15:59 - 16 Jun 2014    Post subject: Reply with quote
Cracking bit of advice, thanks for that! Thumbs Up
Dibble
PostPosted: 19:44 - 16 Jun 2014    Post subject: Reply with quote
Double post
Dibble
PostPosted: 19:46 - 16 Jun 2014    Post subject: Reply with quote
were you part of the mysterious cull of members and breakaway faction alluded to on the VFR owners forum?
spnorm
PostPosted: 22:53 - 16 Jun 2014    Post subject: Reply with quote
I'm one of the few who's still got a foot in both camps - I was never culled surprisingly, even though I was quite critical about the whole Bikers Oracle thing
Dibble
PostPosted: 07:50 - 17 Jun 2014    Post subject: Reply with quote
I've only had my 5th Gen VFR for 3 months (but have just done my first Reg/Rec) so don't know much about the Bikers Oracle Schism but it's a bit frustrating that some of the most knowledgeable members got banned. You find a useful old thread that comes to no conclusion because suddenly the poster got a bullet in the back of the neck.
Suppose that's the trouble with commercial sites.
carlosthejack...
PostPosted: 20:56 - 23 Jun 2014    Post subject: Reply with quote
Update. Went back to see the one I'd seen originally at a local dealers, 05 reg, 17k miles, looked fabulous. Got a good p/x deal on the Hornet I've not been able to sell for over a year and what I think is a cracking price for a very nice looking bike. I'd found cheaper, but a LONG way away, and the one that my mate's shop had got in and I test rode turned out to have the dodgiest history you could imagine.
Already bought the seat cowl and a double bubble screen.
Pick it up on Friday. Will report back.
DrDonnyBrago
PostPosted: 11:09 - 24 Jun 2014    Post subject: Reply with quote
I had a traffic light drag race against one of those last week.
I thought it would crap all over my 2001 CBR600F but it was neck and neck. They do look and sound nice Thumbs Up .
barrkel
PostPosted: 11:52 - 24 Jun 2014    Post subject: Reply with quote
AFAIK they come as sold with seat cowl and a couple of little plastic shims to cover up the mounts for pillion grab handles, if you remove them.
I wouldn't change the screen unless you specifically don't like the look of it or it otherwise is making the air hit you in a weird way. It's perfectly good for extended triple digits on the motorway without needing to duck behind it - IMO.
Big Rab
PostPosted: 17:21 - 24 Jun 2014    Post subject: Reply with quote
Dave was my friend, he worked on VFR`s for club members and any other owners. he knew these inside out. V-tec models. I had two . Liked them but the vtec glitch was horrendous in the wet, like a two stroke power band. newer models have improved engines, valve setting can be very expensive. I`d still buy a gear driven cam model if going for another VFR.
I`m surprised Honda didnt keep the gear driven engines, they were unbreakable. and so reliable. try them both out. you can still buy low mileage gear driven cam models.
Big Rab
PostPosted: 17:22 - 24 Jun 2014    Post subject: Reply with quote
The fat controller sacked a load of us. Thumbs Down
for speaking our minds. fat prick. Middle Finger
carlosthejack...
PostPosted: 17:55 - 25 Jun 2014    Post subject: Reply with quote
I'll hang fire until I've tried it. It's just that I've heard it doesn't deflct sufficiently. And I'd prefer it dark than clear too.
Bound to be better than the Hornet though eh?
Big Rab
PostPosted: 19:17 - 25 Jun 2014    Post subject: Reply with quote
Photo whore time
Just the same as yhre one I had, colour, panniers, top box, I also had Vario bars, melvin gel pad seat. heated grips.
carlosthejack...
PostPosted: 21:45 - 27 Jun 2014    Post subject: Reply with quote
Oh lordy, it goes like stink. All that worry about the VTEC kicking in is, frankly, gash. V-twin rumble all the way up to 7k rpm and then it goes BRRRRRRRRRRRRRRRRAAAAAAAAAAAPPPPPPPPPPP all the way to the redline. 120mph was easy, smooth, planted and effortless.
This is going to be good...
barrkel
PostPosted: 22:24 - 27 Jun 2014    Post subject: Reply with quote
Glad you like it. I find it a bit boring below 7k, it's much more fun winding it on in higher revs Wink
The turbine sound and feel as you accelerate hard with all valves going is pretty sweet.
The last post was made 12 years, 2 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 135.92 Kb
