Fuel tap query...
mullen1981
PostPosted: 17:12 - 15 Jun 2014    Post subject: Fuel tap query... Reply with quote
Hi I'm new to biking and I've just got a 99 bandit 600, it's
Came with no manual so I'm here to ask a question on fuel taps...
Can anyone give me a quick run down on how
to use it? I know reserve is for when it's ran out of fuel and on for when it's running normally I have it on 'on' but I'm wondering if
Anyone can give me a idea what to use it on a day to day basis? I know
It has on reserve and pri but I'm curious how to have it set?
Like I say I'm new so I'm sorry this
Sounds like a daft question.
Thanks in advance
CaNsA
PostPosted: 17:18 - 15 Jun 2014    Post subject: Reply with quote
Leave it on primary.
If you run out of fuel, turn it to reserve.
Fill up, turn it back to primary.
mullen1981
PostPosted: 17:22 - 15 Jun 2014    Post subject: Reply with quote
Is pri to the right? On pointing down, reserve pointing up?
JumpingFrog
PostPosted: 17:25 - 15 Jun 2014    Post subject: Reply with quote
For everyday riding you want to set it to ON. You are correct about using REServe if you run out, although you might need to prime first (see below). Don't be tempted to leave the tap set to reserve, you could end up clogging up your carburettors with dirt from the bottom of the tank.
The tap on the bandit is vacuum operated (IIRC) from manifold pressure; hence on will only allow fuel through if the engine is running. For this reason you have PRIme too which lets fuel flow regardless. You only use this to refill your fuel lines and carburettor float bowls (avoids flattening the battery).
2000 XJ 600S Diversion
CaNsA
PostPosted: 17:31 - 15 Jun 2014    Post subject: Reply with quote
Ignore jumping frog, the tap can only be in 1 of 2 positions.
In the pic below the tap is set to primary, if the tap was pointing to res then it would be using reserve.
https://i.imgur.com/fGmHEWZ.jpg
Biker101
PostPosted: 18:19 - 15 Jun 2014    Post subject: Reply with quote
@CaNsA I think JumpingFrog was right.
Pri is prime, and there are 3 positions, even the OP says this in the first post.
See here for a better pic - https://www.ebay.co.uk/itm/SUZUKI-BANDIT-GSF600S-GSF1200-GSF-600-1200-VACUUM-PETCOCK-GAS-TAP-FUEL-COCK-NEW-/370745658789?pt=Motorcycles_Parts_Accessories&hash=item565229cda5
It's also been covered before on this very forum - https://www.bikechatforums.com/viewtopic.php?t=117923
Past: 06 Runner SP50 >>> 01 Varadero XL125 >>> 08 Kwak ER-6f >>> 05 CBR600rr
Present: 99 FZS600 Fazer
CaNsA This post is not being displayed because it has a low rating (Flame). Unhide this post / all posts.
Biker101
PostPosted: 18:31 - 15 Jun 2014    Post subject: Reply with quote
CaNsA wrote:
JumpingFrog can FO IMO, joined in april only just posted today...
Anyways, nice spot there dude Thumbs Up
Why can someone new not join and try and help, with success in fact?
Were you not new once? That's such a bad attitude towards new members.
mullen1981
PostPosted: 18:40 - 15 Jun 2014    Post subject: Reply with quote
Just been out to double check and I definately have 3 parts to my fuel tap, turned up for reserve, right for pri, down for
ON. So have I got this right...
When I start the bike I turn it to pri, then when I'm ready to go turn it
To on, then leave it to on all the time until I turn it off? And then what do leave it on when it's parked up?
CaNsA
PostPosted: 18:42 - 15 Jun 2014    Post subject: Reply with quote
Rolling Eyes
Set me to enemy and be done with it.
Biker101
PostPosted: 18:43 - 15 Jun 2014    Post subject: Reply with quote
Just leave it set to ON, prime is only really for when the carbs are empty. If you look at the last few posts of the thread I linked to it explains it better.
But for day to day, use ON (and RES if you need to obviously).
Benjums
PostPosted: 20:53 - 15 Jun 2014    Post subject: Reply with quote
Thumbs Up for biker, leave the tap in the on position. The only time you need to turn it off is if you are going to leave the bike for a month or two.
Res is just I case you misjudge the mileage till the next fill up.
I really wouldn't worry about turning the tap on and pri every time you park up.
lihp
PostPosted: 21:05 - 15 Jun 2014    Post subject: Reply with quote
You know that there is no off position?
It's a vacuum tap, so in good working order, it's automatically off when the engine isn't running.
PostPosted: 21:14 - 15 Jun 2014    Post subject: Reply with quote
For a bike with an off position and no vacuum tap, if it has a weeping needle valve then leaving the petrol switched to on can easily dump the contents of the fuel tank into the engine over night let alone a couple of months.
PostPosted: 21:20 - 15 Jun 2014    Post subject: Reply with quote
ON - for riding with, will work so long as you have lets say more than 1/4 tank.
RES - the final 1/4 tank, get to a petrol station you've got something between 15 miles and 40 miles depending on state of bike and how heavy your throttle hand is.
PRI - for when you are too lazy to fix the vacuum part of the tap or when the carbs are likely to be completely dry, likely if you have run out of fuel after being on RES for a while or you have rebuilt the carbs and removed the lines, they will be empty and need filling without the need for loads of cranking to activate the vacuum part and thus flow fuel. Leads to dead battery Wink
I would never leave it on PRI, just in case what Kickstart says actually happens. It can and will Laughing
Benjums
PostPosted: 07:33 - 16 Jun 2014    Post subject: Reply with quote
/quote]
It's a vacuum tap, so in good working order, it's automatically off when the engine isn't running.[/quote]
Yea I know there is no off position I realized my mistake after typing and re reading it, I was tired and knew what I ment to say just not quite how to say it. Rolling Eyes
trevor saxe-coburg-gotha
PostPosted: 11:01 - 16 Jun 2014    Post subject: Reply with quote
Benjums wrote:
I was tired
Time for tubby bye bye!
https://i1.ytimg.com/vi/bvznncrAOJE/maxresdefault.jpg
Wonko The Sane
PostPosted: 22:03 - 22 Jun 2014    Post subject: Reply with quote
on my bike (ZZR) I used to have it as 'on' so that if I run out I have a way of moving a heavy bike
was unpredictable when it would run out on me so I've left it on reserve and just keep an eye on the fuel gauge, when it dips into the red, I need to find fuel shortly and can't make it all the way to / from work
PostPosted: 22:13 - 22 Jun 2014    Post subject: Reply with quote
ZZR600 fuel tap does seem to be a pig to switch to reserve while riding. Most bikes are far easier. Sitting at 70 I could manage the ~190 mile round trip to work fairly easily on a tank full (sitting at 80 made it more touch and go).
Grimeric
PostPosted: 22:33 - 22 Jun 2014    Post subject: Reply with quote
Just leave it to the on position. That's with the tap pointing down on the bandit. Switch it to reserve (pointing up) if you start to run low on fuel, you will know if the happens as it will probably judder misfire and cut out. My bandit needs to be switched to reserve with around a quarter of a tank left but I try not to let it get that far. I usually get around 130 miles before I need reserve depending on my riding.
The last post was made 12 years, 126 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 109.39 Kb
