| chappy |
 chappy Borekit Bruiser
| YBR Ric |
 YBR Ric Spanner Monkey
 Posted: 20:34 - 16 Jun 2014 Post subject: |
The quick release joint (if it's the one I'm thinking of) should be protected by a hinged black plastic case secured with a small [JIS] screw.
The fuel inside the pipe is under pressure, so fire hazard and other dangers whilst riding aside, this will continue to occur until correctly remedied. Preferably much sooner then later
If the connector is faulty you'll need to replace both sections of pipework.
It's a small possibility that the protective joint cover just needs to be removed to ensure the two halves of the join can be fully secured together before replacing it back around the joint.
bit difficult to see from over here  |
| chappy |
| P.addy |
 P.addy Formerly known as P.
| YBR Ric |
The last post was made 11 years, 262 days ago. Instead of replying here, would creating a new thread be more useful? |
