ybr fuel leak
chappy
PostPosted: 17:57 - 16 Jun 2014    Post subject: ybr fuel leak Reply with quote
Hello there I have a 2010 ybr 125 only had 2 weeks and was driving other day at 60 and bike cuts out completely know power I came two stop look at right side smoke every where so got off and noticed the black clip and fuel pipe come off and petrol leakin so pushed black clip and pipe back on and starts and runs fine then today on way home same happens so push back on . When I got home I pulled at it and the black clip and pipe comes away with a pull and it dont seam to click in place just pushes on . Is there a special way to click on when I try it just leaks fuel
Thanks
YBR Ric
PostPosted: 20:34 - 16 Jun 2014    Post subject: Reply with quote
The quick release joint (if it's the one I'm thinking of) should be protected by a hinged black plastic case secured with a small [JIS] screw.
The fuel inside the pipe is under pressure, so fire hazard and other dangers whilst riding aside, this will continue to occur until correctly remedied. Preferably much sooner then later
If the connector is faulty you'll need to replace both sections of pipework.
It's a small possibility that the protective joint cover just needs to be removed to ensure the two halves of the join can be fully secured together before replacing it back around the joint.
bit difficult to see from over here Wink
chappy
PostPosted: 18:40 - 17 Jun 2014    Post subject: Reply with quote
Thanks for help think I sorted it now just had a fiddle and the u lookin blqck clamp just click all way down for first time gave a pull after and don't wanna move so hopefully done . How full is the oil dipstick ment to be and I have a bit rock oil light gear oil left from my rs 125 can I use this or do I need other oil thabks
Formerly known as
P.
PostPosted: 18:54 - 17 Jun 2014    Post subject: Reply with quote
Cold bike, fill the oil so it shows near the MAX line. You want 10w40 oil. Regular changes and cheap oil is perfectly fine.
YBR Ric
PostPosted: 19:25 - 17 Jun 2014    Post subject: Reply with quote
Oil level should be checked with the dip stick resting on the engine - NOT screwed all the way in.
The last post was made 11 years, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 43.28 Kb
