What's missing off here?
Tritey This post is not being displayed because the poster is banned. Unhide this post / all posts.
gavcarter
PostPosted: 20:09 - 19 Jun 2014    Post subject: Reply with quote
pretty sure its usually a return spring......
PostPosted: 20:10 - 19 Jun 2014    Post subject: Re: What's missing off here? Reply with quote
Tritey wrote:
Neighbours daughter
Quid pro quo, Clarice.
gavcarter
PostPosted: 20:13 - 19 Jun 2014    Post subject: Reply with quote
Could also be a later set of carbs with the throttle position sensor removed?
PostPosted: 20:14 - 19 Jun 2014    Post subject: Reply with quote
Instantly thought this...
https://i.ebayimg.com/t/SUZUKI-GSX750-GSX-750-F-TPS-THROTTLE-POSITION-SENSOR-/00/s/MTIwMFgxNjAw/z/rYgAAOxyM89Sc9tL/$(KGrHqFHJEwFJhg2E0grBSc9tN1B3!~~60_35.JPG
However on a bike that old.. I doubt it.
PostPosted: 20:27 - 19 Jun 2014    Post subject: Reply with quote
About the right position for a throttle position sensor (as fitted to 1200 Bandits) but not aware the gsx750f had one.
If lucky it is a 1200 Bandit engine and carbs Razz
Bezzer
PostPosted: 20:31 - 19 Jun 2014    Post subject: Reply with quote
It's a TPS, or more precisely it's a missing TPS, few of the old oil cooled Suzukis - Bandits, Teapots have them. Many just bin it as on that one, it only alters the timing a touch at constant throttle openings/cruising to improve mpg. Which in the real world is zilch, doesn't affect the running in any way if not fitted can only cause a problem if it is fitted but malfunctioning.
gavcarter
later models did, see images on here https://www.ebay.ca/itm/2002-Suzuki-Katana-GSX750F-Carbs-Carburetors-w-TPS-Sensor-Guaranteed-Good-VIDEO-/121358012716?pt=Motorcycles_Parts_Accessories&hash=item1c4180512c the shape of the flange look to be a likely match
PostPosted: 22:48 - 19 Jun 2014    Post subject: Reply with quote
Not needed unless as said, its not the original engine.. then again, the difference it makes is nominal.
hmmmnz
PostPosted: 01:36 - 20 Jun 2014    Post subject: Reply with quote
i had one on both the bandit 12 and cb1000, having it disconnected made absolutly no real world difference on either bike,
leave it off, one less thing to go wrong
the humans are dead
I kick arse for the lord
The last post was made 11 years, 296 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 73.74 Kb
