| BadDog |
 BadDog Scooby Slapper
| MarJay |
 MarJay But it's British!
 Posted: 18:10 - 11 Jan 2005 Post subject: |
Chain adjustment.
Check your chain adjustment. If it is too tight or too loose the gear changes will feel poor.
If it is too tight I recommend you loosen it ASAP because you can damage your gearbox output shaft.
It should move about 3- 3.5cm at the loosest point on the lower run of the chain. Also check for tight spots as some areas of the chain can become stiffer than others.
Failing that, have a go at adjusting the clutch again - although bear in mind that if it hasn't got any better from you doing that then you might be adjusting the wrong way, or in need of a new clutch.
(Don't worry, changing the clutch is relatively straightforward with a haynes manual, and new springs and plates should not cost too much.)
HTH  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| G |
 G The Voice of Reason
| EuropeanNC30R... |
 EuropeanNC30R... Gay Hairdresser
| BadDog |
 Posted: 18:48 - 11 Jan 2005 Post subject: Thanks guys... |
... I'm going to have a go at adjusting the clutch tomorrow... will let you know how it goes...  |
| kasandrich |
 kasandrich Trackday Trickster
| hawkeye |
 hawkeye Nova Slayer
 Posted: 14:52 - 12 Jan 2005 Post subject: |
My NC seems to rattle when I pull off sometimes. The chain is always at the right tension (I check it regularly) and its usually because the chain is a little dry. Check the chain adjustment and lube the chain and it should go away  ____________________ '89 R/W/B NC30
'The car in front is... in my way' |
| BadDog |
| hawkeye |
 hawkeye Nova Slayer
| BadDog |
| hawkeye |
 hawkeye Nova Slayer
 Posted: 17:52 - 12 Jan 2005 Post subject: |
As I and others have said above, try checking the adjustment and then try lubing the chain. I've found the chain to be pretty sensitive to lubing and the noise chain when pulling away goes away after a good lubing  ____________________ '89 R/W/B NC30
| BadDog |
| hawkeye |
 hawkeye Nova Slayer
 Posted: 16:58 - 16 Jan 2005 Post subject: |
Yeah, the adjustment is a bit small, but thats due to the eccentric hub that adjusts the chain. You can also set the ride-height very slightly as well!!
My can is just an oval carbon fibre ART slip-on. Much better noise than a steel can (mate at uni has one on his NC). Below 8000, the NC will always be a bit weak. There are things you can do to the needles to tune out the midrange hole. Best to let a tuning shop take care of it  ____________________ '89 R/W/B NC30
The last post was made 21 years, 180 days ago. Instead of replying here, would creating a new thread be more useful? |
