Honda C200
daveD
PostPosted: 15:20 - 22 Jun 2014    Post subject: Honda C200 Reply with quote
Hi folks, have just bought a 1965 Honda C200 it's a 98cc pushrod engine so fairly simple.
Anyone got one on here?
I'm looking for info on rear indicators especially as they seem to have been removed.
Anyone got access to a parts book?
Dave '62 Enfield Crusader Sports, early GS500E
Son with an XJ600
Help I need a bigger garage!!
daveD
PostPosted: 18:32 - 22 Jun 2014    Post subject: Reply with quote
Vincent wrote:
Pics?
As soon as I collect it LOL.
Hopefully next couple days.
Son with an XJ600
daveD
PostPosted: 19:34 - 22 Jun 2014    Post subject: Reply with quote
Vincent wrote:
You sure they had indicators?
Seems to depend on the market.
This seems to have holes for the rears. I'll need to look when it arrives at the wiring and switchgear.
Son with an XJ600
daveD
PostPosted: 20:01 - 22 Jun 2014    Post subject: Reply with quote
Vincent wrote:
They may have been an optional extra at the time.
That would make sense. Laughing
Son with an XJ600
bypass2
PostPosted: 22:22 - 22 Jun 2014    Post subject: Reply with quote
I think they were mounted on the back mudgaurd
daveD
PostPosted: 19:35 - 23 Jun 2014    Post subject: Reply with quote
Yep, back ones on the guard, front seem to be mounted on the handlebars.
Son with an XJ600
map
Mr Calendar
PostPosted: 19:47 - 23 Jun 2014    Post subject: Reply with quote
Can't add to help but it looks like an interesting bike.
David Silver lists parts.
Also James May has/had one.
I will be interested in seeing this back on the road.
daveD
PostPosted: 20:01 - 23 Jun 2014    Post subject: Reply with quote
Thanks for that. Love the James May one, haven't we all been there?
Picking bike up tomorrow will stick some pics up when I can.
Son with an XJ600
daveD
PostPosted: 20:26 - 24 Jun 2014    Post subject: Reply with quote
Picked it up today. Carb will need a good going over but I got it running on easy start.
I cant beleive how little rust there is on it! 20 years in a shed in this country and it would be scrap.
Clutch seems to be slipping a bit so some new springs are likely to be in order. Also missing a grease nipple from one side of the forks.
Need to find a chain guard/case to fit and look up the front mudguard. They still make the front mudguards (pattern) in Malaysia, front headlight mount needs a look at too as it has a piece cracked.
https://i759.photobucket.com/albums/xx231/DaveD_06/C200/IMG_0339_zps635c8afa.jpg
https://i759.photobucket.com/albums/xx231/DaveD_06/C200/IMG_0336_zps98831f2a.jpg
https://i759.photobucket.com/albums/xx231/DaveD_06/C200/IMG_0343_zps77ede4c0.jpg
https://i759.photobucket.com/albums/xx231/DaveD_06/C200/IMG_0342_zpse0ed6375.jpg
Son with an XJ600
bypass2
PostPosted: 20:50 - 24 Jun 2014    Post subject: Reply with quote
I Like it. maybe wrong but are the old c90 mudgaurd /chaingaurd the same
daveD
PostPosted: 21:05 - 24 Jun 2014    Post subject: Reply with quote
May well be!
Son with an XJ600
alt tab
PostPosted: 22:51 - 24 Jun 2014    Post subject: Reply with quote
That looks like a cracking little bike, best of luck with bringing it up to scratch.
raptor996
PostPosted: 19:48 - 26 Jun 2014    Post subject: Reply with quote
Hi Dave i to have a c200 that iam doing up,i had 3 but one frame was passed it so now only 2 (1963/1964) just starting the rebuild now had the frame,forks & swingarm powder coated looking very good i must say.
just sorting out the indicators (the rears need new lensess as broken)
If you need help give me a shout
daveD
PostPosted: 18:32 - 28 Jun 2014    Post subject: Reply with quote
Well, I got her up and running today. Engine sounds fine.
I did discover that the rear sprocket carrier is cracked which is damned annoying.
Struggling to track one down so far but I need to find out if any other models are common to it.
Might take the gamble and order a pattern chaincase from Thailand, not payday yet though.
Son with an XJ600
daveD
PostPosted: 12:01 - 29 Jun 2014    Post subject: Reply with quote
Vincent wrote:
Some great stuff there! A few things I could use. Not seen that site before. Have you had things from it before? What is the postage from Japan like?
I'm liking the following!
n129955439 headlight surround £16 (can get one from Thailand for £29 posted so it really depends on postage)
j271352202 chain case top £11
j271352206 Sprocket carrier £10
u60829688 baffle £10
Son with an XJ600
daveD
PostPosted: 18:26 - 29 Jun 2014    Post subject: Reply with quote
You need a Japanese postal address to bid but I've got an agent out there that does it for me for $5 to $10 US each item depending on price. Cost of post depends on what it is but I wait until I have a good sized box with a mix of light/bulky items and small heavy ones to save on post.To give you an idea, something like a top fairing from a mid to big bike costs about £50 on its own, I've just had 25KG in 2 parcels sent and it cost me about £210. There's also post in Japan to add in....that's usually about £5 to £8 per item depending on size, they don't use post offices for parcels over there...it's all couriers. It aint cheap but I only get stuff I can't get anywhere else.....mainly Grey Import parts and 80s two-stroke stuff. I'm one of those weirdos that gets all excited at the sight of No Longer Available NOS parts Embarassed[/quote]
Thanks for that Vincent. I'm not panicking quite yet but that looks like a brilliant fall back.
Thanks for the offer and can I get back to you if I cant get something more "local"?
Son with an XJ600
daveD
PostPosted: 18:58 - 05 Jul 2014    Post subject: Reply with quote
update time.
Have found a new chaincase in the states. They've just restored a C200 and have used one on there's so hopefully I can get it to fit, also ordered bolts as they were cheeap from the same place and a rubber plug.
Still looking for a sprocket carrier but hopefully that'll be sorted as I've provisionally been offered one from a member on another site.
Stripped the exhaust off for a good clean and managed to get a load of black marks off of it; still lots of marks/gauges on it so not quite a pretty as I would have liked. I discovered that it was missing the downpipe to muffler gasket so have ordered one of them too.
Whilst the back wheel was off I removed the tyre which was perished and decided this afternoon to polish things up a bit, hopefully you can see which half I've polished here:
https://i759.photobucket.com/albums/xx231/DaveD_06/IMG_0341_zpsf3fcef56.jpg
Came up really well. Better than my old camera can show. Not perfect but pretty damn good.
https://i759.photobucket.com/albums/xx231/DaveD_06/IMG_0343_zps66b6cc9e.jpg
Also cleaned up the brake plate a bit, before:
https://i759.photobucket.com/albums/xx231/DaveD_06/IMG_0346_zps84b2edf6.jpg
and after
https://i759.photobucket.com/albums/xx231/DaveD_06/IMG_0348_zps51a090bc.jpg
Some big scratches to get out if I'm going to make it perfect but again, it'll do for MOT etc.
Also deglazed both the inside of the hub and the brake shoes.
So far this tiddler has been a pleasure to work on; no seized bolts etc.
I've started to T-Cut the frame and it is coming up nicely. Rear shock chrome has come up well too.
Have repaired the headlight mount but not really happy with it so I've ordered a new pattern one and a front mudguard from Thailand. A gamble but we'll see have it looks on arrival.
Son with an XJ600
pabeaufr
PostPosted: 16:20 - 23 Aug 2014    Post subject: Reply with quote
Hi Dave,
I bought my C200 1963 last January.
This « bike » is very rare in France
Here are the pictures (before)
https://www.casimages.com/img.php?i=14082305210217520212472065.jpg
https://www.casimages.com/img.php?i=14082305212317520212472067.jpg
This morning
https://www.casimages.com/img.php?i=14082305172117520212472056.jpg
https://www.casimages.com/img.php?i=14082305165517520212472054.jpg
Mine has turn signals.
2 holes on the handlbar ( Turn signals bought last week, I'm waiting for them) for front.
On the pics bellow, you can see the rear indicators on rear mudguard.
https://www.casimages.com/img.php?i=14082305174317520212472057.jpg
https://www.casimages.com/img.php?i=14082305180017520212472058.jpg
Have a good week-end
Patrick
Honda C200 1963, CB 350 K1 1968,CB 125 S 1971, CB 400 N 1978, Terrot 500 RGSE 1946, Citroën 2CV 1980
The last post was made 12 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.56 - MySQL Queries: 13 - Page Size: 137.44 Kb
