Tell me about blackbirds?
Itchy
PostPosted: 12:58 - 23 Jun 2014    Post subject: Tell me about blackbirds? Reply with quote
So I've seen a 2000 FI version, was thinking of a fat tourer like a BMW or a Pan but this missile caught my eye and I thought hmm that might make a good hyper tourer.
So what goes wrong with them other than reg/rec Hondas are legendary for?
Thanks
Copycat73
PostPosted: 13:00 - 23 Jun 2014    Post subject: Reply with quote
thirsty mpg.
caveat emptor
PostPosted: 13:03 - 23 Jun 2014    Post subject: Reply with quote
Biased as mine broke.
Stator, reg rec. Looking £150 to fix on your own £££ elsewhere.
Heavy and lardy, fairly juicy, linked brakes...some say they like but I didn't.
Wouldn't bother, to me offers nothing over a ZZR600 but faster.
Itchy
Copycat73 wrote:
thirsty mpg.
Well with a 1100cc engine thats a given.
map
Mr Calendar
PostPosted: 13:05 - 23 Jun 2014    Post subject: Reply with quote
Other bad points are cam chain tensioners.
Linked brakes can be a pita to overhaul, although standard maintenance should be ok.
Factor in replacement chain and sprockets.
Doesn't shred rear tyres like Hayabusa has a reputation (urban myth?) for.
Get with hard luggage and it's an excellent sporty tourer. I'd say 2nd to the VFR (others will disagree).
I'd like one if it wasn't the fact I hate chain adjustments. Which reminds me, check if it has a chain oiler. If not, why not?
I seem to recall the early FI had some sort of flat spot. I believe was remapped in later models. So many people rated the old carb models better (much like the BMW GS 1100/1150/1200 which is better debates).
PostPosted: 13:10 - 23 Jun 2014    Post subject: Reply with quote
Itchy wrote:
Copycat73 wrote:
thirsty mpg.
It really isn't though. My R1 got 200 miles to a smaller tank, I got 40+mpg easy on the R1. The BB got less, consistently. Thumbs Up
map
Mr Calendar
PostPosted: 13:20 - 23 Jun 2014    Post subject: Reply with quote
Itchy wrote:
Copycat73 wrote:
thirsty mpg.
Well, Fuelly gives 34mpg average.
So with a 23ish litre tank (or is it 24?) that's about 5 gallons (or 5.25 if 24 litres). So about 170 (or 179ish) miles to a tank. Taking in reserve of 4 litres (usually just less that a gallon) tank range ballpark about 150 miles before looking for a fill up.
To compare on another Honda V4, the ST1100, it's around 200 mile tank range, but that has no reserve, just a warning light. Different horse for a different course though so not like for like by any means.
Also FWIW have a read of this thread on the Blackbird. Seems I might have mis-remembered the flat spot issue, that thread says FI cured it.
PostPosted: 13:37 - 23 Jun 2014    Post subject: Reply with quote
I'd say ridden like a granny, you'll see 170 to a tank. If you decide to spooge a little and do some 100+ work, expect mpg to half. Lowest I got to a tank was 90 miles and that was doing 170 into work and 180 back, indicated officer, not real speeds.
Pie-Roe
PostPosted: 15:17 - 23 Jun 2014    Post subject: Reply with quote
I have paddys old blackbird now.
I find it very pleasant. I've done some work to it, new fork oil, full service, different springs up front and getting some other parts soonish. I mostly wanted a bigger bike for commuting, two up and luggage and for trips abroad. It costs me no more insurance. Consumables might be a bit pricier but not enough to put me off.
It handles fine for me, but I'm used to lardyish type things. It can be a little bit annoying when manouvering about parking in tight spaces etc, but not too bad.
In terms of MPG, I get fairly good commuting, fun riding it's pretty shit. This particular bike is running rich as hell, on standard pipes, so I'm going to get a full system and power commander.
jjdugen
PostPosted: 15:41 - 23 Jun 2014    Post subject: Reply with quote
Long and slow handling, front forks not really up to the job, rear shock bad from new. Ridden as intended they are a luxury cruiser more than fit for German autobahns. Brother had one that I used occasionally, first time I've actually done 100 miles in an hour in the UK. Salford to Sutton Coldfield and back on one tank (the trip back, early Sunday morning was the 100 mph average). So, not hanging about and the fuel light came on just as I was getting into Eccles. Hellish expensive if the plastics get damaged and they all seem to fall onto their right hand side.
You would have to be a lunatic to kill the engine, frame and engine cases tend to get bit scabby if not looked after. To lardy for me but Bro loved it.... until it ran him into a cliff face in the French Alps. Those linked brakes 'can' be lethal.
PostPosted: 17:05 - 23 Jun 2014    Post subject: Reply with quote
I really liked mine except for the linked brakes which I hate with a passion.
Basically it means you lose a front disk when you only use the front brake. You have to use both front and back to get full braking power on the front, which also means you are using the back whether you want to or not.
Had it on my 1800 Goldwing and a variation of it is in my Trophy Evil or Very Mad which was bad enough but on a hyper missile like the Blackbird it was utter lunacy IMO.
Triumph Trophy Launch Edition
Copycat73
PostPosted: 17:18 - 23 Jun 2014    Post subject: Reply with quote
that's wot I call thirsty
my ZZR14 returns 45 mpg average
YZF R1 5VY 48mpg average... I`ve seen it do 160miles b4 fuel light comes on.
caveat emptor
PostPosted: 17:46 - 23 Jun 2014    Post subject: Reply with quote
Might as well have a 250. Not being ridden correctly.
Kris
PostPosted: 17:56 - 23 Jun 2014    Post subject: Reply with quote
Ever ridden one?
It felt like what I imagine it's like to sit astride a torpedo. Didn't want to get round corners much though. Apparently shimming the rear shock helps lots; can't comment myself. Fast if a little too long for my liking.
www.prisonplanet.com
PostPosted: 18:01 - 23 Jun 2014    Post subject: Reply with quote
Did you ever get it fixed for starting on one battery?
Eddie Hitler
PostPosted: 18:05 - 23 Jun 2014    Post subject: Reply with quote
The Common Blackbird
https://i.imgur.com/HFuJJIO.jpg
The common blackbird (Turdus merula) is a species of true thrush. It is also called Eurasian blackbird (especially in North America, to distinguish it from the unrelated New World blackbirds), or simply blackbird, where this does not lead to confusion with a similar-looking local species. It breeds in Europe, Asia, and North Africa, and has been introduced to Australia (where it is considered a pest) and New Zealand. It has a number of subspecies across its large range; a few of the Asian subspecies are sometimes considered to be full species. Depending on latitude, the common blackbird may be resident, partially migratory or fully migratory.
The male of the nominate subspecies, which is found throughout most of Europe, is all black except for a yellow eye-ring and bill and has a rich melodious song; the adult female and juvenile have mainly dark brown plumage. This species breeds in woods and gardens, building a neat, mud-lined, cup-shaped nest. It is omnivorous, eating a wide range of insects, earthworms, berries, and fruits.
Both sexes are territorial on the breeding grounds, with distinctive threat displays, but are more gregarious during migration and in wintering areas. Pairs will stay in their territory throughout the year where the climate is sufficiently temperate. This common and conspicuous species has given rise to a number of literary and cultural references, frequently related to its song.
Fisty
PostPosted: 18:06 - 23 Jun 2014    Post subject: Reply with quote
Must resist Naomi Campbell jokes....
Fatter and faster than Fret
Hetzer
PostPosted: 18:09 - 23 Jun 2014    Post subject: Reply with quote
She's not black, she's just a cunt.
TheCatSatOnTh...
PostPosted: 18:30 - 23 Jun 2014    Post subject: Reply with quote
I really liked mine, but I had Ohlins internals front and Ohlins shock rear. With that setup, if you rag it a bit, budget for new bodywork. It scrapes on the floor when pushed. And I don't mean crashed.
stevo as b4
PostPosted: 18:38 - 23 Jun 2014    Post subject: Reply with quote
A bit better looking and a bit better build quality than the Busa is how I would call a blackbird.
Copycat73
PostPosted: 18:39 - 23 Jun 2014    Post subject: Reply with quote
read it and weep... no but hurt there like Rolling Eyes
caveat emptor
Ariel Badger
PostPosted: 19:12 - 23 Jun 2014    Post subject: Reply with quote
T.
The picture is not a Common Blackbird, rather it is the American Brewer's Blackbird. Common Blackbird has a golden eye and a yellow beak.
Sload
PostPosted: 19:40 - 23 Jun 2014    Post subject: Reply with quote
I like mine, handles and goes more then quickly enough for me but I'm not particularly a nutter anyway. It doesnt feel lardy to me and switches directions well as stock but it is not an R1. Armchair torpedo is probably as accurate as you will get.
Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx
Nb
PostPosted: 21:08 - 23 Jun 2014    Post subject: Reply with quote
They are still pink inside. Mine was way too fast for me if im honest, fuel consumption was shite, my van gets better mpg. But on a long journey it was fairly comfortable once you get the weight off your wrists at 90mph+ and as for consumables i got through two sets of tyres a year at 130 miles a week mainly due to squaring off because of commuting.
Only let me down once because of me not using the bike causing the battery to die but other than that it was perfectly fine, totally fucked off that i sold it a couple of months ago for like 1600 quid. Rolling Eyes Crying or Very sad Crying or Very sad
Pie-Roe
PostPosted: 12:05 - 24 Jun 2014    Post subject: Reply with quote
Not yet, I have a reconditioned starter motor here to fit and a few other bits. Where you put the battery in it's busted through the fairing, I think it's come a bit loose from wheelies. Although saying that, I've had it a fair while now and I've only charged the battery once for 20 minutes, so it might be fine. When I take the fairings off next week I'll have a look.
The last post was made 12 years, 56 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.18 - MySQL Queries: 13 - Page Size: 136.17 Kb
