how to empty my tank completely?
gsxfdumb This post is not being displayed because the poster is banned. Unhide this post / all posts.
SQL
PostPosted: 12:17 - 24 Jun 2014    Post subject: Reply with quote
Lighter? or turn it upside down with cap open and shake it you aren't worried about ruining the paint so it doesn't matter
RhynoCZ
Does the fuel tap have PRI position? If so, use it, if not and can be only operated with the vacuum hose on, I'd take the tap off to drain it and vent it out properly. You should take it off anyway to get paint under it and keep it clean during the painting.. Thumbs Up
Timmeh
1. open lid
2. Leave it the hot sunshine for the afternoon
3. Profit.
PostPosted: 13:13 - 24 Jun 2014    Post subject: Reply with quote
Long rag, soak up as much as you can, then let the rest evaporate.
map
Mr Calendar
PostPosted: 13:24 - 24 Jun 2014    Post subject: Reply with quote
Rogerborg wrote:
Long rag, soak up as much as you can...
You've been at the Finnish army manual again haven't you? Confused
...reference here.
Nobby the Bastard
Harley Gaydar
PostPosted: 14:31 - 24 Jun 2014    Post subject: Reply with quote
A Match...
Triumph Sprint ST 1050
dolly3900
PostPosted: 13:58 - 25 Jun 2014    Post subject: Reply with quote
Overlooking the obvious solution.
Run it dry, put it on the center stand, start it up, run the engine until it stops.
Then again, that would include dragging all the crud from the bottom of the tank into the rest of the fuel system, but if you have an inline fuel filter which you are changing whilst the tank is off, no worries.
2002 Rieju RS2-50 (Sold, spares or repair), 2010 Suzuki DR-125SM (Traded for ->), 2007 Honda CBF 600 (Sold), 2010 Suzuki V-Strom 1000 (Briefly, now returned), 2007 Suzuki Intruder 1800m (Even More Briefly, traded in for ->), 2014 Suzuki V-Strom 650
The last post was made 12 years, 126 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 56.76 Kb
