Speedfight 2 100cc starter motor problem
barryd
PostPosted: 11:39 - 22 Jun 2014    Post subject: Speedfight 2 100cc starter motor problem Reply with quote
My 2004 Speedfight 2 100cc will not start off the button. For a while it would sometimes work then sometimes not. Now just nothing. You get a click and thats it. I dont think its the battery.
The garage want £40 just to look at it and reckon it could get pricey.
Is there anything obvious or easy I could check before I hand it over to them? Im not very mechanical though!
barryd
PostPosted: 13:45 - 24 Jun 2014    Post subject: Reply with quote
Anyone? Very Happy
Doovy
PostPosted: 15:09 - 24 Jun 2014    Post subject: Reply with quote
Try changing the battery.
barryd
PostPosted: 15:15 - 24 Jun 2014    Post subject: Reply with quote
Thanks
I did fully charge the battery and it didnt seem to make any difference. Not sure its that as some days it would work find and others it was just dead.
Battery was reading ok when I tested it on a meter.
Doovy
PostPosted: 15:25 - 24 Jun 2014    Post subject: Reply with quote
Ok.
Starter motor could be gone / on the way out?
map
Mr Calendar
PostPosted: 15:41 - 24 Jun 2014    Post subject: Reply with quote
Or starter solenoid (thinking same as a bike).
If this is the case then shorting wth suitably insulated screwdriver to test (remember to do the brake lever pull to start if needed).
barryd wrote:
...Not sure its that as some days it would work find and others it was just dead...
Then IMO points to starter. If faulty/iffy may be drawing more amps than healthy for battery. The CB500's battery would need regular charges. Since I cleaned up the starter motor it's been fine and bike starts on the button each time (touch wood, don't jinx it).
barryd
PostPosted: 17:11 - 26 Jun 2014    Post subject: Reply with quote
Thanks very much. Will have a look at those.
TUG
PostPosted: 16:28 - 27 Jun 2014    Post subject: Reply with quote
I had an issue with my old speedfight 100 not starting on the button properly and it was due to the starter button being full of corrosion. I can't remember exactly how I sorted it, I cleaned it up I know that much but not so certain on how I stripped the switch. Be careful if you do it because the 2 contacts are small and can be easily lost.
Haz ER-5, innit!
barryd
PostPosted: 19:01 - 27 Jun 2014    Post subject: Reply with quote
Thanks.
That I can probably have a look at.
I fully charged the battery today and it still didnt start so its not that. There is a clearly heard click when you press the starter button though. Nothing else.
TUG
PostPosted: 21:25 - 27 Jun 2014    Post subject: Reply with quote
barryd wrote:
Thanks.
If the battery is goosed and you fully charge it, there is still a chance it could discharge anyway, I had an old FZR that used to do it and I could of saved myself a lot of hassle by simply replacing it but we live and learn.
If you can get to the starter solenoid then bride the connections with a screw driver, if you hear a click and nothing more, the solenoid is fine, if you have a mate who has a good battery borrow it and then if the bike still doesn't start you can rule that out too and it will be a case of either a loose wire on the starter motor/frame or the motor bushes are dead.
Haz ER-5, innit!
The last post was made 11 years, 206 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 67.64 Kb
