Brand new oil reduced to cream.
TUG
PostPosted: 20:05 - 25 Jun 2014    Post subject: Brand new oil reduced to cream. Reply with quote
So I got rid of my oil leak!
But now my rad is literally pissing out coolant and my oil is now cream.
The bike had been run without coolant for fuck knows how long, but is there any way to fix this? Would it be a case of replacing the head gaskets or will it be much worse?
Haz ER-5, innit!
Fisty
PostPosted: 20:09 - 25 Jun 2014    Post subject: Reply with quote
Yep sounds headgaskety to me, unless the head or block is cracked around the cooling jacket somewhere.
Fatter and faster than Fret
TUG
PostPosted: 20:16 - 25 Jun 2014    Post subject: Reply with quote
Thing is, why has it only done it now, when I dropped my oil it wasn't full of cream?
Haz ER-5, innit!
Suntan Sid
PostPosted: 20:19 - 25 Jun 2014    Post subject: Reply with quote
If the bike was running without coolant, there was nothing to mix with the oil to "cream" it.
If the headgasket is FUBAR you've added water to mix with the oil.
TUG
PostPosted: 20:23 - 25 Jun 2014    Post subject: Reply with quote
Now that you've said it, I can't believe I didn't even think of it.
So how do I fix this then? New cylinder head? With or without pistons and cams?
Haz ER-5, innit!
sickpup
Old Timer
PostPosted: 20:36 - 25 Jun 2014    Post subject: Reply with quote
In my experience of these engines, bin it and buy another one.
Fisty
PostPosted: 20:37 - 25 Jun 2014    Post subject: Reply with quote
New head gasket or buy a used engine from ebay.
pdg
PostPosted: 20:38 - 25 Jun 2014    Post subject: Reply with quote
Pistons don't go in the cylinder head.
I recommend having a word with some who, say, has had training as a mechanic and see what they think.....
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
Fisty
PostPosted: 20:39 - 25 Jun 2014    Post subject: Reply with quote
Rob Fzs wrote:
https://www.ebay.co.uk/itm/KAWASAKI-ER5-A-C-ER500-ENGINE-MOTOR-17-000-MILES-1998-/380814308874?pt=UK_Motorcycle_Parts_13&hash=item58aa4d360a
Buy that
no more hassle
job done for your £200 bike.
this one is cheaper Wink
https://www.ebay.co.uk/itm/kawasaki-ER5-engine-was-running-before-being-removed-from-bike-/191219771122?pt=UK_Motorcycle_Parts_13&hash=item2c859626f2
TUG
PostPosted: 20:42 - 25 Jun 2014    Post subject: Reply with quote
Slight slip up on my part, and given I rebuilt a VTR1000F engine and was an apprentice mechanic, I think I'll be ok. Thumbs Up
Haz ER-5, innit!
Nobby the Bastard
Harley Gaydar
I'm still confused as to how a bike with no coolant is emulsifying it's oil.
Triumph Sprint ST 1050
TUG
PostPosted: 20:45 - 25 Jun 2014    Post subject: Reply with quote
I filled the cooling system with water to see how no one noticed it didn't have coolant in it, originally I assumed that the leak would come from a pipe and run down the side of the engine as no one noticed, but when I saw it pissing out the bottom of the radiator, all became apparent.
Edit: Incorrect word use, I am doing several things at once here...
Haz ER-5, innit!
Nobby the Bastard
Harley Gaydar
PostPosted: 20:46 - 25 Jun 2014    Post subject: Reply with quote
I filled the cooling system with oil to see how no one noticed it didn't have coolant in it, originally I assumed that the leak would come from a pipe and run down the side of the engine as no one noticed, but when I saw it pissing out the bottom of the radiator, all became apparent.
You do know that you aren't supposed to fill the radiator with oil, don't you?
pdg
PostPosted: 20:48 - 25 Jun 2014    Post subject: Reply with quote
I saw you had mechanic training from a post in your project thread, which prompted my sarcastic remark.
I'm only being slightly mean here, but the fact you have had (at least some) training and had trouble sorting a brake and couldn't diagnose emulsified oil for me justifies my stance that nobody but me does any work on any vehicle I own.
TUG
A set of barrels is a lot cheaper than an engine but I see what your saying, could I still not repair this one and flog it anyway?
What kind of damage from the heat am I looking at? Hypothetically speaking.
Haz ER-5, innit!
TUG
PostPosted: 20:50 - 25 Jun 2014    Post subject: Reply with quote
Ah right I see, well keep it up I guess? Could you tell me which brake I had trouble sorting out? was it the Tokico 6 pots on the Kwak? Because they're well easy them. Thumbs Up
Haz ER-5, innit!
TUG
PostPosted: 20:51 - 25 Jun 2014    Post subject: Reply with quote
Yea I know that now after the last time, my mistake but this time I did it the right way I swear! Thumbs Up
Haz ER-5, innit!
pdg
I see the problem now.
OIL GOES IN CRANKCASE
and
WATER GOES IN RADIATOR
Clean them out, put the right fluids in the right holes - job jobbed.
TUG
PostPosted: 20:53 - 25 Jun 2014    Post subject: Reply with quote
and
I put water in the cooling system and oil into the engine via the engine oil filler upper port your highest of horses sittererererer. Laughing
Haz ER-5, innit!
sickpup
Old Timer
PostPosted: 21:01 - 25 Jun 2014    Post subject: Reply with quote
Cost of gaskets, seals and time. I can drop and replace one of those lumps in under 3 hours by myself.
TUG
PostPosted: 21:08 - 25 Jun 2014    Post subject: Reply with quote
Ok fair point, any suggestions on getting one that isn't as fucked or has some form of fault? And what should I do with the old engine as fucked ones are just scrap.
Haz ER-5, innit!
sickpup
Old Timer
PostPosted: 21:09 - 25 Jun 2014    Post subject: Reply with quote
Talk to R&C salvage Colchester, they warrant engines and pay for pick up if defective.
TUG
PostPosted: 21:20 - 25 Jun 2014    Post subject: Reply with quote
Thank you sickpup, I've had a look on egay
cylinder and pistons - £22.50
Base Gasket - £15-20
Head Gasket - £10 (cheapest one I found)
Vs a new engine costing £100+ I dunno which to do at the moment.
Haz ER-5, innit!
sickpup
Old Timer
PostPosted: 21:28 - 25 Jun 2014    Post subject: Reply with quote
Cylinder head will need skimming, will need copper gasket spray as well. Then if you're lucky it will work ok, if not...
The last post was made 11 years, 217 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 131.74 Kb
