| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 14:38 - 26 Jun 2014 Post subject: Why do car engines seem to use more oil than bikes engines? |
In my experience my bke engines have used little to no oil at all.
However, plenty of cars I have owned have used a wee bit between services, and generally speaking it seems to be more accepted that if you're hammering a car engine, it'll use a bit of oil.
Just wondered why really?
If anything bike engines should use more as they're consistently revved higher and harder. Or do car makers just slap an engine together, whereas motorcycle makers use finer tolerances? ____________________ My Flickr |
| tbourner |
 tbourner World Chat Champion
| MarJay |
 MarJay But it's British!
| Itchy |
 Itchy Super Spammer
 Posted: 14:48 - 26 Jun 2014 Post subject: |
Aww contraire you ever seen a thunderace? or early FZ EXUP?
I've known some which burn petrol and oil at 3:1 tatters had one which used 3-4 bottles in 2000 miles.
My thought is however is bike engines = performance machines.
Performance machines = much smaller tolerances as an engine thing spinning at 16000RPM is under a lot more stress than a car engine thing turning around at 5000rpm.... I'm not even sure I've seen 5000rpm in my car.
So less oil leaks between the piston rings, plus bike oil changes are 4000 miles, cars can go 20K without oil changes. So if 1-2% is lost through normal use, it is not noticable at 4K but noticable at 10K ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| groovylee |
 groovylee World Chat Champion
| DrDonnyBrago |
 Posted: 15:07 - 26 Jun 2014 Post subject: |
Thinking about it, none of my vehicles have ever used oil, and I've had some real scabby pieces of crap.
Maybe they've all had fuel leaks to keep them topped up .
| Wafer_Thin_Ham |
| Wafer_Thin_Ham |
| beardface |
 beardface Spanner Monkey
| Wafer_Thin_Ham |
| Baffler186 |
 Baffler186 World Chat Champion
| mentalboy |
 mentalboy World Chat Champion
| Andy_Pagin |
 Andy_Pagin World Chat Champion
 Posted: 17:00 - 26 Jun 2014 Post subject: |
My Landrover leaks more than it burns. I should fit a bucket underneath it with a pump to the oil filler.  ____________________ They're coming to take me away, ho-ho, hee-hee, ha-haaa, hey-hey,
Yamaha Vity -> YBR125 -> FZS600 Fazer -> FZ1-S Fazer |
| Fisty |
 Fisty Super Spammer
| gavbriggs |
 gavbriggs Crazy Courier
| DrDonnyBrago |
| Llama-Farmer |
 Llama-Farmer World Chat Champion
 Posted: 18:32 - 26 Jun 2014 Post subject: |
Had a car which didn't appear to use any oil at all in 12,000 mile intervals.
Another car I used to do a filter change every 6000 but would require 1 litre top up of oil every 1000 miles. It was burning some and evaporating some, but compression test was absolutely fine and wasn't leaking anywhere... engine ran beautifully, just happened to consume quite a lot of oil.
My bike doesn't seem to require topping up. A friends bike gets through quite a bit of oil though.
So I'd say that is all depends on many variables.
Cars do tend to have bigger capacity, more cylinders, larger sumps, run at lower rpm, and so the tolerances can be less tight. An engine limited to 5000rpm has a fuckload less energy and inertia than one that can rev up to 15,000rpm.
Energy is proportional to speed squared. Twice the speed equals four times the energy. Three times the speed (15,000rpm over 5,000rpm) is NINE times the energy in the system.
You need much tighter tolerances, and much tighter tolerances will usually mean much less chance for the oil to leak past where it is supposed to.
Oil is burnt off to cool things down if the engine gets too hot though. For example if the radiator loses all coolant, most modern systems can limit rpm and cut ignition to some cylinders, so only half the engine is firing, the other half is essentially cooling the engine with fuel and oil and air. ____________________ Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R |
| talkToTheHat |
| bikertomm |
 bikertomm World Chat Champion
| Llama-Farmer |
| bikertomm |
| weasley |
 weasley World Chat Champion
| Slacker24seve... |
 Slacker24seve... World Chat Champion
 Posted: 21:11 - 26 Jun 2014 Post subject: |
06-08 675 engines are partial to a drop of 10w40. So much so that for the 09 engine, Triumph didn't alter the sump; they shortened the dipstick!
My cars, even the hateful Renault shitbox, barely used a drop. ____________________ Triumph Daytona 675 track bike + girlfriend's Honda Hornet 600
Banger rallies are ace |
| jimspeed |
 jimspeed World Chat Champion
 Posted: 21:23 - 26 Jun 2014 Post subject: |
My mate was given a brand spanking MAN TGA truck a few years ago to do his job, driving to Italy each week.
The 1st oil change on it was 100,000KM's in that 100k it used around 5ltrs of oil but the sump held over 28ltrs so it hardly registered on the stick/dashboard computer thingy, where as some of the motors we service will have less than 1 ltr left in them after 6k
I think a lot of it is down to load cycles too the truck was always pulling weight and worked hard where a lot of cars just trickle around with no load on the engines to help the rings seal etc where a bike is usually worked hard at least once each trip. ____________________ Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?" |
| Nexus Icon |
The last post was made 12 years, 111 days ago. Instead of replying here, would creating a new thread be more useful? |
