Clutch still slipping after changing the friction plates.
c_dug
PostPosted: 16:36 - 26 Jun 2014    Post subject: Clutch still slipping after changing the friction plates. Reply with quote
I changed my clutch a tad over two weeks ago now, I've done well over 1000 miles on the new plates, I've noticed the clutch is still slipping a fair amount at lowish revs but big throttle openings, for instance if I go full throttle in second gear from 2krpm, the clutch will slip up to around 6krpm and then seems to grip. The grip could be me easing off a bit.
I changed the springs and friction plates for EBC items. I didn't change the steel plates. There was some blueing on two or three of the steel plates, very localised, there wasn't any burned smell from them though, and the plates were still dead flat.
Could the steel plates be the issue? If not what else might it be?
yen_powell
PostPosted: 16:40 - 26 Jun 2014    Post subject: Reply with quote
When I had a slipping clutch it was the arm where the cable connected to the engine that wasn't turning properly due to a seized bearing. Replaced the bearing, added some grease and all was well again.
XT1200Z and a DR350 in bits
Snorty
PostPosted: 16:42 - 26 Jun 2014    Post subject: Reply with quote
Definitely could be the steel plates. I had the same issue, I'd changed the friction plates but not the steels, and it started slipping again. If the steels are blued they need changing.
Fisty
PostPosted: 16:44 - 26 Jun 2014    Post subject: Reply with quote
Change the springs. The EBC heavy duty ones I had caused more slip than the fucked standard ones. I fitted OE new ones and has been fine since.
Fatter and faster than Fret
DMCpro
PostPosted: 20:35 - 26 Jun 2014    Post subject: Reply with quote
Cable stretched/not adjusted properly?
Did you measure the steel plates?
What oil are you using?
Steel plates are checked for warp on an engineers flat plate using feeler gauges may not be able to see warp with the naked eye
Possible position of the plates? Sometimes last plate is thicker or in a different plate
Honda CB-1, TS125X
VW Golf Estate
c_dug
PostPosted: 20:48 - 26 Jun 2014    Post subject: Reply with quote
Thanks for the suggestions Thumbs Up
The cable is at the end of it's adjustment, but that would do the opposite and not disengage, no?
Plates were checked with a feeler gauge on our marble kitchen cutting plate, flat enough for me to be confident they're not warped. (Shhh! Don't tell the OH).
Should have measured the steel plates but to be fair I didn't so I suppose that is a possibility.
Oil is 10w40 motorcycle oil, motul I think but could be Halfords own.
Fairly sure the plates were identical, I have both the Haynes and the Yamaha Service manuals, no mention of a specific order in either.
As it stands this suggestion:
Has got me thinking, I struggled with getting the arm lined up properly, I wonder if it is slightly out of alignment.
Also I remembered I took a couple of pictures of the marks on the plates and it is far worse than I remember, I'm going to replace the steel plates when I get paid:
https://i235.photobucket.com/albums/ee81/paddy2007dug/DSC_0270_zpsk9y0tr9q.jpg
https://i235.photobucket.com/albums/ee81/paddy2007dug/DSC_0269_zpsis8fqbgd.jpg
I reckon that will turn out to be it.
DMCpro
PostPosted: 20:56 - 26 Jun 2014    Post subject: Reply with quote
I would get a new set of steel plates in there.
Sometimes with the cable it can disengage but not fully causing slip
Is the clutch cable mounted onto the cover or on the engine side?
Honda CB-1, TS125X
VW Golf Estate
c_dug
PostPosted: 21:03 - 26 Jun 2014    Post subject: Reply with quote
The cover I think, though I might look in the morning and decide otherwise!
Fisty
PostPosted: 21:04 - 26 Jun 2014    Post subject: Reply with quote
Did you soak the new plates in oil overnight?
c_dug
PostPosted: 22:02 - 26 Jun 2014    Post subject: Reply with quote
Nope, instructions just said to give them a coat in oil before fitting?
PostPosted: 02:28 - 27 Jun 2014    Post subject: Reply with quote
Soaking clutch plates belongs in the same box as stuff like wire brushing new tyres to scrub them in, firmly taped up with a big sticker on the front stating 'OPEN ONLY IN EVERT OF DERP'
The bluing on your plates looks normal for the mild slipping you describe though the pic does indicate slight dishing on that plate.
Check your basics first. Pop the cable off at the engine end. If you can't make the lever flap about loosely by pushing and pulling the end of the cable, wash all the gunge out of it or replace. While you have the cover off clean and lube the helical release mechanism and check the pushrod clearance.
c_dug
PostPosted: 05:10 - 27 Jun 2014    Post subject: Reply with quote
This bit:
How, and what will it show?
EDIT: by how I mean, what am I measuring exactly?
el_oso
PostPosted: 09:16 - 27 Jun 2014    Post subject: Reply with quote
the pushrod clearance was what was wrong with the SV. If it's too tight then it may not allow the clutch to engage fully. The SV was opposite. It was so loose that no amount of cable pull would be able to turn the worm mechanism enough to push the pushrod and disengage the clutch.
Duke 390
Car: Jeep Wrangler 4.0L
c_dug
PostPosted: 09:29 - 27 Jun 2014    Post subject: Reply with quote
Oh, I see, I thought Pete. meant the arm that runs through the centre of the clutch itself.
The divvy doesn't use a push rod, the cable runs down through the bike directly to the clutch.
gandy666
PostPosted: 14:52 - 27 Jun 2014    Post subject: Reply with quote
hydraulic or cable clutch?
if its hydraulic, check that the fluid return hole in the master cylinder isn't blocked.
engine heat makes the fluid expand and if it cant return it'll engage your clutch
PostPosted: 15:18 - 27 Jun 2014    Post subject: Reply with quote
Aah right, Divvy, thought it was the SV. The devil's in the detail....
Yammy clutch, they either slip or grab 'they all do that sir' Very Happy
Ed Case
PostPosted: 16:28 - 27 Jun 2014    Post subject: Reply with quote
Have you started using a super-dooper non-bike oil ?. Some clutches are sensitive to fully-synthetic car stuff.
c_dug
PostPosted: 16:31 - 27 Jun 2014    Post subject: Reply with quote
Sorry, should have clarified earlier!
No super oils used, just a plain motorcycle oil.
1cyl
PostPosted: 21:21 - 27 Jun 2014    Post subject: Reply with quote
I fixed this problem with:
https://www.bikechatforums.com/download.php?id=93083
Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
c_dug
PostPosted: 07:42 - 28 Jun 2014    Post subject: Reply with quote
Did that not make the clutch very hard to pull?
To be fair if it worked I'll happily give it a go as a short term solution, need to ride to Bournemouth on Monday.
bodger
PostPosted: 08:07 - 28 Jun 2014    Post subject: Reply with quote
Your diversion should have a return spring between the clutch actuating arm and the clutch casing to help return the arm.
Try disconnecting the clutch cable from the arm to see if the arm moves easily.
If the arm is stiff in the casing, it will need to be stripped to allow it to move freely.
PS also check that the clutch cable moves freely.
c_dug
PostPosted: 11:15 - 28 Jun 2014    Post subject: Reply with quote
It does have a spring, I'll have a fiddle when the rain stops and see whether there is any stiffness.
I'm sure it was all moving freely when I changed the plates.
Robby
Dirty Old Man
PostPosted: 12:29 - 28 Jun 2014    Post subject: Reply with quote
I have had similar problems in the past following a clutch change, where It would either slip or be really stiff and grabby. Sorted itself out in 200 miles or so.
My theory is that the steel plates and basket wear to fit each other over time, and when you change the clutch the bits end up in a slightly different position and catch on each other. Over a few hundred miles they wear smooth and start behaving.
A bit of blueing shouldn't affect the steel plates too much - the reason to look out for it is that blueing is a sign of heat, and heat causes warping. If they aren't warped I wouldn't change them. I probably would roughen them a bit with some emery paper. That could make the clutch a bit grabby, but it will wear down in no time.
1cyl
PostPosted: 16:16 - 28 Jun 2014    Post subject: Reply with quote
Not particularly heavy. But then I think Lifan/pit bike engines only have small basket setups anyway, so less plates and weaker springs perhaps?
In addition to the ziptied springs, I found that adjusting the cable so that the biting point is only just cleared when the levers pulled, also helped in curing the slip when engaged.
c_dug
PostPosted: 14:30 - 08 Oct 2014    Post subject: Reply with quote
So after ignoring this issue for a while it was gradually getting worse, yesterday I decided to get off my arse and do something about it.
I think this:
https://i235.photobucket.com/albums/ee81/paddy2007dug/DSC_0341_zpsam5canp2.jpg
Was causing a lot of my issues.
I installed a new cable yesterday and it seems much better than it was, I'm having some real issue with getting it set up nicely though. At the moment it feel a little like the travel in the lever isn't equating to enough travel at the clutch arm if that makes any sense?
Like when the lever is all the way out the clutch still slips a tiny bit, and when the lever is all the way in it still crunches a tad on the gear change. I feel like if there was an extra 5mm at both ends then it would solve all of the issues.
Is this just an adjustment issue? The lever isn't being pulled back entirely, when I let go of the lever I can push it another 2-3mm out, unsure if that is relevant?
The last post was made 11 years, 116 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 131.06 Kb
