tyre damage
dardappa2004
PostPosted: 22:03 - 26 Jun 2014    Post subject: tyre damage Reply with quote
Hi guys and girls,
Just a quick questions about my rear tyre . Basically on the way to work some bint pulled out in front of me last minute causing me to do an emergency stop from 70mph to 20mph on a dual carriage way to which I had to swerve on to the hard shoulder ( if you call it that) . Anyways after that little drama I arrived at work and on my lunch I saw my tyre has tears in it. So rang kawasaki to get some new tyres booked in the following morning. So on the way back home I get pulled over by the police who spotted the tears . I explained to them what happened and that the bike has been booked in for tyres both front and rear to be replaced. Regardless of that they gave me a prohibition of my bike whi h I was unable to use til I got the tyres replaced and a FULL MOT redone and said that my tyres were dangerously torn... So following day got all that criteria met got the prohibition notice removed from there system. Received a letter today about my tyre saying either accept 3 points and 100 pound fine or go to court.
Im a bit annoyed given the circumstances and unsure what I should do? Accept the fine and points or go to court?
Ill post the tyre and you give me your knowledgeable thoughts on the tyre and advice on what I should do?
clancy
PostPosted: 22:15 - 26 Jun 2014    Post subject: Reply with quote
Take it to court, that damage could easily be caused by heavy breaking over crap surface etc
You done what you where asked too, repaired the next day and proved etc. I'd say you have reasonable grounds to argue the points
Or if the points don't bother you just take them, saves agro
KLX 300r
Fisty
PostPosted: 22:17 - 26 Jun 2014    Post subject: Reply with quote
The tyre is worn out. Heavy braking didn't cause that.
Fatter and faster than Fret
nowhere.elysium
The Pork Lord
PostPosted: 22:19 - 26 Jun 2014    Post subject: Reply with quote
Take the fine. You've neglected those tyres for a long while, by the looks of it.
Nobby the Bastard
Harley Gaydar
PostPosted: 22:20 - 26 Jun 2014    Post subject: Reply with quote
You got the prohibition notice because the tyre had no tread and was likely showing cords etc.
This had nothing to do with braking from 70 mph. It has everything to do with you not maintaining your vehical.
Edit: And that's the rear and you are blaming this on excessive braking from 70 down to 20 in one hit?
You do know that, as soon as you use the front brake, all the weight lifts off the rear and so the chances of it doing anything other than flatspotting is negligable. You just wore out this tyre and then have butt-hurt because you got caught.
Triumph Sprint ST 1050
dardappa2004
PostPosted: 22:21 - 26 Jun 2014    Post subject: Reply with quote
When I did E brake there was crazy on the hard shoulder also these tears are not all the way round the tyre just on the bit shown. The back wheel did lock up to which I had to release and reapply
nowhere.elysium
The Pork Lord
PostPosted: 22:23 - 26 Jun 2014    Post subject: Reply with quote
So? There's no tread in the middle. You're meant to have at least 1 mm left on it for it to be road legal - that's clearly not.
McJamweasel
BCF Junkie
This. Thumbs Up
pdg
Don't listen to these twats, that tyre is pretty much perfect and should have at least 4,000 miles of life left on it.
Did you call the copper who pulled you a cunt?
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
Carvel
PostPosted: 22:25 - 26 Jun 2014    Post subject: Reply with quote
Who is crazy?
dardappa2004
So just accept the fine then?
nowhere.elysium
The Pork Lord
PostPosted: 22:26 - 26 Jun 2014    Post subject: Reply with quote
Accept the fine, be grateful for it, and learn to maintain your vehicle.
jeddy11
PostPosted: 22:27 - 26 Jun 2014    Post subject: Reply with quote
Whatever the reasons which maybe valid those tyres are illegal and you were using the bike..
Happened to me in my car years ago i was going to the local tyre fitters 5 mins away from work who my boss had booked for me was heading there and was like 2 mins away when i got pulled, i explained and they said i should have taken the wheels off (2) and taken them there !!
They also said i can take a ticket for 1 tyre or go to court for 2 tyres Shocked b'stards
Although good news i received a letter later saying they had made a mistake with the ticket and there would be no further action Thumbs Up
Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!!
MarkJ
That's what tyres do just before they expose the threads underneath. They're way past done.
Fisty
PostPosted: 22:28 - 26 Jun 2014    Post subject: Reply with quote
https://image.sportrider.com/f/15729683/146_0904_14_z+SR_tire_comparison_test+pirelli_diablo_corsa_III.jpg
https://www.bikechatforums.com/download.php?id=93077
Mrs F's rear diablo did exactly that when it was worn out.
Nobby the Bastard
Harley Gaydar
Quite frankly, you should be offerng up your arse to them for saving your life....
dardappa2004
PostPosted: 22:29 - 26 Jun 2014    Post subject: Reply with quote
I'm just asking advice that's all.
I accept that if I make a mistake I'll admit to it and won't try and weasel out as there no point. I only use my bike to get to and from work so didn't realise as I finish late at night
Nobby the Bastard
Harley Gaydar
PostPosted: 22:31 - 26 Jun 2014    Post subject: Reply with quote
A tyre doesn't get that bad in a week. I do 200 miles a week and kill a rear in 6 months.
dardappa2004
PostPosted: 22:35 - 26 Jun 2014    Post subject: Reply with quote
I bought the bike second hand about 3months back so ignorance on my side for not checking
sickpup
Old Timer
PostPosted: 22:36 - 26 Jun 2014    Post subject: Reply with quote
I remember when Cansa posted a tyre like that, he called it power tears, we called it bald. He doesn't mention it anymore.
That tyre is bald, it was over inflated. Deal with it.
dardappa2004
PostPosted: 22:40 - 26 Jun 2014    Post subject: Reply with quote
Have dealt with it I've already filled out the fpn sick up Thumbs Up
sickpup
Old Timer
PostPosted: 22:42 - 26 Jun 2014    Post subject: Reply with quote
Now learn to adjust the tyre pressure for your weight.
dardappa2004
PostPosted: 22:48 - 26 Jun 2014    Post subject: Reply with quote
How would I gauge the pressure for my weight 68kg and the tyre on now is pilot powers? Bike is a 2005 zx10r
PostPosted: 22:50 - 26 Jun 2014    Post subject: Reply with quote
Look in manual or on michelin website https://moto.michelin.co.uk/
Use the minimum stated figure as you're light.
reed
PostPosted: 23:03 - 26 Jun 2014    Post subject: Reply with quote
I looked at that and thought it looked fine in terms of tread.
Although until 2 days ago I had been riding around on this with little worry myself, cords had been showing for weeks. Laughing
I can safely say I got the most out of it.
https://i.imgur.com/7EsuSim.jpg
Generic XOR 50, Gilera SMT 50, GSXR 400 GK73A, Ducati Monster 600, Honda Hornet 600.
Sold. Stolen. Written off. Sold. Current.
The last post was made 12 years, 111 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 130.46 Kb
