Anything I can do to cure a weave?
gbrand42
PostPosted: 14:19 - 27 Jun 2014    Post subject: Anything I can do to cure a weave? Reply with quote
My new bike has a slight weave at around 85, which is just around the speed I like to sit at on my private test track Thumbs Up
It only does it when I have the top box on. It's not really bad but it would be nice if I could get rid of it.
I know little about the workings of suspension but was wondering if adjusting the preload up or down a bit might help.
Anyone with any knowledge care to offer an opinion?
Yamaha RD50M, Honda C90, Yamaha RS100, Yamaha RD125LC, Honda XL125 V9 Varadero, Honda NT700VA, Honda VFR800X, Honda CRF1000L, Honda ST1300 Pan European
PostPosted: 15:03 - 27 Jun 2014    Post subject: Reply with quote
I doubt adjusting your suspension will help. You need to change the weight distribution and aerodynamic properties of the bike. A screen might help, but personally I'd ditch the top box.
Busa1340R
PostPosted: 16:32 - 27 Jun 2014    Post subject: Reply with quote
I would at least check tyre pressures and check for abnormal tyre wear. Bit more air in the rear tyre and maybe a stiffer rear spring may help. Are your head bearings smooth and correctly adjusted? And what about your rear suspension linkages.
But ultimately as above......ditch the topbox....get a tank bag if you have to carry sh1t. I have found that rucksacks can equally cause a bit of a weave at speed.
Other opinions are available........
Current: 2010 Suzuki GSX1340R Hayabusa, 2013 Yamaha YP250R X-Max Sport - Previous: Triumph Sprint ST1050ABS, Honda XL600V Transalp, Honda NT650V Dullsville (don't ask!), Kawasaki ZX9R E1, Honda NX650 Dominator, Suzuki GSX1300RKZ Hayabusa, Honda CBR1000FM, Kawasaki GPZ500S, etc etc
gbrand42
PostPosted: 17:12 - 27 Jun 2014    Post subject: Reply with quote
Thanks guys, I thought as much. TBH I only keep the topbox on to sling my helmet in while I'm at work, can just as easily take it in with me. Karma to you both Thumbs Up
Suntan Sid
PostPosted: 17:17 - 27 Jun 2014    Post subject: Reply with quote
Murray explains it all:-
https://www.bikechatforums.com/viewtopic.php?t=276208
hachi8
Rogain?
K7 GSXR 1000 - The Beast!
hachi8
PostPosted: 17:18 - 27 Jun 2014    Post subject: Reply with quote
Rogain?
Carvel
PostPosted: 17:43 - 27 Jun 2014    Post subject: Re: Anything I can do to cure a weave? Reply with quote
Topbox's are gay as fuck, ditch it.
cb1rocket
PostPosted: 18:53 - 28 Jun 2014    Post subject: Reply with quote
Worn shock absorbers
Matt B
PostPosted: 10:13 - 29 Jun 2014    Post subject: Re: Anything I can do to cure a weave? Reply with quote
My Pan does the same thing at exactly the same speed (when riding around my private estate).
Same cause - top box, If I take it off it stops. I normally only have the box on when I need to store gear in it parked up so I just deal with it and ride a bit slower.
Gets worse when I have a folding camping chair strapped across the pillion seat against the box. Must be to do with air flow coming round and buffeting the box.
Slacker24seve...
PostPosted: 10:35 - 29 Jun 2014    Post subject: Reply with quote
The top box (weight thereof or aerodynamic effects of) could be exacerbating a problem that would otherwise go unnoticed. I would thoroughly check the following:
Wheel alignment
Wheel balance and bearings
Suspension condition and function
Tyre pressures and condition
Re: Pan weave, didn't the police ditch them when they noticed they started weaving at 100+?
Banger rallies are ace
Matt B
PostPosted: 08:07 - 30 Jun 2014    Post subject: Reply with quote
They did ditch them for that reason but that was the newer ST1300, not the old ones like mine. May be wrong but I think there was a pretty major accident/death at high speed on the 1300.
Without the box it's solid as a rock at a ton (Autobhan of course). Even with it on it's not really a weave, more like the buffeting you get from a tall screen.
The last post was made 11 years, 228 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 74.3 Kb
