Oil cooler beyond repair?
Dave M
PostPosted: 15:34 - 27 Jun 2014    Post subject: Oil cooler beyond repair? Reply with quote
Hi all. Are these oil cooler fins too far gone to repair or should I just straighten them up as best I can?
https://i1214.photobucket.com/albums/cc487/weedave1/Mobile%20Uploads/DCE5C3FB-7508-481D-8C87-055A61EAC83E.jpg
https://i1214.photobucket.com/albums/cc487/weedave1/Mobile%20Uploads/02BA2A60-1FFE-4B6B-9517-C8D59D88C4EA.jpg
Cheers.
Hetzer
PostPosted: 16:02 - 27 Jun 2014    Post subject: Reply with quote
Get a pair of needle-nose tweezers (NOT pliers), pass them through (one arm on each side of each fin) and squeeze. Painstakingly tedious but doable.
Busa1340R
PostPosted: 16:16 - 27 Jun 2014    Post subject: Reply with quote
Get a radiator comb off "the Bay" for under a tenner.....
Current: 2010 Suzuki GSX1340R Hayabusa, 2013 Yamaha YP250R X-Max Sport - Previous: Triumph Sprint ST1050ABS, Honda XL600V Transalp, Honda NT650V Dullsville (don't ask!), Kawasaki ZX9R E1, Honda NX650 Dominator, Suzuki GSX1300RKZ Hayabusa, Honda CBR1000FM, Kawasaki GPZ500S, etc etc
Dave M
PostPosted: 16:33 - 27 Jun 2014    Post subject: Reply with quote
Had a go straightening a few jus to see how much of a ball ache it will be and they started falling off. Will this be a problem? Should it still do it's job if a small few come off? Cheers.
Busa1340R
PostPosted: 16:38 - 27 Jun 2014    Post subject: Reply with quote
Not ideal.
I would say if only a few fall of and it doesn't leak you will be OK. If you end up with large gaps, like grannies teeth then its cooling ability will be impaired...better to source annuverun'
Hetzer
PostPosted: 16:53 - 27 Jun 2014    Post subject: Reply with quote
I assume only the bent bits are breaking off, leaving a section behind? In which case I'd not worry about it, considering the percentage in the picture that need straightening is small.
Dave M
PostPosted: 18:11 - 27 Jun 2014    Post subject: Reply with quote
I've straightened them as best I could. The core looks good and not too many have fallen out. I'll take more pics.
Dave M
PostPosted: 19:03 - 27 Jun 2014    Post subject: Reply with quote
How do they look now? Not much more I can do with them. Should be able to zoom in on the pics. This iPhone is s*** for taking pics!
https://i1214.photobucket.com/albums/cc487/weedave1/Mobile%20Uploads/90818AC7-29E3-4BBF-9361-E53756A663EF.jpg
https://i1214.photobucket.com/albums/cc487/weedave1/Mobile%20Uploads/DB8E5398-00F2-4729-819D-9B43BD783840.jpg
Nexus Icon
PostPosted: 19:32 - 27 Jun 2014    Post subject: Reply with quote
That'll be fine. Trust me, I used to make radiator cores for a living, they're generally well over-specced so a little bit of damage like that shouldn't hurt.
The fins are there to increase the surface area of the tubes so as long as air can pass through the core it'll work ok whatever shape they've ended up.
Greetings from Shitsville!
gavbriggs
PostPosted: 20:52 - 27 Jun 2014    Post subject: Reply with quote
Spray it black and it will work better!
Recent bikes: Varadero 125 - Mod 2 3/2/14 - Bandit 1200 SK4
Dave M
PostPosted: 21:15 - 27 Jun 2014    Post subject: Reply with quote
Yes it's going black! Hope to fit it as soon as I can find a cover for it.
The last post was made 11 years, 206 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.29 - MySQL Queries: 13 - Page Size: 66.38 Kb
