BMW R1100S not starting
nitro1980
PostPosted: 10:51 - 28 Jun 2014    Post subject: BMW R1100S not starting Reply with quote
Hi my bike is not starting normally, you turn it on and hear the fuel pump charge but when I press the starter button you just hear a clunk.
It has a;
* new battery which I've checked is fully charged.
* new engine oil filter & oil.
* new spark plugs.
* new fuel filter.
* cleaned K&N air filter.
* & passed it's MOT 1 month before it stopped starting.
Bike: BMW R1100S
Yr: 1999
Mileage: 57,000
To get it going I can bump start the bike to get it going. Once going it does seem to idle a higher than normal. However the bike now seems to over-heat easily which I believe is connected to the high idle but not 100% sure.
I'm thinking this could be the starter motor or wires connecting to it, would this seem about right?
Any suggestions on why the idle is higher than normal or alternative suggestions on why it's over heating?
Thanks
Dave
Best rally of the year: Farmyard Party
Bikes: R1100S, ST1100, NT650V
davebike
PostPosted: 11:29 - 28 Jun 2014    Post subject: Reply with quote
Yet another BMW common fault The starter or pre engage uniit is gone
Don'tt piss aboout replace whole thing
Motorworks // motobins will supply non BmW part att resnoble price
Dave
Dave
NC750Xdct + others at work !
[email protected]
pdg
PostPosted: 14:37 - 28 Jun 2014    Post subject: Reply with quote
When you press the starter, is it actually a 'clunk' or is it more like a loudish 'click'?
You said it has a new battery, was the old battery getting very tired? Using a nearly duff battery can make the starter solenoid unhappy.
None of the other things you've listed would affect the operation of the starter, unless someone particularly hamfisted buggered something while changing those things...
For the high idle and overheating - is the oil level correct? How was the k&n filter cleaned and was it re-oiled afterwards? (k&n is a complete waste of time on the vast majority of BMWs by the way, there is no lack of flow on the OEM units but the k&n lets through more crap).
When the new oil filter was fitted, did it have any stickers etc. stuck to the outside of it and if so, were they removed?
Passing an MOT means the square root of fuck all when it comes to the operation of a bike - it's minimum roadworthy standard check, not a pre-sales and service inspection. In fact, passing an MOT doesn't mean much at all any time......
If you can't fix it and get fed up, I'll give you 50quid for the bike Wink
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
nitro1980
PostPosted: 14:25 - 01 Jul 2014    Post subject: Reply with quote
Thanks Dave, yes I have used Motorworks for many parts over the years and I'd say the bike is now 10% supplied by them, good set of guys there.
Hi pdg, yes I'd say more of a clunk than a click. Fitted a new battery as the bike had been previously SORN and I'd not kept up a charge on the battery so the old battery was goosed. Don't think I have hamfisted anything, but I'll soon know when I get time to strip it down.
Oil level is correct and the k&n was re-oiled, I've never had an issue with K&n and they save me re-buying a new filter everytime, it was not bought for any performance reasons.
Can't remember there being any stickers etc on the oil filter, was bought from Motorworks along with the oil, so I'm sure it's exactly what it should be.
Hmm, thanks very much for the offer but I'll have to refuse your generous offer of 50quid. Smile
temeluchus
PostPosted: 17:00 - 01 Jul 2014    Post subject: Reply with quote
Make sure it isn't over oiled, that can upset everything. The excess oil strangles the motor and also upsets the sensor in the exhausts. Whilst you are fault finding, i'd suggest getting a paper filter, to rule it out.
Check the connection to the exhaust and airbox sensors and look up resetting the throttle position sensor.
Time to get the starter off and have a look at the brushes etc.
nitro1980
PostPosted: 13:25 - 06 Aug 2014    Post subject: Reply with quote
Thanks all, although the oil was just at the max mark, I reduced this slightly and that seems to have solved the over heating issues, won't be so generous next time Smile
Still need to strip bits down, including the starter motor as it's not as efficient as it was and power supply to it seems ok, but will leave that for winter now.
Thanks again.
The last post was made 12 years, 52 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.44 - MySQL Queries: 13 - Page Size: 50.22 Kb
