ZZR600 lighting upgrade?
Wonko The Sane
PostPosted: 18:38 - 28 Jun 2014    Post subject: ZZR600 lighting upgrade? Reply with quote
I'm wanting to increase the amount of lighting compared with the standard set up on my ZZR600,
Would popping a higher rated bulb in be the easy way without needing to upgrade any thing else?
What are my other options?
Want to keep costs and modifications down
_mjs_
PostPosted: 18:47 - 28 Jun 2014    Post subject: Reply with quote
I stuck an Osram Nightbreaker in mine and that helped quite a bit Thumbs Up
_mjs_
PostPosted: 18:49 - 28 Jun 2014    Post subject: Reply with quote
P.S Set a good two hours aside to do it because changing the bulb on these is a nightmare... unless you have tiny hands don't even try using the acess panel, just pull the front fairing to bits!
Wonko The Sane
At risk of sounding dim, can you post a link or the spec I should be looking for?
Is it a specific motorbike one or..?
ta
_mjs_
PostPosted: 19:00 - 28 Jun 2014    Post subject: Reply with quote
It's a standard H4 60/55w like you'd find in most cars, think I paid about a tenner for one on ebay.
PostPosted: 21:00 - 28 Jun 2014    Post subject: Re: ZZR600 lighting upgrade? Reply with quote
There are the better output bulbs above which should be fine. But watch out for higher wattage bulbs. On a bike that new they are illegal (from memory, anything post 1985 they are illegal for), plus they draw more current (which can melt the wiring) and produce more heat (which can melt the headlight).
Wonko The Sane
PostPosted: 22:15 - 29 Jun 2014    Post subject: Reply with quote
So for the ZZR does it have to be H4 60/55w ?
What does the H4 part refer to, can it be a different H number?
I presume the 60 is the draw on full beam and the 55 the draw on regular?
stonesie
PostPosted: 22:25 - 29 Jun 2014    Post subject: Reply with quote
H4 is the bulb fitting, no other H number will fit and no other H number will give you both low and high beam in 1 bulb... And you do need 60/55...
https://www.ebay.co.uk/itm/1-X-H4-OSRAM-NIGHT-BREAKER-UNLIMITED-HEADLIGHT-BULBS-12v-60-55w-SINGLE-BLISTER-/121346301721?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c40cd9f19
Wonko The Sane
PostPosted: 08:26 - 30 Jun 2014    Post subject: Reply with quote
ta, makes sense now Smile
The last post was made 12 years, 2 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.43 - MySQL Queries: 13 - Page Size: 61.72 Kb
