I need a top box - Varadero 125cc.
SQL
PostPosted: 16:03 - 30 Jun 2014    Post subject: Reply with quote
52L TopBox,
or one of those pizza boxes made from estate agent signs
Hokum
PostPosted: 16:04 - 30 Jun 2014    Post subject: Re: I need a top box - Varadero 125cc. Reply with quote
BodyGuard wrote:
I need a top box
DON'T do it, top boxes look shit.
Sane: To know when you are doing something crazy.
Stephenniall
PostPosted: 16:16 - 30 Jun 2014    Post subject: Reply with quote
I use a topbox once every blue moon, and my last one broke. So I made one out of an old toolbox... It looks shite but it works well.
Something like this would be the cheapest solution, only about £35 off eBay.
https://i.ebayimg.com/00/s/NDc1WDQ3NQ==/z/jycAAOxyrx5TjvbE/$_1.JPG
Although I would go with a battered 2nd hand Givi box over a new cheap one anyday.
Itchy
PostPosted: 16:20 - 30 Jun 2014    Post subject: Reply with quote
I'm not sure a 52l will be enough for all that, my NTV had a top box, it was enough to fit my Belstaff summer jacket and helmet, or my trousers and jacket but not much more.
The armour inserts into jackets and trousers make them non bendy and foldy.
If you could roll your trousers and jacket it would fit but you can't and of course you can't roll a helmet or boots.
I think you should get an armour shirt and separate knee armour, and wear them under your normal gear so your normal gear can be rolled up and the armour pads be stuffed inside other things.
I don't wear bike specific boots now, I wear boots which you can double up as riding and work boots.
mudcow007
PostPosted: 16:23 - 30 Jun 2014    Post subject: Reply with quote
bin bag cable tied to your seat would be reet
fatjames
PostPosted: 16:30 - 30 Jun 2014    Post subject: Reply with quote
I have a 52l topbox and although it doesn't do the bikes looks much good, I couldn't care. I don't like wearing a rucksack and having filled pockets and 52l is about nig enough for my 1st lunch (2nd is always McD's)
52l will hold my lid and jacket, but there is no way I could gets boots or trousers in too.
Might be worth looking at Hood jeans and see if there any pants that you can wear on and off bike.
Itchy
PostPosted: 17:31 - 30 Jun 2014    Post subject: Reply with quote
Well its a Honda and they will have a helmet lock on the seat, they all do, or every one I've had will do.
Maybe some side paniers? I've got a pair of Nonfango side paniers which you will need to make a rack for though, but if you can weld its no problem to make one.
iooi
PostPosted: 17:50 - 30 Jun 2014    Post subject: Re: I need a top box - Varadero 125cc. Reply with quote
Rubbish.
A lot better and safer than riding with a rucksack on your back.
I have that box in the pic (48ltr version) is pretty good. Been on for 5 years now still as solid. Only difference is I bolt it to the rack and NOT use the quick release base.
Matt B
PostPosted: 17:57 - 30 Jun 2014    Post subject: Reply with quote
It wont. Like fatjames said - lid and jacket, gloves, snood will go in but not trousers as well. Boots maybe, depends on type.
ADSrox0r
PostPosted: 19:12 - 30 Jun 2014    Post subject: Reply with quote
I use a 36L Coocase and I can only get my lid, gloves, waterproofs and random topbox paraphernalia such as bungees/spare spark plug/WD40/butt plug/couple of microfiber cloths etc.
Couldn't give a fuck what anyone thinks it looks like, I ride every day all weather so I need practical. Next machine will have a 52L on, I'd go with hard luggage panniers too but they mean (useful) filtering is a no-no.
PostPosted: 20:26 - 30 Jun 2014    Post subject: Reply with quote
Go large. 56L Scootor topbox hold 2 helmet.
I linked to the cheapest one, although you could get a more expensive one as you'll doubtless claim that it never arrived anyway and get it refunded.
Cheapest solution would be to throat punch your new boss and move on to the next job-of-the-week though.
andyscooter
PostPosted: 21:07 - 30 Jun 2014    Post subject: Reply with quote
Get a burgman I get helmet gloves jacket and trousers under the seat as we have no wereat work to put it
andyscooter
PostPosted: 21:08 - 30 Jun 2014    Post subject: Reply with quote
Stephenniall
PostPosted: 22:18 - 30 Jun 2014    Post subject: Reply with quote
If you want more luggage than a topbox, get the Givi Pannier racks for the varadero from wemoto, they're around £100.
I was going to get some for mine, but they're too expensive!
A 52L topbox looks ridiculous on any bike, But for every day use would be your best option.
SQL
PostPosted: 22:22 - 30 Jun 2014    Post subject: Reply with quote
Gonna weld the sprockets on that too?
If you don't care about looks make one from wood supports sheet ally 0.9mm and rivets.
a 0.5m by 0.5m topbox would be relatively cheap to make, also can transfer to the Big Vara so you look even more of a GS wannabe.
PostPosted: 22:55 - 30 Jun 2014    Post subject: Reply with quote
I'm at 58L on the GS. I believe that at that size it begins to look structural, like the bike is an accessory of the box. Whistle
Dave70
PostPosted: 23:29 - 30 Jun 2014    Post subject: Reply with quote
I have done this, once. Although, instead of cable ties I used some old string and boot laces. Laughing
SQL
PostPosted: 23:49 - 30 Jun 2014    Post subject: Reply with quote
Regarding handling you may or may not have a speed weave you won't know until you try
PostPosted: 08:47 - 01 Jul 2014    Post subject: Reply with quote
It's narrower than your bars, and you have a bigger surface area. It might reduce your mpg slightly, but not that I've noticed on my GS.
I should note that I keep my anchor chain in a tail bag on the pillion seat though, not in the box.
It might look a little derp on the 125 Dearo, but since you'll be fully licensed up soon anyway and onto the litre version you'll be able to swap it over.
https://www.hardwaremx.com/forum/public/style_emoticons/default/poker.jpg
The last post was made 12 years, 40 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.16 - MySQL Queries: 13 - Page Size: 132.61 Kb
