Spray painting advice.
koolio
PostPosted: 11:09 - 01 Jul 2014    Post subject: Spray painting advice. Reply with quote
I'm going to be painting a tank by myself, read up a lot about which paints etc.
There are two things I'm still not clear about.
Do I have to sand down between primer, coats and the final clear coat. (I know I fine sand the clear coat).
Lastly is there a polishing compound I can use by hand to good effect?
I don't have a rotary polisher.
Crz
PostPosted: 11:58 - 01 Jul 2014    Post subject: Reply with quote
-Sand tank (use say, 400 grit) and wash it to remove dirt and sanding dust.
-Primer, I used about 3 coats and allowed it to dry for around 24 hours. Sanded extremely lightly with 800 grit (it doesn't take much) and be careful not to burn through. Remember to wash to remove the dust from sanding.
-Colour coat is then applied maybe between 3-5 coats and allow to dry for roughly 24 hours. leave 10-15 between coats. Do not sand this coat!
-Clear coat, I generally use 3 coats. I would leave it for about 1-2 weeks before sanding and polishing so the lacquer is fully cured.
-Sand very gently the whole wheel with 1500+ grit. Polish small sections at a time with the polish so you can easily manage what you have done and for gods sake don't lily foot when doing it you need to be quite firm.
I presume you know the basics of side to side, 1st coat being the lightest and getting progressively heavier. Thumbs Up
Theory: 8/7/13 Mod 1: 26/7/13 Mod 2: 21/8/13
"Life is like a garden, plant your seed in every hole you see"
koolio
PostPosted: 19:06 - 01 Jul 2014    Post subject: Reply with quote
Thanks I appreciate the input. I know about the first light coat etc. I usually start spraying before I get to the object and try and make it as light as possible at first.
clancy
PostPosted: 19:16 - 01 Jul 2014    Post subject: Reply with quote
You only need to sand between primer and paint layers if there is any marks or uneven paint etc
Biggest thing is if you are going to sand and polish the clear coat make sure it's fully cured, needs a good 10 days or so
KLX 300r
PostPosted: 20:11 - 01 Jul 2014    Post subject: Reply with quote
I'll give you my best advice, based on years of experience, hours of frustrating hard work and loads of money spent:
Pay someone to do it!
PostPosted: 20:12 - 01 Jul 2014    Post subject: Reply with quote
Can of Dulux, paintbrush Smile
https://www.bikechatforums.com/viewtopic.php?p=2479715
BTTD
PostPosted: 20:28 - 01 Jul 2014    Post subject: Reply with quote
What paint are you using? And is it fully petrol resistant? Wink
koolio
PostPosted: 21:31 - 01 Jul 2014    Post subject: Reply with quote
Actually I'm using VHT engine enamel, I will oven cure between the primer, main coat and gloss or maybe once its all gone on, this makes it fuel resistant, have seen some fairly good finishes doing this. Reading a lot about how to do it, have painted parts before but want this to be a good job.
I'm after an old enamel painted look so any slight imperfections are actually welcome.
I am terrible with brush!
gavcarter
PostPosted: 21:34 - 01 Jul 2014    Post subject: Reply with quote
Petrol tank in oven? Are you sure now.....
Shaft
PostPosted: 23:04 - 01 Jul 2014    Post subject: Reply with quote
Nothing wrong with that, so long as it's been properly purged.
koolio
PostPosted: 06:52 - 02 Jul 2014    Post subject: Reply with quote
Precisely
The last post was made 11 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 68.74 Kb
