| koolio |
 koolio Spanner Monkey
| Crz |
 Crz Two Stroke Sniffer
 Posted: 11:58 - 01 Jul 2014 Post subject: |
-Sand tank (use say, 400 grit) and wash it to remove dirt and sanding dust.
-Primer, I used about 3 coats and allowed it to dry for around 24 hours. Sanded extremely lightly with 800 grit (it doesn't take much) and be careful not to burn through. Remember to wash to remove the dust from sanding.
-Colour coat is then applied maybe between 3-5 coats and allow to dry for roughly 24 hours. leave 10-15 between coats. Do not sand this coat!
-Clear coat, I generally use 3 coats. I would leave it for about 1-2 weeks before sanding and polishing so the lacquer is fully cured.
-Sand very gently the whole wheel with 1500+ grit. Polish small sections at a time with the polish so you can easily manage what you have done and for gods sake don't lily foot when doing it you need to be quite firm.
I presume you know the basics of side to side, 1st coat being the lightest and getting progressively heavier.  ____________________ Theory: 8/7/13 Mod 1: 26/7/13 Mod 2: 21/8/13
"Life is like a garden, plant your seed in every hole you see" |
| koolio |
| clancy |
 clancy World Chat Champion
 Posted: 20:11 - 01 Jul 2014 Post subject: |
I'll give you my best advice, based on years of experience, hours of frustrating hard work and loads of money spent:
Pay someone to do it! ____________________ a.k.a 'Geri'
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 20:12 - 01 Jul 2014 Post subject: |
Can of Dulux, paintbrush
https://www.bikechatforums.com/viewtopic.php?p=2479715 ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| BTTD |
 BTTD World Chat Champion
 Posted: 20:28 - 01 Jul 2014 Post subject: |
What paint are you using? And is it fully petrol resistant?  |
| koolio |
| gavcarter |
 gavcarter Could Be A Chat Bot
| Shaft |
 Shaft World Chat Champion
| koolio |
The last post was made 11 years, 247 days ago. Instead of replying here, would creating a new thread be more useful? |
