heat shrink fuel hose
wertyu
PostPosted: 12:17 - 09 Jul 2014    Post subject: heat shrink fuel hose Reply with quote
Any one know of ?, where to buy fuel hose that can be shrank to fit fit
tightly to carb .
ive seen it before but cant find any to buy
PostPosted: 12:42 - 09 Jul 2014    Post subject: Reply with quote
Buy the correct size fuel hose or use a cable tie.
map
Mr Calendar
PostPosted: 15:33 - 09 Jul 2014    Post subject: Reply with quote
Do the words "hose clip" ring any bells?
Here's a google hint Thumbs Up
Mudshark
PostPosted: 16:13 - 09 Jul 2014    Post subject: Reply with quote
dunno about applications with fuel hose but elsewhere I use clear plastic tubing same (or slightly smaller) internal diameter as the outer diameter od the tube it's going on to and usually you need to heat the plastic tube to soften it so it goes over the other tube then when it's cooled it's pretty tight, I'd still use a hose clip / jubilee clip though with petrol
R1250RS
XT660X
PostPosted: 21:59 - 09 Jul 2014    Post subject: Re: heat shrink fuel hose Reply with quote
tightly to carb .
Fuel hose is thick walled.
Heat shrink is thin.
I wouldn't want to use anything that I could shrink to fit.
stonesie
PostPosted: 23:02 - 09 Jul 2014    Post subject: Reply with quote
Heat shrink is for electrical connections or holding wires together, Petrol would probably eat through it in short order.
Get properly sized fuel tube and the appropriate clips, a jubilee type hose clip will work as a last resort but is not ideal.
wertyu
PostPosted: 11:45 - 10 Jul 2014    Post subject: Reply with quote
yeah tried clips clamps , its very high pressure application .
heres a photo of similar .
or best i could find anyway .
[CENTER]https://media.use.com/images/s_2/7c16a812d5461265d787.jpg
https://www.use.com/images/clicklarge3.gif[/CENTER]
grant965
PostPosted: 12:10 - 10 Jul 2014    Post subject: Reply with quote
im not saying its heat shrink but its tight stuff , heres a photo of original .
or best i could do anyway .
Thats just a standard fuel line for fuel injected bikes, well at least 125s
To get it on, dip the end in boiling water to soften it up then push it on, If hot enough it just slides on near enough then goes back to being hard
Ex bikes: 05 Suzuki En 125, '98 Yamaha Thundercat, '08 Honda cbr125, '05 Kawasaki z750, '03 Triumph Daytona 600, '91 Kawasaki ex250, '03 Hyosung Comet 125
Current Bike: '02 Suzuki TL1000R
wertyu
PostPosted: 12:18 - 10 Jul 2014    Post subject: Reply with quote
thanks , any idea where it can be bought from by the metre ?
or a product name .
grant965
PostPosted: 12:39 - 10 Jul 2014    Post subject: Reply with quote
Ebay will do it or any automotive supplier, I know for a 125 its usually just called 6mm ID fuel line, so measure the Inner Diameter of your hose and ebay it or take to a shop
Mudshark
PostPosted: 13:47 - 10 Jul 2014    Post subject: Reply with quote
https://www.demon-tweeks.co.uk/performance/fuel-hose/fse-high-pressure-fuel-injection-hose
R1250RS
XT660X
wertyu
PostPosted: 18:11 - 10 Jul 2014    Post subject: Reply with quote
Mudshark wrote:
thanks for you help mud , ive tried all that if you see my photo above , this line is heat shrank to fittings ( shrank to fit anyway )
all clips tried have failed ( leak high pressure fuel ) and look a mess anyway .
i need OEM finish , think ill phone up Manufact tomoz .
thanks anyway !!
https://media.use.com/images/s_1/88dc1330333a86179bc4_1.jpg https://media.use.com/images/s_1/88dc1330333a86179bc4_2.jpg https://media.use.com/images/s_1/88dc1330333a86179bc4_3.jpg https://media.use.com/images/s_1/88dc1330333a86179bc4_4.jpg
Mudshark
PostPosted: 18:44 - 10 Jul 2014    Post subject: Reply with quote
thanks anyway !!
jeez, next best I could see was this sort of stuff "adhesive lined heat shrinkable" fuel resistant
https://www.cablejoints.co.uk/sub-product-details/heat-shrink-3m-canusa-hellermann-tyton/heat-shrink-tubing-elastomer-diesel-resistant
the manufacturers catalogues at that link are facinating Shocked
R1250RS
XT660X
MaybeGuy
PostPosted: 19:21 - 10 Jul 2014    Post subject: Reply with quote
Why does it have to be flexible hoses for a fuel pump?
Might take a bit of effort to do, but why not just use steel piping and compression fittings?
kramdra
PostPosted: 00:21 - 11 Jul 2014    Post subject: Reply with quote
Why do you have two fuel pumps in parallel? This cant be the standard fitting? Shocked
The last post was made 12 years, 82 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 97.04 Kb
