So I passed my cbt and went home to ride then.........
Tnias
PostPosted: 21:23 - 12 Jul 2014    Post subject: So I passed my cbt and went home to ride then......... Reply with quote
Before I start I have a gz125 suzuki marauder.
Was riding about for a couple of hours fine, went to my friends, we noticed fuel was leaking from under the carb. There was no hose connected to it or anything, is there supposed to be? Cos one was sitting loose that was connected to the top of the carb. Bike won't start now but engine still turns over, any ideas anybody
EazyDuz
PostPosted: 21:24 - 12 Jul 2014    Post subject: Reply with quote
Post a pic
Tnias
PostPosted: 21:27 - 12 Jul 2014    Post subject: Reply with quote
Left bike at my mates for now he will take a pic when he's home from dropping me off and I'll stick it on bud
Tnias
PostPosted: 22:07 - 12 Jul 2014    Post subject: Reply with quote
so the hose i have attached underneath wasnt actually plugged into where it is now, was just sitting loose (only plugged into the top). So not sure how its meant to look ? fuel was leaking from where i plugged the hose into under the carb.
https://i.imgur.com/jQ4gTQe.jpg
https://i.imgur.com/ml2eHRh.jpg
https://i.imgur.com/0Mo3iKb.jpg
Shaft
PostPosted: 22:19 - 12 Jul 2014    Post subject: Reply with quote
If you mean the red pipe, it's currently plugged onto the carb overflow and is doing what it should be doing, venting excess fuel to a point where it drips on the ground, usually just under the swing arm pivot point.
The carb is overflowing because the needle valve is stuck, so the fuel doesn't stop flowing when the float bowl is full.
Try tapping the float bowl with a light hammer/screwdriver handle (you aren't trying to smash it to pieces, just unstick a little valve) and see if it stops.
Tnias
PostPosted: 22:26 - 12 Jul 2014    Post subject: Reply with quote
ah OK, will try that tomorrow, so I should leave that pipe where i have it now and try what you said or unplug that pipe form underneath and put it loose where it was ? excuse the severe lack of knowledge just trying to learn as I go.
thanks for the reply
gavcarter
PostPosted: 22:28 - 12 Jul 2014    Post subject: Reply with quote
I have had MILD success doing the following:
Turn petrol tap off ( if has one)
Opening drain screw on carb, will be right above the red pipe
Push a tin of carb cleaner quite hard against the red pipe and back-fill the carb, so the float bowl is filled with cleaner, it will all drain back out when you take the can off the red pipe.
Wont work if you dont get enough inside the carb so try and keep the pipe higher than the bottom of the carb.
It is just a quick fix, and you may end up having to clean it out properly, but its always worth a little punt, it can save you about an hour if it works Thumbs Up
Shaft
Leave it where it is, it's meant to stop you getting a big puddle of petrol on top of your gearbox.
gavcarter
PostPosted: 22:29 - 12 Jul 2014    Post subject: Reply with quote
Leave where is, just make sure the other end is NOT pointing at back wheel or at anything that gets hot ( just bear in mind that petrol comes out of it when theres a problem )
Tnias
PostPosted: 22:30 - 12 Jul 2014    Post subject: Reply with quote
yeah that seems to make sense heh Razz
thanks again will post back when me and my mate have a look again tomorrow
Tnias
PostPosted: 22:31 - 12 Jul 2014    Post subject: Reply with quote
well, the other end of it is plugged into the top of the carb, like you can see in the pic above, is that maybe not meant to be plugged in there ?
Shaft
PostPosted: 22:36 - 12 Jul 2014    Post subject: Reply with quote
OK, so it's some form of recirculation system, so that excess fuel gets dumped back into the top of the throttle body.
Still leave it where it is.
gavcarter
PostPosted: 22:45 - 12 Jul 2014    Post subject: Reply with quote
The other end has gone brown? I thought it was two separate pipes. Embarassed
In that case double check there is a pipe connected to the fuel tap, and that you actually have some petrol left in the tank......
If there is no pipe on the fuel tap, then take the pipe off the BOTTOM of the carb and connect it to fuel tap, leave the middle bit where it is...
Apologies for earlier posts ( ignore them) , I thought we were looking at two separate pipes, not one that has been looped back round out of sight Rolling Eyes
Tnias
PostPosted: 22:50 - 12 Jul 2014    Post subject: Reply with quote
There is definitely a pipe from the fuel tank and definitely fuel in the tank, that's all connected fine. Yeah the brown end was always plugged in where it is but the other end was sitting loose under the seat somewhere. Then fuel started dripping out of where that end is now plugged into (underneath)
Shaft
PostPosted: 22:55 - 12 Jul 2014    Post subject: Reply with quote
Before you passed your CBT, had the bike been standing unused for a while?
Tnias
PostPosted: 22:58 - 12 Jul 2014    Post subject: Reply with quote
Yeah it had been left out in all weather, got quite rusted etc, but was running fine. Needed the front brake caliper replaced, done that and sorted out the rust. Bike ran fine when I got it, or so it seemed. I did get it cheap heh
Tnias
PostPosted: 23:03 - 12 Jul 2014    Post subject: Reply with quote
Forgot we discovered something else, not sure if it's related to the same leaking fuel thing. But when it didn't start we checked the spark plug and it was wet when we pulled it out, cleaned it up but still no joy.
Shaft
PostPosted: 23:15 - 12 Jul 2014    Post subject: Reply with quote
Most likely, it had some rust in the tank, using it has sloshed the fuel around and dislodged a few particles, one of which has found it's way past the filter and got stuck under the float valve. Put in an inline filter, between the tank and the throttle body, it should help.
As for it not starting, it's either fuel flooding (the overflow problem suggests this) or I notice lots of water droplets around the place; if you've been riding in the rain, the ignition circuit could be wet and you've got no spark, hence wet plug.
Tnias
PostPosted: 23:20 - 12 Jul 2014    Post subject: Reply with quote
Yeah I'm afraid living in Scotland makes riding in the rain a regular occurrance heh.
Thanks alot both of you for all the advice we will have a good look at it tomorrow (hopefully the weather will be better)
Shaft
PostPosted: 23:31 - 12 Jul 2014    Post subject: Reply with quote
Do a standard spark test; take the plug out, shove it back in the plug cap, then earth the thread against the cylinder fins (hold the plug lead, not the spark plug!)
Press the start button and if you get a nice fat blue spark across the plug electrodes, the ignition is all good and it's overfuelling.
Tnias
PostPosted: 08:28 - 13 Jul 2014    Post subject: Reply with quote
ok will try that too, whwn we took the plug out and held the elad last night there was no visible spark but fuel flew out of where it was plugged into, im guessing thats normal cos thats where it ignites ?
EDIT: sigh.. mate just checked on the bike as its parked at his and said its been leaking petrol all night from elsewhere now... christ knows what's happening. seems since its had a good ride its just falling apart. Leaking from air filter.
Ariel Badger
PostPosted: 11:33 - 13 Jul 2014    Post subject: Reply with quote
Your carb needs stripping and cleaning. Your cylinder is full of fuel, it should not squirt out of the plug hole. If your cylinder is full of fuel it will have got past the rings and contaminated the oil and that will need changing.
Tnias
PostPosted: 11:36 - 13 Jul 2014    Post subject: Reply with quote
right, think I am in way over my head heh.
Thanks for the reply ill see what I can do. Thumbs Up
Lord Percy
PostPosted: 12:03 - 13 Jul 2014    Post subject: Reply with quote
This may help:
Assembly diagram of your carburettor:
The floats are number 15.
https://images.cmsnl.com/img/partslists/suzuki-gz125-2000-uy-carburetor_bigsue0360fig9_75ca.gif
Tnias
PostPosted: 12:04 - 13 Jul 2014    Post subject: Reply with quote
nice! thank you Smile
The last post was made 11 years, 197 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 128.24 Kb
