| Tnias |
 Tnias Two Stroke Sniffer
| EazyDuz |
 EazyDuz World Chat Champion
| Tnias |
| Tnias |
| Shaft |
 Shaft World Chat Champion
 Posted: 22:19 - 12 Jul 2014 Post subject: |
If you mean the red pipe, it's currently plugged onto the carb overflow and is doing what it should be doing, venting excess fuel to a point where it drips on the ground, usually just under the swing arm pivot point.
The carb is overflowing because the needle valve is stuck, so the fuel doesn't stop flowing when the float bowl is full.
Try tapping the float bowl with a light hammer/screwdriver handle (you aren't trying to smash it to pieces, just unstick a little valve) and see if it stops. ____________________ Things get better with age; I'm close to being magnificent........
WooHoo, I'm a Man Point Millionaire! https://www.bikechatforums.com/viewtopic.php?t=234035 |
| Tnias |
| gavcarter |
 gavcarter Could Be A Chat Bot
 Posted: 22:28 - 12 Jul 2014 Post subject: |
I have had MILD success doing the following:
Turn petrol tap off ( if has one)
Opening drain screw on carb, will be right above the red pipe
Push a tin of carb cleaner quite hard against the red pipe and back-fill the carb, so the float bowl is filled with cleaner, it will all drain back out when you take the can off the red pipe.
Wont work if you dont get enough inside the carb so try and keep the pipe higher than the bottom of the carb.
It is just a quick fix, and you may end up having to clean it out properly, but its always worth a little punt, it can save you about an hour if it works  |
| Shaft |
Leave it where it is, it's meant to stop you getting a big puddle of petrol on top of your gearbox. ____________________ Things get better with age; I'm close to being magnificent........
| gavcarter |
| Tnias |
 Posted: 22:30 - 12 Jul 2014 Post subject: |
yeah that seems to make sense heh
thanks again will post back when me and my mate have a look again tomorrow |
| Tnias |
| Shaft |
| gavcarter |
 Posted: 22:45 - 12 Jul 2014 Post subject: |
The other end has gone brown? I thought it was two separate pipes.
In that case double check there is a pipe connected to the fuel tap, and that you actually have some petrol left in the tank......
If there is no pipe on the fuel tap, then take the pipe off the BOTTOM of the carb and connect it to fuel tap, leave the middle bit where it is...
Apologies for earlier posts ( ignore them) , I thought we were looking at two separate pipes, not one that has been looped back round out of sight  |
| Tnias |
| Shaft |
 Posted: 22:55 - 12 Jul 2014 Post subject: |
Before you passed your CBT, had the bike been standing unused for a while? ____________________ Things get better with age; I'm close to being magnificent........
| Tnias |
| Tnias |
| Shaft |
 Posted: 23:15 - 12 Jul 2014 Post subject: |
| Tnias wrote: | Yeah it had been left out in all weather, got quite rusted etc, but was running fine. Needed the front brake caliper replaced, done that and sorted out the rust. Bike ran fine when I got it, or so it seemed. I did get it cheap heh |
Most likely, it had some rust in the tank, using it has sloshed the fuel around and dislodged a few particles, one of which has found it's way past the filter and got stuck under the float valve. Put in an inline filter, between the tank and the throttle body, it should help.
As for it not starting, it's either fuel flooding (the overflow problem suggests this) or I notice lots of water droplets around the place; if you've been riding in the rain, the ignition circuit could be wet and you've got no spark, hence wet plug. ____________________ Things get better with age; I'm close to being magnificent........
| Tnias |
| Shaft |
 Posted: 23:31 - 12 Jul 2014 Post subject: |
Do a standard spark test; take the plug out, shove it back in the plug cap, then earth the thread against the cylinder fins (hold the plug lead, not the spark plug!)
Press the start button and if you get a nice fat blue spark across the plug electrodes, the ignition is all good and it's overfuelling. ____________________ Things get better with age; I'm close to being magnificent........
| Tnias |
| Ariel Badger |
 Ariel Badger Super Spammer
| Tnias |
 Posted: 11:36 - 13 Jul 2014 Post subject: |
right, think I am in way over my head heh.
Thanks for the reply ill see what I can do.  |
| Lord Percy |
 Lord Percy World Chat Champion
| Tnias |
 Posted: 12:04 - 13 Jul 2014 Post subject: |
nice! thank you  |
The last post was made 11 years, 196 days ago. Instead of replying here, would creating a new thread be more useful? |
