| bikertomm |
 bikertomm World Chat Champion
 Posted: 21:59 - 12 Jul 2014 Post subject: De-restricting a Honda Hornet CB600 2007? |
Hi all,
I have a Honda Hornet 07' that has been restricted since I bought it to 33BHP.
Soon enough, I will legally be able to take this off. Been waiting for this day for 5 years now...
All I really know is that It's a throttle stop restriction - I have limited movement on the throttle - Is that literally it?
I wanted to find out some more info, if anyone has ever come across taking one off before on a Hornet?
So far what I've found is that the tank needs to come off and I quote;
'you need to lift tank, disconnect the throttle cables and unscrew the metal plate then take it off and put the cables back on. Bit of a ball ache as space is tight.'
A plate on the side of a throttle body.
I think this may well be too much for myself (Jivebunny skillz yo) but if I can at least get an idea I can take it to someone and provide some insight!
Unless anyone capable wants some money?
Cheers lads.  ____________________ 07' Honda Hornet now full powaah! My guide on performing an oil change! |
| gavbriggs |
 gavbriggs Crazy Courier
| bikertomm |
| Shaft |
 Shaft World Chat Champion
 Posted: 23:05 - 12 Jul 2014 Post subject: |
It's probably not that difficult, the hard part (as mentioned) will be access, because it's going to be fiddly little nuts, buried somewhere that's just out of reach, probably hard up against some other component so it only comes out a certain way.
Take the tank off, get a good torch and post some quality pictures, I bet you can be talked through it. ____________________ Things get better with age; I'm close to being magnificent........
| gavcarter |
 gavcarter Could Be A Chat Bot
 Posted: 23:38 - 12 Jul 2014 Post subject: |
Tank off, then air box off.
Remove the carb / throttle body from the rubbers ( leave the rubbers on the engine)
You should see big washers similar to these
https://i14.photobucket.com/albums/a324/david_m213/zzrrestriction.jpg
Yank em out.......
Not literally you'll damage the rubbers, probably have to undo the rubbers from engine and take them out of then put rubbers back
After having a good google at new kits for the 07 hornet - i do not believe the jetting is changed when fitted so that should be job done.
Carb back, air box back on, tank back on - new undies first time you forget and "launch" off the lights  |
| Ste |
 Ste Not Work Safe
 Posted: 23:44 - 12 Jul 2014 Post subject: |
Those washer aren't throttle stops.
The throttle stop that was on my 33bhp TL1000R was a part that was changed so the original part was needed for derestricting it.
Do you know if it's an FI International kit or something else? If it's FI International then you might be able to find the fitting instructions somewhere online. The place I got mine fitted gave me the standard part back and the fitting instructions. |
| Shaft |
OP thinks it's a throttle stop restriction, not constrictor washers. ____________________ Things get better with age; I'm close to being magnificent........
| gavcarter |
| P.addy |
 P.addy Red Rocket
 Posted: 00:34 - 13 Jul 2014 Post subject: |
Have fun. That Hornet is a cunt stick to work on.  |
| Shaft |
 Posted: 00:43 - 13 Jul 2014 Post subject: |
How hard can it be  ____________________ Things get better with age; I'm close to being magnificent........
| P.addy |
 P.addy Red Rocket
| Shaft |
 Posted: 01:01 - 13 Jul 2014 Post subject: |
Sounds like a typical modern bike to me.
I'd have a go at fixing the OP's Hornet, but only if he brings it to me, so I've got every tool available. ____________________ Things get better with age; I'm close to being magnificent........
| TUG |
 TUG World Chat Champion
| bikertomm |
 Posted: 10:17 - 13 Jul 2014 Post subject: |
Ste, yes it is an FI international one, I have the certificate etc from the previous owner.
I tried Emailing FI international but not a response. Don't think they are interested unless they are making money..
Thanks for inspiring confidence Paddy
And thanks for the offer Shaft.
I spoke to a local mechanic and he seemed to know the deal, he reckoned a couple hours labour and around £100.
We shall see, keep the tips coming!!
Cheers  ____________________ 07' Honda Hornet now full powaah! My guide on performing an oil change! |
| talkToTheHat |
| Ste |
 Ste Not Work Safe
 Posted: 01:36 - 16 Jul 2014 Post subject: |
| bladerunner |
| Conzar |
 Conzar World Chat Champion
| Conzar |
| P.addy |
 P.addy Red Rocket
| Ste |
 Ste Not Work Safe
| talkToTheHat |
| TUG |
| Vincent |
 Vincent Banned
 Posted: 19:41 - 20 Jul 2014 Post subject: |
FI International certainly took first place in ripping off customers. IIRC they were charging something like £120 for £5 worth of components and a piece of paper  ____________________ Space Is Deep |
| bikertomm |
 Posted: 23:58 - 23 Jul 2014 Post subject: |
FFS Paddy I bet this turns out you are right and there will be plenty of effin' and blinding on the day.
Will try to make sure I get a price before hand, incase it turns into a 4+ hour jobby..
2 and a bit months
Will update this  ____________________ 07' Honda Hornet now full powaah! My guide on performing an oil change! |
The last post was made 11 years, 262 days ago. Instead of replying here, would creating a new thread be more useful? |
