Toolkit on a tight budget advice?
FlightRisk
PostPosted: 17:11 - 13 Jul 2014    Post subject: Toolkit on a tight budget advice? Reply with quote
So I've realised how little I know about mechanic-ing tools, but I know a little more than I did 2 days ago. Now I know there are 6 and 12 pointed sockets and wall-drive (which is pretty cool).
I already have screwdrivers and hex keys & bits and pliers - small stuff like that.
My spannering ambitions are this type of thing to begin with:
remove rear wheel to go get tyre
remove exhaust to paint
adjust head bearing
fork seals
bleed brakes
clean carbs
I saw the Halfords sets on sale ( Shocked I can haz ALL THE TOOLZ!? Mr. Green ) but on closer inspection whatever I was looking at had loads of imperial stuff I don't need.
I'd rather keep things minimal and have some nicer quality stuff than loads of stuff I won't use. I did pick up this RAC branded spanner set (https://www.argos.co.uk/static/Product/partNumber/7004250.htm) for £13 but I don't know... Has good reviews and says it's chrome vanadium but it doesn't feel like real steel, I'm nearly scared to use it!
I don't know whether I should be spending money on spanners or sockets, or which sizes to go for, or if I should be looking for a set with deep sockets?
I guess ratchet spanners are more of a luxury thing, like if you'd be using them all the time?
Can you get combination spanners with the 6 points on the ring end?
Wonko The Sane
PostPosted: 18:48 - 13 Jul 2014    Post subject: Reply with quote
I have a socket set bought for me by my parents a while ago so I don't know the cost.
The set comprises large and small ratchet handle, screwdriver handle and a spark plug socket or two.
sizes 4mm through 30mm (probably won't need the large end of those!
small, med, large allen key, cross head, flat head and torx screwdriver bits.
This along with a decent size adjustable wrench and a pair of long nosed pliers has served me well thus far.
Helps for me that Kawasaki deliberately use different sized heads on bolts so that a 17mm is needed one end and a 15mm the other, kind of handy.
I do have some ratchet spanners which are handy for spaces you can't get a socket into - mine are halfrauds ones.
A torque wrench may come in handy from time to time (I'm just finding this out myself)
You may need additional tools for the fork seals
Places like machine mart, screwfix etc may be cheaper for tools than halfrauds but of similar quality.
gavcarter
PostPosted: 18:49 - 13 Jul 2014    Post subject: Re: Toolkit on a tight budget advice? Reply with quote
adjust head bearing
fork seals
bleed brakes
clean carbs
They are called wall-drive spanners, imperial stuff will more than likely wasted money and space, money on sockets, spanners and DECENT screwdrivers, cheap screwdrivers will start to round screws off very quickly. A punch set, feeler gauges, and a manual impact driver should see you set for most jobs
PostPosted: 19:11 - 13 Jul 2014    Post subject: Reply with quote
A 13 quid RAC branded set from Argos is not going to be good quality because 1. Argos stuff is over-priced tat and 2. If it's RAC branded they will be paying a cut to them for the endorsement.
You don't need new tools, how about visiting a few boot fairs or asking around the family?
Sload
PostPosted: 19:17 - 13 Jul 2014    Post subject: Reply with quote
Buy it as you need it then Thumbs Up
Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx
Hugh Farking Cant
PostPosted: 19:29 - 13 Jul 2014    Post subject: Re: Toolkit on a tight budget advice? Reply with quote
I think you are getting wall drive and hex mixed up.
https://i1159.photobucket.com/albums/p626/willandrip/265V8NOTE291wheelnut_zps7ae99e34.jpg
Some manufacturers also refer to them as flank drive depending on the configuration.
Hex spanners are usually reserved for manufacturers tool kits and used on wheel spindles etc.
https://i1159.photobucket.com/albums/p626/willandrip/_57_zps43dceb6a.jpg
I assume sets will be available but will be numb as fuck to use in everyday situations.
Normal sockets/spanners are usually referred to as bi/hex.
Remember; Someone on here always has a blacker cat.
bugeye_bob
PostPosted: 19:39 - 13 Jul 2014    Post subject: Reply with quote
https://www.halfords.com/motoring/garage-equipment/socket-sets/halfords-advanced-professional-36-piece-socket-set-1-4
These are brilliant for the bike, I have a couple now,
I also carry the bikes OE kit,
These socket sets pop up at £19.99 from time to time,
Its also compact enough to fit under the seat so you arent caught out.
hth
And have a life time warrenty
Sload
PostPosted: 19:51 - 13 Jul 2014    Post subject: Reply with quote
hth
Very good little set, missing a few of my adaptor bits and I broke the hinges but still going strong. Currently use it at work.
DrSnoosnoo
PostPosted: 20:56 - 13 Jul 2014    Post subject: Reply with quote
I bought a set from ARGOS. £40 for a set of every socket you'll need and Allen heads, torx heads etc. Really good
Using this set (and some torque wrenches from ALDI and machine mart) I've had me wheels off, calipers off, replaced my rear shock and done my valve clearances. the 1/2" ratchet has started to play up but 2 years and that being the only problem. .. worth it!
The next set I will get will be the huuuge halfords set though.
groovylee
PostPosted: 21:04 - 13 Jul 2014    Post subject: Reply with quote
I know I'm going to be going against the grain a little here, but you don't need awesome tools.
as long as you don't expect tools from poundland to cause you anything but grief, you'll be fine. Christ, I've done cylinder head exchanges with tools that some of the snapon fanbois wouldn't shit on, but they worked, and didn't fuck anything.
get the most comprehensive stuff you can afford, and as you save yourself money by doing things yourself, upgrade. Thumbs Up
and before anyone thinks I'm some sort of uninformed cretin - this is the opinion of a marine engineer of 16 years experience Thumbs Up
good effort for giving it a go yourself OP, just don't get too bogged down in the expensive details (but don't go buying poundland shite either Laughing )
Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R
clancy
PostPosted: 21:33 - 13 Jul 2014    Post subject: Reply with quote
Halfords tools are pretty crap and their sets have loads of stuff you never use
Go to a machine mart. Far better quality, far cheaper too. You can mix and match and just get what you need
I recently got a low profile trolley jack, new torque wrench, set of long spline bits and 700mm breaker bar for about £80 when they had a vat free weekend. So you could easily build a decent basic toolkit of just stuff you need for cheap
KLX 300r
Wonko The Sane
PostPosted: 21:55 - 13 Jul 2014    Post subject: Reply with quote
halfords profesional range is up to the job, but carries a price tag.
I've yet to break any tool I've bought from Aldi, I'm half way through a house renovation that has killed dewalt, bosch and black&decker drills but not my aldi one!
Don't underestimate or rule out aldi tools.
Lone-Wolf
PostPosted: 22:48 - 13 Jul 2014    Post subject: Reply with quote
Wotcha.
Many moons ago I bought a socket set. It cost me just over three and a half week's wages. I still have it. OK, the ratchet and one socket got lost when they fell from my pocket ( lesson to be learned here ) on the way to the local garage. One socket got worn out - the 5/16 Whitworth - but the rest are fine and I still use 'em to this day.
Tl;dr. Buy good and buy once.
Cheers.
L.W. - www.moonshiners.org.uk
wr6133
PostPosted: 01:06 - 14 Jul 2014    Post subject: Reply with quote
Halfords professional, they regularly have huge sales on them online. I got mine with 66% off! Yeah there's a bit of imperial stuff there but at that price and with a lifetime guarantee that means if anything breaks I can walk in to my local halfrauds and swap it I think it's money well spent.
FlightRisk
PostPosted: 01:08 - 14 Jul 2014    Post subject: Reply with quote
I wouldn't hesitate to check out Aldi or Lidl if they had anything in. That's the problem, never when you need it...
I nearly bought the Argos set but they were out of stock. No Machine Mart where I live.
What's a punch set useful for?
bugeye_bob wrote:
I was looking at that kit alright, but since I already have most of those little hex drive bits I was wondering if this might be a better bet for the same money: https://www.halfords.com/motoring/garage-equipment/socket-sets/halfords-advanced-professional-27-piece-metric-socket-set-1-4, it has a handful of deep drive sockets instead.
Will I need those?
Or this 3/8 drive set which goes a little higher in sizes: https://www.halfords.com/motoring/garage-equipment/socket-sets/halfords-advanced-professional-28-piece-metric-socket-set-3-8
Will one of these deep drive sockets do spark plugs or do I need a special one for that?
Also was checking out Bahco sets like this one which has a mix of 1/4 and 3/8 drive: https://www.amazon.co.uk/Bahco-Socket-Piece-Square-Drive/dp/B0001JZRYY/ref=sr_1_3?ie=UTF8&qid=1405298584&sr=8-3&keywords=bahco+socket+set
Not much change out of £50 for a few Bahco spanners! Bet they're lovely though, I had some Bahco wood chisels that hold an edge like nothing I've ever known.
Going in a totally other direction, just how cheesy do you think this Phaze 50 piece set would be?
Just occurred to me neither of these will get the rear wheel off. Maybe just one big spanner for that. Does that really need a torque wrench or just 'Tight lad, TIGHT!' ? Laughing
groovylee
PostPosted: 05:12 - 14 Jul 2014    Post subject: Reply with quote
I got given the first 1/4 inch set for Xmas by my in laws. Absolutely brilliant little set for the money Thumbs Up I use it pretty much daily and it hasn't failed me yet. And the deep sockets are a bonus too.
FlightRisk
PostPosted: 21:11 - 15 Jul 2014    Post subject: Reply with quote
OK, I've just about decided on this Draper Expert 3/8 set as a nice mix of price vs quality & useful sizes (6-24mm).
One question though; my rear axle nut is 24mm, is a 3/8 drive up surviving the level of torque needed for a rear axle?
Haynes manual says 90 Nm.
smegballs
PostPosted: 22:04 - 15 Jul 2014    Post subject: Reply with quote
+1 for old, quality tools
A local house-clearancey type of store sold me a big handful of Britool and Gedore spanners last year for 3 quid.
I'd much rather work with some old british/yank/german tools that buy new shit.
qarka
PostPosted: 22:11 - 15 Jul 2014    Post subject: Reply with quote
Fork seals... to get the bushings and seals in you need a seal driver. Don't buy one though, you can make one with a few bits of PVC pipe and two jubilee clips. As per https://www.youtube.com/watch?v=vrmYJgcGX30
Used this method to do my fork seals a few days ago, worked a treat! Thumbs Up
clancy
PostPosted: 22:22 - 15 Jul 2014    Post subject: Reply with quote
Don't really agree, broke two of their ratchets, one on the day I got it. Also their toolkits come with loads of useless crap, their sockets are pretty good though
whoever said about the lifetime warranty, it doesn't cover any mechanisms or moving parts etc. so on a ratchet for example it'll only be replaced if yiu snap the handle not the internals... pretty pointless
KLX 300r
FlightRisk
PostPosted: 00:26 - 22 Jul 2014    Post subject: Reply with quote
I did go for this Argos set in the end, I think it must have been the smaller set I was looking at but you're right, this one should be worth it just for having every size I'll need. All metric and even has the right spark plug socket. I even took the spanners back to be extra thrifty!
I have my trusty adjustable one anyway with the £1.49 sticker left on because I'm such a label whore...
Plan to get a cheapie torque wrench for the axle nuts next, not sure about a low range one though?
Do I need a punch set? Next thing I want to do is take a brake pin out but I was just going to tap it out with a screwdriver and a hammer. What can go wrong?
biker_bob
PostPosted: 16:11 - 22 Jul 2014    Post subject: Reply with quote
I have a draper expert set, bit more comprehensive than that one but still 3/8's drive. I've had it for about 15-20 years and had no issues. I have used it to undo wheel nuts on a landrover, using an extension (scaffold) tube, and wound up bending the T bar a bit when I bounced on it but the 3/8" drive was fine.
I'd always go for good quality stuff second hand off fleabay or the like. Second hand tools sell for next to nothing and last several lifetimes so are an excellent bargain.
The last post was made 11 years, 200 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 124.51 Kb
