electrics on a cbr600 fw 98
fuel
PostPosted: 23:44 - 14 Jan 2005    Post subject: electrics on a cbr600 fw 98 Reply with quote
a couple of time this week, i've gone to start me bike and whats happened is as follows....
1) de-arm imob
2) key in ignition
3) turn ignition on
4) press the starter button
it is on point 4 that the electrics for the bike completely cut out, no dash lights, no starter, NOTHING
give the bike a swift slap on the seat, " drivers not passenger's" and electrics come back on.
now back to point 1 threw 4 and one of two thing happens
either the bike starts or it all cuts out again
now this problem could happen a few times in a row, and then it decides the electrics will stay on, and once its running its fine.
i doesnt cut out or anything (touch wood)
so tomorrow im gonna take the seat off and check connections ect.....
and i just wondered if anyone can offer any input into what might be happening
or if someone has had a simular experience, what it turned out to be
any ideas welcome
thanx fellow bikers
Fuel............
PostPosted: 00:21 - 15 Jan 2005    Post subject: Reply with quote
If it is like the early 1990s CBR then just in front of the seat there is a starter relay that also has the main fuse for the rest of the electrics. These fail and are not cheap (~£75). Worth checking out once you have checked all the other fuses and the battery contacts.
fuel
PostPosted: 00:27 - 15 Jan 2005    Post subject: Reply with quote
i will have a look for it.
am worried it will be a pain to find though coz its intermitant fault which is why im asking for idea's
is there a way to test this relay you speak of? and any ideas on how i will recognise it?
thanx Fuel...........
mchaggis
PostPosted: 00:30 - 15 Jan 2005    Post subject: Reply with quote
You'll be wanting a Haynes or Clymer manual for your bike. Invaluable things really, especially if they stop you from making expensive mistakes.
I must not be a troll...
Mmmm, Guinness
fuel
PostPosted: 00:34 - 15 Jan 2005    Post subject: Reply with quote
i have a haynes, i will have a look tonight
cheers
Fuel........
PostPosted: 01:46 - 15 Jan 2005    Post subject: Reply with quote
The relay was about 6" in front of the battery. Has a couple of large leads to it (one from the battery, one to the starter motor) and a connector with several wires. Also has a cover for a large fuse on it.
Not sure how you test it, but we found it when Ants bike would not start one night.
keith
PostPosted: 02:52 - 15 Jan 2005    Post subject: Reply with quote
I agree with Kieth on this one. I have has several of these things let-go. If you follow the big fat wire from the battery positive, it will be attached to the top of the starter solenoid by a big bolt.
On a lot of bikes, all the power to the rest of the bike goes through a connector block on the side of this solenoid. It may not be a fault on the solenoid itself, could just be corrosion in the terminal block or fuse holder that attaches to it. Pull the block apart and have a good look, give the wires that attach to it a bit of a wiggle to see if they are about to break off (if you can pull a wire out of a connector block without exerting yourself, it was too loose)
The solenoid should make an audible 'click' when you press the starter button.
Could also be a loose connection or loose fuse somewhere else in which case you will just have to go through and look for it, start at the solenoid and work forwards.
fuel
PostPosted: 18:35 - 15 Jan 2005    Post subject: Reply with quote
just to let you know i took the seat off today and started at the barrery and found that even though the battery earth screw was tight, the conector was moving around, so i've added a washer and now the connection is all nice and tight.
hopefully this has cured it, i will fine out this week, to and frow from work
fingers crossed
thanx for you help fellow bikers
keep it on the blackstuff
Fuel..........
stryker
PostPosted: 19:12 - 15 Jan 2005    Post subject: Reply with quote
FWIW, I once had the starter on my trike fail to operate every so often. Even though the big heavy connector and nut were tight, when I took it apart there was a big buildup of carbon and assorted cr4p. Cleaned it off and everything was ok.
Now what?
The last post was made 21 years, 173 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.21 - MySQL Queries: 13 - Page Size: 65.42 Kb
