| fuel |
 fuel Nitrous Nuisance
| fuel |
| mchaggis |
 mchaggis World Chat Champion
| fuel |
 Posted: 02:52 - 15 Jan 2005 Post subject: |
I agree with Kieth on this one. I have has several of these things let-go. If you follow the big fat wire from the battery positive, it will be attached to the top of the starter solenoid by a big bolt.
On a lot of bikes, all the power to the rest of the bike goes through a connector block on the side of this solenoid. It may not be a fault on the solenoid itself, could just be corrosion in the terminal block or fuse holder that attaches to it. Pull the block apart and have a good look, give the wires that attach to it a bit of a wiggle to see if they are about to break off (if you can pull a wire out of a connector block without exerting yourself, it was too loose)
The solenoid should make an audible 'click' when you press the starter button.
Could also be a loose connection or loose fuse somewhere else in which case you will just have to go through and look for it, start at the solenoid and work forwards. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| fuel |
| stryker |
 stryker Brolly Dolly
The last post was made 21 years, 171 days ago. Instead of replying here, would creating a new thread be more useful? |
