Power valve actuator needle bearing.
Medicinal_Motocross
PostPosted: 14:00 - 17 Jul 2014    Post subject: Power valve actuator needle bearing. Reply with quote
Hi all,
I am struggling to remove a powevalve actuator bearing from my clutch cover. The bearing seems slightly gritty to me and its the last thing to sort before running the rebuilt engine. I've tried heating several times it just doesn't seem to be going anywhere.
I've got a few questions;
* What sort of temprature do you normally heat a clutch cover or the maximum without damaging anything?
* What are the chances of one of these bearings going? If it should fail what sort of damage is likely to occur, as the bearing on the crankcase side of the actuator has the same 'gritty' feel.
* I also noticed that a mystery component (It looks like a gear shaft internal seal) was in the old bits I got back. If this has been removed what will be the consequences of running the engine?
Am I worrying about nothing?
Any input appreciated.
Medicinal_Motocross
PostPosted: 14:36 - 17 Jul 2014    Post subject: . Reply with quote
Also can anyone tell me how many/where the o rings are supposed to be on shaft. No diagrams seem to be specific in pictures there is 3 grooves on shaft but only 2 o rings & my other one has only the top grooved ring on
Medicinal_Motocross
PostPosted: 14:58 - 17 Jul 2014    Post subject: Reply with quote
_Iain_ wrote:
Stop being a potato.
I can't check any of this without the details requested in my previous post.
Sorry about that Iain. Laughing
Its a 1994 kwak kmx 125 b7 also i have uploaded a couple of pictures of the water pump shaft and mystery part Very Happy
Medicinal_Motocross
PostPosted: 16:30 - 17 Jul 2014    Post subject: . Reply with quote
I have attached a couple of photos hope theyre decent enough basically the 3rd one i mentioned is a groove right at the bottom of shaft so seems it would be inside the crankcase, i ordered the two o rings but the larger one (8.8mm i think) is closest to impeller and smaller one doesnt seem big enough to fit onto shaft past this groove right at the bottom and its baffling me Laughing
The engine was rebuilt by a supposed reputable company but guy works from home and im coming across a few schoolboy errors to say the least. The 8.8mm one i have fitted onto the highest groove as this is where it seemed to be before & on my spare shaft before there was just the one on both shafts Shocked thanks
The last post was made 11 years, 207 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 58.14 Kb
