r6 tyre tread depth
stranger12
PostPosted: 19:58 - 17 Jul 2014    Post subject: r6 tyre tread depth Reply with quote
Hi All,
I had a puncture the other day ( almost 8 month from when I last had puncture).
My tyre is metzeler and now I am considering whether to repair it or replace.
I understand the bike minimum tread depth is 1mm, I understand this is across the tyre, correct me if I am wrong.
now when I measured it , the middle bit close to the center is very close to 1-1.6mm with the sides having 3-4mm left .
I think it is due to mainly highway and straight riding.
what is the tread depth on brand new tyre? 6-7mm?
I am trying to think whether to spend £8 for repair or £130 to replace if I am going to need to replace it soon after.
I guess the wear will impact cornering etc , is that correct ?
I am looking at michelen pilot 3 or dunlop roadsmart 2
SV650 Red
R6 Red
PostPosted: 20:12 - 17 Jul 2014    Post subject: Reply with quote
The minimum tread depth is 1mm across three quarters of the tyre.
I'd repair it and keep going as it's got loads of life left yet. Wink
gavcarter
PostPosted: 20:15 - 17 Jul 2014    Post subject: Reply with quote
Repair it, if you don't do millions of miles a year it'll take a couple of months to get down to 1mm
Copycat73
PostPosted: 20:39 - 17 Jul 2014    Post subject: Re: r6 tyre tread depth Reply with quote
its all but fcuked minimum is 1mm
5-6mm if your lucky
caveat emptor
stranger12
PostPosted: 20:44 - 17 Jul 2014    Post subject: Reply with quote
Doing 600 miles a month so do you reckon i can get 3-4 month out of it?
As it is , is it going to be worse for cornering etc
SV650 Red
R6 Red
clancy
PostPosted: 20:59 - 17 Jul 2014    Post subject: Reply with quote
New tread depth depends on the tyre, usually between 6 and 8 mm. If you buy part worn from a tyre shop they are usually 5mm
if your at 1.1mm in the centre, I'd personally just get a new tyre.
and if it's 3/4 mm outside and dead in the middle your doing a lot of upright riding, consider different tyres that will last better
KLX 300r
stranger12
PostPosted: 21:18 - 17 Jul 2014    Post subject: Reply with quote
thats right
in my 45 mins journey i only have 5-10 corners so what type of tyres would you go for
I also think my tyre would be have less traction in rain as it is almost bold
SV650 Red
R6 Red
clancy
PostPosted: 06:45 - 18 Jul 2014    Post subject: Reply with quote
I'd look at sport touring tyre, still give good grip in the twisties but set up for crunching miles too
the Bridgestone bt023 are supposed to be pretty good, just look up sport touring tyre reviews and have a read
KLX 300r
thomp1983
PostPosted: 07:08 - 18 Jul 2014    Post subject: Reply with quote
I run pirelli angel gt's on my 916, I do a similar commute about 200 miles a week motorway with some a roads. after roughly 8k miles my tyres are probably half worn at most ive not measured them but there's certainly a good amount of tread all over and they've handled all the abuse ive thrown at them. they were £230 fitted for the pair
DrDonnyBrago
PostPosted: 08:33 - 18 Jul 2014    Post subject: Reply with quote
It's shagged, I'd replace it.
As for tyres, I like PR3 but they are overkill if all you do is commute.
Realistically, I doubt you'll get much more than 7k* from a PR3 and they aren't exactly cheap.
* yes I know some Americans can get a bazillion miles per tyre, but I can only assume that they ride like my grandmother.
Snorty
PostPosted: 08:43 - 18 Jul 2014    Post subject: Reply with quote
The profile on that tyre must be fucked.
Fronts are a dime a dozen (well I buy mine part worn, 5 sets for £100) so I'd just throw a new front on when it ends up like that, it's going to cause adverse handling.
gbrand42
PostPosted: 09:27 - 18 Jul 2014    Post subject: Reply with quote
If it's an R6 related question then Jizz-Bummy is your man, send him a PM.
I'm running BT023s at the moment and have no complaints
Yamaha RD50M, Honda C90, Yamaha RS100, Yamaha RD125LC, Honda XL125 V9 Varadero, Honda NT700VA, Honda VFR800X, Honda CRF1000L, Honda ST1300 Pan European
devojunior
PostPosted: 09:39 - 18 Jul 2014    Post subject: Reply with quote
david wanna sell me a set off stickyness for the zx6
Blue_SV650S
PostPosted: 09:03 - 21 Jul 2014    Post subject: Reply with quote
Get a new tyre, otherwise time and money wasted if it is down that low anyway.
stranger12
PostPosted: 16:31 - 21 Jul 2014    Post subject: Reply with quote
just got a new michellen pilot power 3 and so far seems good
SV650 Red
R6 Red
stranger12
PostPosted: 17:03 - 21 Jul 2014    Post subject: Reply with quote
well when I used confused.com it did a full hpi check and had a box to input the vin number which once entered it would have said it matched their record.
that was it .
it still did the hpi by just providing the number plate
SV650 Red
R6 Red
PostPosted: 17:13 - 21 Jul 2014    Post subject: Reply with quote
that was it .
I see Laughing
clancy
PostPosted: 17:36 - 21 Jul 2014    Post subject: Reply with quote
that was it .
What ?
KLX 300r
stranger12
PostPosted: 18:06 - 21 Jul 2014    Post subject: Reply with quote
Which part of it is not clear ?
SV650 Red
R6 Red
clancy
PostPosted: 18:35 - 21 Jul 2014    Post subject: Reply with quote
what's confused and hpi checks got to do with your tyres Confused
KLX 300r
stranger12
PostPosted: 14:34 - 22 Jul 2014    Post subject: Reply with quote
apologies
this was meant to posted in
https://www.bikechatforums.com/viewtopic.php?p=3943735#3943735
thanks
SV650 Red
R6 Red
sabian92
PostPosted: 14:40 - 22 Jul 2014    Post subject: Reply with quote
If it's got just over 1.1 mm on the part you measured it's likely to be under 1mm at some point on the tyre.
Considering the not brilliant weather we get, I'd just change it.
The last post was made 11 years, 203 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.84 - MySQL Queries: 13 - Page Size: 110.93 Kb
