| Bunny Lingus |
 Bunny Lingus Traffic Copper
| Rogerborg |
 Rogerborg nimbA
 Posted: 10:10 - 16 Jul 2014 Post subject: |
Yup, 156FMI is 56mm (or 56.5mm in the case of the CG copyengine). It can refer to a couple of different engines, sadly, but none of them are 52mm bore. That should be labelled as 152FMI (at least for a 125cc, the final I represents the capacity).
Not much help, sorry. ____________________ Biking is 1/20th as dangerous as horse riding.
| Bunny Lingus |
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 17:41 - 17 Jul 2014 Post subject: |
You can't go wrong if you fit the spring washers on the end of g box shafts where the shaft goes into the crankcase . I think they are used to stop wear on the casings from the gears as they slickly slide along the shafts.
Be more carefully if washers are required ....BETWEEN the g box gear clusters. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| Bunny Lingus |
| Vincent |
 Vincent Banned
| mathewculver |
 mathewculver Borekit Bruiser
| Bunny Lingus |
| mathewculver |
The last post was made 11 years, 224 days ago. Instead of replying here, would creating a new thread be more useful? |
