Fuel getting to carb but not cylinder?
skatefreak
PostPosted: 20:52 - 20 Jul 2014    Post subject: Fuel getting to carb but not cylinder? Reply with quote
Evening all.
Came across a a strange issue today.
I was looking at a ped for a friend, a 2013 Pesaro 50 replica.
He filled up at a petrol station and after about a mile the bike cut out.
He is sure it was petrol, they have drained/replaced it with fresh fuel and no joy.
I have checked the carb, defiantly fuel getting to it, cleaned out the jets, they are defiantly clear and the spark plug is getting a strong blue spark and there is plenty of 2 stroke oil.
No matter how much the engine is cranked however the spark plug seems to be dry as a bone.
Any thoughts on what may be stopping fuel getting from the carb to the cylinder?
Without taking it apart more I cannot see if there is anything more between the two however I wouldn't expect there to be.
Any thoughts would be very much appreciated..
Best regards.
-Jvr
CestrianX
PostPosted: 21:25 - 20 Jul 2014    Post subject: Reply with quote
How sure are you that it was petrol?
Have you dismantled any part of the bike?
Need more info Smile
Ariel Badger
PostPosted: 22:03 - 20 Jul 2014    Post subject: Reply with quote
Does it have any compression?
skatefreak
PostPosted: 22:31 - 20 Jul 2014    Post subject: Reply with quote
All I've taken off is the bottom fairing, air box and carb.
When turning over there was air flow through the engine as I put my hand behind the exhaust and felt it.
No smell of fuel from the exhaust though.
As for compression, I will have to go over with my compression tester later to be sure.
I am pretty confident it was petrol and not diesel however if it was, the carb has been cleaned out and and its still not getting any petrol through.
Interestingly, even with a strong spark the engine wouldn't fire up using carb cleaner (substitute for easy start).
I really think I'm missing something here as there is defiantly fuel getting to the carb, the jets are clear, no restricted air flow and there is a good spark.
It does only really leave compression however I would expect to at least smell fuel/wet plug after cranking for a while with no ignition but not even that's happening.
One last thing to mention, for a little while apparently the bike has been reving up to roughly 6,000 rpm of its own accord. It has an auto choke however if this was faulty I would be surprised if it kicked the rev's up this high...
Strange one this.
Cheers for the input guys.
Best regards
-Jvr
biker_bob
PostPosted: 16:56 - 21 Jul 2014    Post subject: Reply with quote
I don't know the bike but has it got reed valves or any other kind of valve in there? YPVS is one other that I remember.
Normally sits between the cab and cylinder.
I'm presuming it a 2 stroke.
skatefreak
PostPosted: 08:32 - 22 Jul 2014    Post subject: Reply with quote
sorry.
Yep its 2 smoke.
Its been shipped off to the dealers, was only told its still under warrantee after I had a butchers heh.
Will wait on them to find out what it was as its a pretty curious issue...
A note on the reed valves though, as possibility if they were broken and letting the crank case pressure back out through the carb however I would still expect the engine to fire...
I am starting to wonder if it really could be compression on a 13 plate Rolling Eyes
Best regards.
-Jvr
The last post was made 11 years, 210 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 49.63 Kb
