Tyre rubbing undertray - rear shock issue?
Snorty
PostPosted: 13:38 - 21 Jul 2014    Post subject: Tyre rubbing undertray - rear shock issue? Reply with quote
https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-xpa1/t1.0-9/936056_10154323363440332_6942523193335015528_n.jpg
https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-xfp1/t1.0-9/10479157_10154323363460332_2792949814669779227_n.jpg
https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-xfp1/t1.0-9/983728_10154323363450332_3425651781973888010_n.jpg
It's an aftermarket undertray which came with the bike, but the tyre seems to be catching it. The bike is running a 180/60/17 but it's supposed to have a 190/50 as stock, which seems like it would be even worse.
So what's the issue here? The bike seems to have enough damping and it's a pretty hard suspension on front and rear.
When I sit on it there's probably about an inch before the tyre hits the undertray. Is the shock dead? Set up wrong? When I take pillions it's pretty much a given the tyre will hit the undertray, especially on the shite roads.
sickpup
Old Timer
PostPosted: 15:43 - 21 Jul 2014    Post subject: Reply with quote
This thread is funny for so many reasons that you probably don't appreciate. If you manage to not spit your dummy out of the pram I may post something useful later.
sickpup
Old Timer
PostPosted: 16:09 - 21 Jul 2014    Post subject: Reply with quote
_Iain_ wrote:
You've fitted a higher profile rear tyre Laughing
180 is the width, 60 is the aspect ratio (can be used to work out profile), 17 is the wheel size.
Have a look at a few online calculators.
190/50 has a height of 95mm
180/60 has a height of 108mm
A difference of 13mm in NOT the problem here.
Try again.
PostPosted: 16:25 - 21 Jul 2014    Post subject: Reply with quote
Whoah there Peter Fonda! Wink
Snorty
PostPosted: 16:59 - 21 Jul 2014    Post subject: Reply with quote
I'm not going to "spit my dummy out of the pram" so to speak.
So we're playing the guessing game.
Preload? The undertray is not for this bike? The undertray is a piece of shit? We could do hot or cold as well.
iooi
PostPosted: 17:50 - 21 Jul 2014    Post subject: Reply with quote
I would guess a combination of a knackered shock and a undertray that is wrong.
pdg
PostPosted: 17:53 - 21 Jul 2014    Post subject: Reply with quote
I have a few words in mind about this, but I'm entertained by pup's tack.
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
sickpup
Old Timer
PostPosted: 18:02 - 21 Jul 2014    Post subject: Reply with quote
25 hours awake and a Snorty who hasn't opened his eyes yet. I'm off to bed now so if no one else solves it I may answer then.
One of the things that amused me was the comments along the lines in another thread about how well the front is set up.
Rob W
PostPosted: 18:05 - 21 Jul 2014    Post subject: Reply with quote
Here's a pic of my SRAD sitting on a working rear shock with what is probably the same undertray.
[img]https://i1212.photobucket.com/albums/cc449/Rob-W-1983/IMG_20140518_161800_zps39818a7c.jpg
PostPosted: 18:11 - 21 Jul 2014    Post subject: Reply with quote
either your shock is dead or you are missing a vital part of the linkage Shocked
low rider yo
Fisty
PostPosted: 18:29 - 21 Jul 2014    Post subject: Reply with quote
https://www.youtube.com/watch?v=6A0U7jakUY8
Fatter and faster than Fret
ripzay
PostPosted: 18:31 - 21 Jul 2014    Post subject: Reply with quote
... Or a previous owner has lowered it by changing the length of the dogbones on the linkage.. was the person you bought it from vertically challenged? :p
Current: 2005 KTM SuperDuke 990
Previous: 1996 Suzuki Bandit 600
Previous: 1994 Suzuki GSX-R 400
Northern Monkey
PostPosted: 18:33 - 21 Jul 2014    Post subject: Reply with quote
Maybe you just need to visit Greggs a little less frequently,
Snorty
PostPosted: 18:40 - 21 Jul 2014    Post subject: Reply with quote
The dog bones are standard I believe (they have 33E stamped on them).
That SRAD looks a lot higher than mine. I'm guessing the rear shock is fucked then - probably the original one still.
Fisty
PostPosted: 18:50 - 21 Jul 2014    Post subject: Reply with quote
Could the subframe be twisted? Wink
PostPosted: 19:06 - 21 Jul 2014    Post subject: Reply with quote
Three words.
Ride
Height
Adjuster.
Snorty
PostPosted: 19:21 - 21 Jul 2014    Post subject: Reply with quote
The pre-load? The bit that requires a c-spanner?
PostPosted: 20:15 - 21 Jul 2014    Post subject: Reply with quote
no. Wink
Snorty
PostPosted: 20:55 - 21 Jul 2014    Post subject: Reply with quote
Can't find anything in the Haynes Manual.
Fisty
PostPosted: 21:45 - 21 Jul 2014    Post subject: Reply with quote
Take a picture of the top of the shock, the very top of it where it bolts to the frame.
sickpup
Old Timer
PostPosted: 08:35 - 22 Jul 2014    Post subject: Reply with quote
I'm confused as to why some people think its a duff shock? The only way it could be is if the spring was broken.
Snorty
PostPosted: 10:01 - 22 Jul 2014    Post subject: Reply with quote
https://force-v4.com/store/images/force-v4/spl-ride-height-adjuster.png
Am I looking for one of these? The Haynes manual doesn't even mention this, just the length of the shocker on max preload and min preload.
evoboy
PostPosted: 10:07 - 22 Jul 2014    Post subject: Reply with quote
Subframe looks bent.
Angle on the swingarm looks ok from the small amount that can be seen in one of the pics.
Although, it could be a combo of a few things!
APT Motorcycles
Snorty
PostPosted: 11:20 - 22 Jul 2014    Post subject: Reply with quote
https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-xpf1/t1.0-9/10492384_10154326784085332_3891180413842808778_n.jpg
https://scontent-b-fra.xx.fbcdn.net/hphotos-xfp1/t1.0-9/10404223_10154326784080332_4049553142520834609_n.jpg
Yes, it's filthy.
The last post was made 12 years, 84 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 131.45 Kb
