Carb jetting question
EazyDuz
PostPosted: 16:41 - 21 Jul 2014    Post subject: Carb jetting question Reply with quote
I fit aftermarket pipes (with baffles which are wrapped with fibreglass) on my bike.
Stock everything else.
It pops on decel which is annoying to me. Ive read a lot of conflicting info on how to stop it.
Im positive there are no exhaust leaks. I read that if i richen the pilot screw, it will cure the popping. Which makes sense because it only does it when the throttle is fully closed, if its open a tiny bit it wont do it.
Basically whenever im engine braking with no throttle it will do it, e.g down hills.
Problem is the pilot screw is seized with a stripped head, and at £60 to have it removed and replaced by a carb specialist its not something i want to do really. Would putting a larger (by 2.5) main jet cure it, or would that make no difference?
Or what about slightly narrowing the air intake hole, or would that affect performance?
Also does anyone know a good, reliable carb specialist anywhere?
Thanks
pdg
PostPosted: 16:44 - 21 Jul 2014    Post subject: Reply with quote
The main fuel circuit isn't active with a closed throttle on most carbs I've seen so changing this jet probably won't make any difference at all...
Although, if you've changed the exhaust for a freer flowing one but left the carb stock you might be setting yourself up for other problems - check plugs etc....
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
EazyDuz
PostPosted: 16:47 - 21 Jul 2014    Post subject: Reply with quote
Thanks for the reply. Checked the plugs and they are fine. So the only cure would be to get the pilot drilled out and replaced?
pdg
PostPosted: 16:49 - 21 Jul 2014    Post subject: Reply with quote
That's not the only way to get a pilot screw out, but then I haven't seen your carbs or stroked them at all so I couldn't advise on that bit...
EazyDuz
PostPosted: 16:53 - 21 Jul 2014    Post subject: Reply with quote
Single carb. Pilot screw is about 3/4 of an inch inside the carb body. I heard a reverse drill bit is my best bet.
Are there no other carb/intake mods i can do to fix it?
If not, removing it isnt something id want to do, so i guess ill have to get a pro
pdg
PostPosted: 16:59 - 21 Jul 2014    Post subject: Reply with quote
Seeing as the 'problem' was caused by a modification, sorting that properly would be the right thing to do. Just 'modding' more things in an attempt to mask it is isn't...
I wouldn't trust anyone who takes a drill bit near a carb with it attached to the vehicle which explains why the price is so high for a '5 minute job'.
If you're not comfortable taking the carb off and getting that screw out yourself, then the only other sensible option is to take it to someone else.
EazyDuz
PostPosted: 17:17 - 21 Jul 2014    Post subject: Reply with quote
No I was quoted £20-40 (depending on how long it takes) to remove the carb and send it to them. Would be £60ish inc insured postage to them.
I can take the carb off its just the removal of the jet I wouldn't fancy trying myself. Think I'll just leave it for now and pull the clutch in more often than engine braking.
Hetzer
PostPosted: 17:48 - 21 Jul 2014    Post subject: Reply with quote
It sounds like you need to change the main jet. I had to do mine on a Fireblade when I fitted a Micron can.
gavbriggs
PostPosted: 18:27 - 21 Jul 2014    Post subject: Reply with quote
Does it have a manual choke? Put it on ever so slightly. It will probably stall at junctions but just to text if it cures the decel pop.
It would be better to sort the pilots tho, it took me a while to get mine set up after having to replace on of the four carbs.
Standard it 3 turns out, mine are at 4.5 turns out and that with just a viper end can. Rest of the revs is fine but it had a splutter at around 2k rpm, which is commute/traffic speed and nearly had me in trouble a few times
Recent bikes: Varadero 125 - Mod 2 3/2/14 - Bandit 1200 SK4
EazyDuz
PostPosted: 20:00 - 21 Jul 2014    Post subject: Reply with quote
But the main jet doesn't affect 0-5% throttle does it? Also the bike runs spot on, no flat spots or loss of power so wouldn't a larger main make it overly rich anyway?
EazyDuz
PostPosted: 20:11 - 21 Jul 2014    Post subject: Reply with quote
Another thing to note is that when I pull the choke when the engine is hot, rpms increase and it doesn't stall. Further suggests that the pilot is lean right?
The last post was made 11 years, 218 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.16 - MySQL Queries: 15 - Page Size: 68.15 Kb
