Suzuki RF900R, Clutch-ish piston housing... engine case
hollowgod89
PostPosted: 19:05 - 22 Jul 2014    Post subject: Suzuki RF900R, Clutch-ish piston housing... engine case Reply with quote
Right, so im eyeing up this bike that i could make an offer on, as one would guess by the subject name, its an rf900 - 95/96 model. Bar the general servicing it needs it has one major issue.
The clutch, so at one point the chain snapped on this bike and smashed a chunk of the engine casing. all in all its effectively only superficial. But, it has smashed two of the bolt threads that hold the clutch piston in place. Now every time the clutch is used the piston flexes on its remaining bolts. As its a hydraulic clutch it means theres little room for adjustment.
The thing is ridable now, after getting used to the seemily on/off choice you have but it is steadily worsening..
So, being that this isnt my ride i dont know if this piece of the engine case can be replaced easily or if it is part of the crank case.
Any advice?
Honda CG125 (died a noble death)- Honda CB125TD (modified and converted into.....) - Honda CB200 Benley Cafe (Burnt to cinders by idiots)- Honda CB500 (training for test) - Honda CB600F Hornet (damn laws changed/ passed test on)- Honda Shadow 750 Trike (borrowed for a month while bike was under service CBR--->)- Honda CBR600 F2 - (The only bike I've know to be a 'He') - Suzuki RF900R (borrowing on a mid-long term basis) - Yamaha XJ600 Diversion (oil rings locked up and seized engime of a f*cking motorway) - Honda CBR1000F hurricane ( Aye she's a fast 'un)
CHR15
Turbo nutter bastard
PostPosted: 19:44 - 22 Jul 2014    Post subject: Reply with quote
its part of the crankcase.
you could have some bosses welded on if you found someone suitably skilled.
Fisty
PostPosted: 22:45 - 22 Jul 2014    Post subject: Reply with quote
Would 4 thou be enough?
Fatter and faster than Fret
Fizzer Thou
PostPosted: 10:51 - 25 Jul 2014    Post subject: Reply with quote
Or convert it to a cable clutch.
I have seen a few GSXR1100H and J models with this modification
Always have a 'Plan B'
hollowgod89
PostPosted: 21:08 - 25 Jul 2014    Post subject: Reply with quote
how in hades do you convert from hydraulic to a cable? easily
CHR15
PostPosted: 23:47 - 25 Jul 2014    Post subject: Reply with quote
replace the hydraulic slave cylinder with a mechanical one.
not that that would solve the problem because your still applying force to the same part.
you could.... possibly... fit a gsxr750 clutch cover and lifter mechanism, which pulls the clutch open using a rack and pinion built into the clutch cover.
although im not sure if the oil boiler clutch covers bolt on to the rf motors.
The last post was made 12 years, 82 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 56.88 Kb
