huge hole in crankcase
PostPosted: 15:59 - 24 Jul 2014    Post subject: huge hole in crankcase Reply with quote
I have gotten a huge hole in the right side crankcase and I wondered if it is worth the money or possible to fix this hole.
heres a pic link so you dont have to download..
https://postimg.org/image/lp69dwahn/
P.
PostPosted: 16:01 - 24 Jul 2014    Post subject: Reply with quote
https://upload.wikimedia.org/wikipedia/commons/a/af/DryToast.jpg
That is...
TUG
PostPosted: 16:14 - 24 Jul 2014    Post subject: Reply with quote
If you wanted that fixed it would need welding then the entire thing cut flat perfectly. It would be a better option to get another crank case unless it's cheaper to have it welded then machined. Is it a 2 stroke or a 4 stroke engine?
Haz ER-5, innit!
PostPosted: 16:27 - 24 Jul 2014    Post subject: Reply with quote
Take it to a weldor and ask them to weld it. How did it get broken?
Robby
Dirty Old Man
PostPosted: 16:28 - 24 Jul 2014    Post subject: Reply with quote
It could be welded. I wouldn't bother.
Alpha-9
PostPosted: 16:30 - 24 Jul 2014    Post subject: Reply with quote
How did you manage that then? Laughing
Fzr-600 1999
PostPosted: 17:26 - 24 Jul 2014    Post subject: Reply with quote
What's it off and how much do you give a shit?
I'm looking at that and thinking you could probably lumiweld it back in place then glue an aluminium patch over the outside with JB weld for good luck. Do up that bolt last.
Another (really, really bad) part of me thinks that if you were to put the bolt back in so that piece was held onto the cover with an appropriately thick piece of paper gasket, coated the broken edge in instant gasket then bolted the cover back in place, it'd probably be oiltight.
It's not like its pressurised, it just needs to be oiltight.
Both are bodges. The latter an utterly horrific one (although I know people who'd try it, might have myself once upon a time). Both have the potential to dump your engine oil out at any time.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:43 - 24 Jul 2014    Post subject: Reply with quote
Just find the elves that were working on the pit and dirt bikes at the BCF BBQ. I swear, they made a piston out of grass at one point...
Triumph Sprint ST 1050
gavcarter
PostPosted: 20:44 - 24 Jul 2014    Post subject: Reply with quote
Fixable with a top quality aluminum adhesive / epoxy or as said aluminum weld. Both are probably cheaper and less hassle than splitting and replacing crankcases
gavbriggs This post is not being displayed because it has a low rating (Confusing). Unhide this post / all posts.
Nobby the Bastard
Harley Gaydar
PostPosted: 21:23 - 24 Jul 2014    Post subject: Reply with quote
gavbriggs wrote:
I would clean the break with acetone or similar to remove any oil residue. Then chuck some sort of oil resistant glue/liquid teal etc in the joint, bolt in opposite casting and join it all up. One set remove case and bolt, tidy it up. Apply more gloppy shit and put it all back together and ebay, you can get the outside looking standard as the inside will be sealed and no one will ever know there's a join!
Are you suggesting that you do a substandard repair and then flog it to an un-suspecting person?
Edit: It appears that there isn't an option to rate a post 'This person is just a cunt'
770
PostPosted: 21:48 - 24 Jul 2014    Post subject: Reply with quote
do you think a mechanical shop would do that and do i need to remove any parts from the crankcase? the hole i located down-right on the clutch side..
serlant
PostPosted: 21:57 - 24 Jul 2014    Post subject: Reply with quote
is it wrong that I hear the derp song https://www.youtube.com/watch?v=ooNbVgSSguI in my head while picturing him hitting it with a hammer. "Smack, Smack, Smack" scratches head, "this is on tight" "smack smack smack, Yay its off!" "awwww"
I'd try a durafix welding rod and blowtorch, have successfully welded a hole in my VTR1000 clutch cover when I dropped the bike damaging it.
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
gavcarter
PostPosted: 22:11 - 24 Jul 2014    Post subject: Reply with quote
Think more along of the lines of an engineering firm, or some one who fabricates aluminum parts.
If it got tig welded I reckon they could probably do it in the frame, if they "braze" it, probably have to remove the engine.
Personally I would give this a bash first https://www.ebay.co.uk/itm/JB-Weld-Marine-Weld-Dont-Scrap-It-JB-Weld-It-/281371219315?pt=UK_Home_Garden_FittedCarpets_Underlay_SM&hash=item4183081573
Clean both edges with acetone or at least a strong degreaser and then give a light sand right before applying the epoxy.
Sand ( with rough paper about 80grit ) the outer side of both parts all the way along the break line about and about 10mm extra in all direction ( so 10mm longer than the break each end and 10 mm wider all the way along)
apply a fair bit of JB to the break and push the broken part in until its flush with rest of case ( light tap with hammer may be needed to seat it back together)
Squash the extra epoxy on the OUTSIDE of the cases against the break to make a "patch" over the join, on the inside the epoxy will squeeze out of the join, so trim it off with a knife or scraper ASAP before it sets, also wipe the inside with a damp rag to remove any extra after scraping.
Double check the piece is in proper position and let set.
Dont fart on with outside too much, concentrate on getting the piece aligned and inside clean you can sand the outerside when its set
Eddie Hitler
PostPosted: 00:11 - 25 Jul 2014    Post subject: Reply with quote
I'm sure some normal home superglue would do the trick on that.
Ed Case
PostPosted: 13:32 - 25 Jul 2014    Post subject: Reply with quote
JB Weld is the stuff, it'll work a treat.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:36 - 25 Jul 2014    Post subject: Reply with quote
_Iain_ wrote:
Piston out of grass is unfourtunately a myth, however I did make a working inlet boot out of an inner tube, some old mastic and superglue which seemed to double the power output of the superped & resulted in a few flipped wheelies. Laughing
Didn't you donate a sock at one point as well?
groovylee
PostPosted: 20:21 - 25 Jul 2014    Post subject: Reply with quote
yep, on the little pitbike Laughing unfortunately the noxious fumes overwhelmed the engine Shocked Wink
Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R
ZRX61
Victor Meldrew
PostPosted: 19:05 - 13 Aug 2014    Post subject: Reply with quote
Weld it, piece of piss.
They're not one night stands, they're auditions.
The last post was made 11 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 112.22 Kb
