full beam for filtering?
Wonko The Sane
PostPosted: 09:06 - 25 Jul 2014    Post subject: full beam for filtering? Reply with quote
Someone recommended in the 'new riders' section to have high beam on for filtering to aid being seen.
Someone told them to stop being a twat (might have been because Bodyguard suggested it)
I have been using full beam generally when using motorways for the past two years on both my varadero and on my ZZR600 to aid being seen, justifying it as my lights are not brighter than HID's etc
Do you use full beam for filtering?
If so, motorway only or generally?
good idea / bad idea?
PostPosted: 09:11 - 25 Jul 2014    Post subject: Reply with quote
Full beam is only for use on empty roads as the beam is set higher than the dipped. You'll blind people.
Last thing I would want is full beam when filtering, what if the guy in the car checks his mirrors and cant see anything because you are blinding him with your lights? Surely that is more dangerous.
PostPosted: 09:14 - 25 Jul 2014    Post subject: Reply with quote
Probably counterproductive, definitely a cu​nt's trick. Not for me, thanks.
arry
PostPosted: 09:16 - 25 Jul 2014    Post subject: Re: full beam for filtering? Reply with quote
Bad idea.
Brightness isn't the same as dispersal pattern. Full beam delivers intense light centre weighted without giving a toss whether it's delivered into oncoming drivers' eyes - or in your instance, dazzling them off their mirrors.
iooi
PostPosted: 09:21 - 25 Jul 2014    Post subject: Re: full beam for filtering? Reply with quote
That would be me Laughing
And NO bodyguard saying it was not why...
Go and sit in a car and put your bike so your full beam is shining in the mirror...
What is the result.
YOU CAN'T SEE
High/main beam. Is for unlit roads to help you see.
It does nothing to help others see you or even to be able to work out how far behind you are.
From the highway code.
You MUST NOT
use any lights in a way which would dazzle or cause discomfort to other road users,
including pedestrians, cyclists and horse riders
use front or rear fog lights unless visibility is seriously reduced. You MUST switch them off when visibility improves to avoid dazzling other road users (see Rule 226).
In stationary queues of traffic, drivers should apply the parking brake and, once the following traffic has stopped, take their foot off the footbrake to deactivate the vehicle brake lights. This will minimise glare to road users behind until the traffic moves again.
Law RVLR reg 27
115
You should also
use dipped headlights, or dim-dip if fitted, at night in built-up areas and in dull daytime weather, to ensure that you can be seen
keep your headlights dipped when overtaking until you are level with the other vehicle and then change to main beam if necessary, unless this would dazzle oncoming road users
slow down, and if necessary stop, if you are dazzled by oncoming headlights
TheArchitect
PostPosted: 09:28 - 25 Jul 2014    Post subject: Reply with quote
agree with above in that it's a really bad idea to use full beams on normal roads in normally lit conditions.
I've been in my car with a knobsack rider behind me with high beams on. Had to adjust my mirrors to stop being blinded. Can you imagine how distracting that would be at motorway speeds?
As said, it makes little to no difference in you being seen. You're better of improving your obs and road positioning as that'll actually save your life.
GSXR 600 K6 - Stolen
MT09 - Almost stolen
Northern Monkey
PostPosted: 09:29 - 25 Jul 2014    Post subject: Reply with quote
Cunts use full beam
Efes123
PostPosted: 09:31 - 25 Jul 2014    Post subject: Reply with quote
He also said go as fast as you like while filtering, please tell me you don't do that as well, otherwise you might have to change your username Laughing
Honda Goldwing GL 1000 Current love
Honda VT500 ED - SOLD
Projects Suzuki GS125 Done, then stolen - Kawasaki GPX750R SOLD - Honda VF750S SOLD
Hetzer
PostPosted: 09:54 - 25 Jul 2014    Post subject: Reply with quote
Bikers who ride around with full-beam on deserve a slap.
gbrand42
PostPosted: 10:00 - 25 Jul 2014    Post subject: Reply with quote
Only utterly retarded twat compulsive liars with attitude problems filter on main beam.
Proper bikers do it properly.
Yamaha RD50M, Honda C90, Yamaha RS100, Yamaha RD125LC, Honda XL125 V9 Varadero, Honda NT700VA, Honda VFR800X, Honda CRF1000L, Honda ST1300 Pan European
69.9mph
PostPosted: 10:01 - 25 Jul 2014    Post subject: Reply with quote
This is one of my pet hates.
If you think you need to use main beam while filtering, you probably are inept and shouldn't be filtering anyway.
Baffler186
nope. All you need for filtering is common sense, appropriate speed and good observations. Nothing else will help you. I also read that there is a craze for people putting their hazards on when filtering. Equally as useless and annoying as having full beams on.
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
Raffles
PostPosted: 10:24 - 25 Jul 2014    Post subject: Reply with quote
When I'm in a car and the car/bike behind has their lights on full beam, I adjust my mirror to bounce the light back at them. They soon dip 'em.
stonesie
PostPosted: 10:33 - 25 Jul 2014    Post subject: Reply with quote
Full beams are for empty country lanes at night, only morons use them in traffic.
drzsta
PostPosted: 10:42 - 25 Jul 2014    Post subject: Reply with quote
Definitely a cunts trick. Its also very hard to judge the distance and speed of a motorcycle when they're using full beam.
PostPosted: 10:43 - 25 Jul 2014    Post subject: Reply with quote
Terrible idea. It's impossible to judge distance when you're being dazzled, it's been proven by a number of different studies. Whoever does this is a moron.
British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
Islander
PostPosted: 10:53 - 25 Jul 2014    Post subject: Reply with quote
As above (pick any post).
Just. Don't.
Wonko The Sane
PostPosted: 10:58 - 25 Jul 2014    Post subject: Reply with quote
So, it's unanimous then,
I'll see how drivers behave next week without it, used to find I got a bit more space on the varadero with full beam on. Stopped caring now I've got better at filtering and a bigger bike.
covent.gardens
World Clap Champion
PostPosted: 11:14 - 25 Jul 2014    Post subject: Reply with quote
Full beam when filtering?
https://i59.tinypic.com/1el5z8.jpg
andyscooter
PostPosted: 11:15 - 25 Jul 2014    Post subject: Reply with quote
think someone may be getting confused with main beam and head light
blueglue
PostPosted: 11:33 - 25 Jul 2014    Post subject: Re: full beam for filtering? Reply with quote
I'm new here but I take it this guy is trying to get new riders to do stupid things on purpose?
Nah, he's just a moron in general.
PostPosted: 11:44 - 25 Jul 2014    Post subject: Re: full beam for filtering? Reply with quote
It's rude.
While it probably WILL make people take more notice of you, it also WILL make it harder for them to judge your position and speed. The latter not being very useful and could easily be used to show you were at fault in an accident.
PostPosted: 11:48 - 25 Jul 2014    Post subject: Reply with quote
Compared to what?
Bikers, self included, have a dreadful habit of projecting our beliefs as though they effect reality. "He made eye contact!" and "Loud pipes save lives" are a good tie for first, but this sounds like a close second.
The last post was made 11 years, 161 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 129.76 Kb
