want to get ripped
Bike Chat Forums Index -> Dear Auntie BCF... Goto page 1, 2, 3  Next
KaGantua
PostPosted: 21:14 - 27 Jul 2014    Post subject: want to get ripped Reply with quote
ok
im 5'9, male
cant seem to put on weight, but ive been eating healthy for the past two years (2 portions of fruit a day, cut out most cola, only eat dark chocolate ocassionally, no fatty fried foods, lots of pastas, veg, white meat, fish, protein etc)
also started having 2 protein shakes a day, seem to eat less that way
whats a good plan for getting cut?
ive never been a big gym aficiando, but thats changing now
dont want to look like arnie, and not interested in roids
what can you guys recommend? please thx
Itchy
PostPosted: 21:33 - 27 Jul 2014    Post subject: Reply with quote
Gym, use free weights and bars don't use machines as they do half the work for you and neglect minor control muscles reducing your usable strength. On the bench press machine I can easily go over 70 kilos, but with a bar I generally can manage 45.
Select a weight which is challenging where you can JUST about do your 4 sets of 10, if you can do it easily add more weight. If you can't reduce it.
Ask others about technique, for example bicep curls a lot of beginners will cheat by swinging.
Work outs are a very personal thing, I focus on my triceps, lats and triceps as when I had huge delts and biceps I found it affected my fighting style which depends on position, technique and balance rather than brute strength.
marsden1967
PostPosted: 21:38 - 27 Jul 2014    Post subject: Reply with quote
I'm watching the Commonwealth games at the mo. ALL the male swimmers have fantastic bodies. Not too big but have good muscle definition. I would say start swimming regularly.
Ooooh Matron!
current bike(s) YBR 125, ER6 N
el_oso
PostPosted: 21:50 - 27 Jul 2014    Post subject: Reply with quote
stronglifts 5x5 program. It will not get you ripped, but it will get you very strong and will identify any weaknesses you have.
When you start plateauing out on the stronglifts which (which shouldn't take that long 3months I'd say) then concentrate on more reps. It's the amount of time your muscles are under tension which gives them definition. By doing the stronglifts you are able to put a lot more tension on the muscles because you are stronger.
Duke 390
Car: Jeep Wrangler 4.0L
angryjonny
PostPosted: 21:56 - 27 Jul 2014    Post subject: Re: want to get ripped Reply with quote
KaGantua wrote:
want to get ripped
Come round and give our cat a bath. You'll get ripped to within inches of your life.
Chalky.
PostPosted: 22:05 - 27 Jul 2014    Post subject: Re: want to get ripped Reply with quote
KaGantua wrote:
ok
im 5'9, male
Do you want to be cut, or put on size?
KaGantua
PostPosted: 22:11 - 27 Jul 2014    Post subject: Re: want to get ripped Reply with quote
Chalky. wrote:
KaGantua wrote:
ok
im 5'9, male
good question, i suppose i want to gain a bit more size and definition, but not alarmingly so
Rogue_Shadow
PostPosted: 22:23 - 27 Jul 2014    Post subject: Reply with quote
Agreed
Swimming
bikertomm
PostPosted: 23:18 - 27 Jul 2014    Post subject: Reply with quote
I'm in a similar position to the OP.
Following with interest.
I do enjoy swimming, but most likely resemble a drowning fly to everyone else.
Surely they hit the gym aswell as swim loads though, very good for toning you up not sure about making you bigger. Thumbs Up
PostPosted: 23:43 - 27 Jul 2014    Post subject: Re: want to get ripped Reply with quote
If you want to put weight on, you need to eat more calories.
Simples.
None of what you describe particularly says 'healthy' (or not healthy) that I can see.
'Healthy' to me is a good choice of food to meet your goals.
If your goal is to put on weight, a lot of low calorie density food might be a bad idea.
Me, I had a whole 900ml tub of icecream, which I'd consider a healthy choice to meet my calorie needs. (Actually, I really should eat a little more as I'm still slowly losing weight, which probably doesn't help recovering from a couple of injuries.)
If you want to put weight on, specifically muscle, the first thing to do is to eat more calories than you burn in a day.
There are various calculators and other ways you can figure it out (I have a very expensive machine that will give you a pretty decent figure), but the best way I'd say is to use an app like libra (or a spreadsheet) and track your averaged weight with daily checkins.
If your weight is going up, sorted. If not, eat more Smile.
Of course, if you want to put on muscle you need to be using your body.
I'd second the suggestion of stronglifts, or starting strength, which is similar.
You can get your own weights set up for not too much, or at a gym, of course.
Aim to have at least .7g of protein per lb of body weight when putting on weight. It won't hurt to have more.
Do make sure you get some fat, which is important for various hormones and so on.
Once you've put on some muscle, you'll probably then want to cut some fat. Putting on muscle pretty much always comes with fat*, and you may well find you want to lose some more anyway to get the 'definition' you are after, which tends to be more about low body fat (especially abs etc) than big muscles.
*If you go REALLY slow, it won't so much, but it's generally quicker to get to the same point to put on muscle with fat, then lose fat and repeat than to go slow.
sensi5446
PostPosted: 23:50 - 27 Jul 2014    Post subject: Reply with quote
+1 to Gs post, he knows what he's talking about Smile
Eddie Hitler
PostPosted: 09:59 - 28 Jul 2014    Post subject: Reply with quote
You do realise they will have a strength training program? They don't get ripped from swimming alone. Laughing .
lihp
PostPosted: 10:04 - 28 Jul 2014    Post subject: Reply with quote
Want to get ripped? Reduce body fat percentage.
One method is to bulk up slowly on a heavy weight training programme, then cut back slowly to reduce fat, and repeat for a long time.
It's not something that will happen in a few weeks.
Eddie Hitler
PostPosted: 10:08 - 28 Jul 2014    Post subject: Re: want to get ripped Reply with quote
KaGantua wrote:
o
When people commented to Arnold "I never want to look like you", he always replied "Don't worry, you never will".
dydey90
PostPosted: 14:09 - 28 Jul 2014    Post subject: Reply with quote
All these people struggling to put on weight can have a bit of mine. Just get a desk job and you'll put it on no trouble!
I've managed to stop gaining by reducing what I eat to around 1800 calories a day.
Chalky.
PostPosted: 14:41 - 28 Jul 2014    Post subject: Re: want to get ripped Reply with quote
Ok, what kind of shake are you on?
Simplified, but lean muscle you want protein, bulking you want carbs. This is for your meals and your shakes. Skinny people with a quick metabolism can eat all the shit in the world and stay skinny, opposite for others.
You're in a common position with your desires, hit the food and hit the weights, do individual body parts each day and smash them hard, 8-10 reps on each exercise.
lihp
PostPosted: 14:50 - 28 Jul 2014    Post subject: Re: want to get ripped Reply with quote
Pretty much a myth.
Metabolism varies for everybody depending on many influences such as muscle mass, food consumption, activity levels, etc.
notbike
PostPosted: 14:51 - 28 Jul 2014    Post subject: Reply with quote
Haven't read other advices here but this is what I used to do before exams at uni (using those as an excuse for why I'm a lazy git now XD)
Caloric deficit for cutting, caloric surplus for weight gain.
Balanced diet fruits, veg, nuts, beans, vary it, raises testosterone.
Stable steady excess protein (lots of boiled chicken, yes it gets very boring)
Cycle your Carbs (get into a weekly pattern for example 3 low carb days followed by a high carb day, rest low carb days, end of week high carb day, repeat) this'll help lose excess fat rapidly when combined with:
High intensity daily Cardio but short intervals like 30 minutes or so - Lift daily (Rotate muscle groups, allow couple days rest) what worked for me was calisthenics type workouts (Check out Barstarzz for an idea, obviously I'm nowhere near these guys in strength or ability but they're great motivation!)
I used to go to parks like primrose hill and do bodyweight exercises daily, they have dip bars and pull up bars and all that. It was nice to be out in the open so often. I used to go every day for like 2 weeks then I'd take a few days off completely from total fatigue, then repeat. It gives great results tbh aside from the constant sore muscles xD
Buuuut I've been a massively lazy git for the last 4 months. I need to jump back on it real bad but I'm finding motivation hard.
Also a hobby sport ontop will make you more lean without you even realizing it, I used to do mountain biking & cycling on top for enjoyment which gave nice results.
Don't expect to get ripped quick, it takes months to see results, and dont expect to get strong quick either, it also takes months. See it as a lifestyle change, and in a few years you'll have an impressive physique.
Edit: Dont invest money in supplement gimmicks either, extra protein doesnt hurt and creatine is okay (with plenty of water). But instead just invest faith in yourself, not products. If you're looking at shakes to get strong you're missing the point, there is no get ripped quick scheme and it takes dedication and a lot of hard work (unless you're a superior genetics nob who can eat anything and not lift and maintain a superior physique)
Chalky.
PostPosted: 15:33 - 28 Jul 2014    Post subject: Re: want to get ripped Reply with quote
PhilDawson8270 wrote:
Pretty much a myth.
Someone with a naturally quick metabolism is not going to see the same weight gain as someone with a slow metabolism if they ingest the same calories?
JonB
Afraid of Mileage
PostPosted: 16:21 - 28 Jul 2014    Post subject: Reply with quote
Why are you taking a protein shake when you aren't even working out?
Your body can only process a set amount of protein a day and you probably get enough for your general diet.
Tarmacsurfer
PostPosted: 16:35 - 28 Jul 2014    Post subject: Re: want to get ripped Reply with quote
KaGantua wrote:
want to get ripped
If you listen to Hetz, just pay into a pension and you will be Laughing
I'm immortal. Well, so far.
lihp
PostPosted: 17:05 - 28 Jul 2014    Post subject: Re: want to get ripped Reply with quote
The point I am making is that a persons metabolism isn't fixed.
Muscle is "metabolically active" the more muscle you have, the faster your metabolism will work, massive calorie restrictions will slow your metabolism down.
2 people with the same fat percentage, and the same lean muscle mass, eating an identical diet at identical times, shouldn't have massively different metabolism rates.
Robby
Dirty Old Man
PostPosted: 17:06 - 28 Jul 2014    Post subject: Reply with quote
Other people will probably give good advice. Simple bit from me:
Lift weights. Have a break from lifting of at least a week every 2 months or so.
If you build muscle, it'll stay with you and come back later in life. I used to lift weights, haven't bothered for a few years. A couple of weeks ago I did a 10 minute session, next day I was considerably larger.
lihp
PostPosted: 17:11 - 28 Jul 2014    Post subject: Reply with quote
In your bulking up phase you want to be adding 0.5lbs or so per week, so at a slow rate, with plenty of protein surplus and regular heavy weight program.
Benjums
PostPosted: 17:47 - 28 Jul 2014    Post subject: Reply with quote
When I was hitting the gym hard in my younger days I was always told to bulk up its high weights, low reps. To cut was low weights high reps. And to adjust what your eating to what you want to achieve.
Just please when you first start use low weights until you get the technique sorted (there was nothing funnier than watching the roid heads in the gym just swinging the weights and not doing anything)
Another way is to look at the high intensity workout dvd like insanity or other things like that, don't think you will look like them after 8 weeks if your really over weight though (I am overweight but I started the insanity workout and lost two stone in the first 5 weeks, then done my knee in put an end to that for a while and put weight back on)
Everyone will offer different advice on here and in rl as well because what works for one may not work for another, in time if your going to the gym you will put together your own workout, dropping some routines and adding others in that work for you. There is no magical pill or anything, it's down to time and pure hard work.
The last post was made 12 years, 70 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 133.11 Kb
