Tell me about the ZZR 1100
-Monty-
PostPosted: 22:04 - 29 Jul 2014    Post subject: Tell me about the ZZR 1100 Reply with quote
Well my 33bhp restriction is up this November (thank god) and I am now thinking about what to get next.
As I am thoroughly fed up with the CB500's (lack of) performance when out on the open road (particularly whilst on the Autobahn in Germany) I am considering a large capacity sports touring bike.
I want something fast, comfortable and cheap. So the ZZR1100 seems to fit the bill. I realize this will be an enormous step up from a 33bhp CB500, but the ZZR really appeals to me (I actually like the retro nineties look).
Anyway, I'm just hoping for some further information from owners/previous owners on here. I.e. what they're like to live with (comfort, reliability, fuel consumption etc), common problems and common upgrades/mods.
A minor concern I have about this sort of bike is the amount of rear tyres they must get through. My CB500 got through a rear in about 4000 miles and I can't imagine a bike with several times the power and far more weight is going to fair much better. What are other people's experiences with this?
I understand the later D1 models are the ones to go for due to numerous improvements over the original (fuel capacity, brakes etc). Would it be worth paying much more for the later model?
It won't be used as an every day bike as I will likely keep the CB500 for that, but whatever I get will be used for next years EuroJolly to Switzerland and other future trips away.
Thanks
Alex
Present: [Kawasaki ZX7r][Suzuki DRZ 400s]
Past: [Honda PCX 125] [Yamaha RXS 100] [Honda CB 500] [Triumph Speed Four] [Honda ST1100 Pan European - Po-Po Edition]
BenR
PostPosted: 22:10 - 29 Jul 2014    Post subject: Reply with quote
It's made by Kawasaki with an 1100cc engine. Wink
-Monty-
PostPosted: 22:15 - 29 Jul 2014    Post subject: Reply with quote
Well, I never!
_mjs_
PostPosted: 22:29 - 29 Jul 2014    Post subject: Reply with quote
A guy at work has a big purple one and loves thrashing it on sunny days.
He also has a ZZR1100.
ZZr
PostPosted: 22:36 - 29 Jul 2014    Post subject: Reply with quote
heavy when pushing into parking spot, light when moving
Keeps up with most bikes on the straight ,
Always feels planted on the road.
Braided lines are a must.
Maybe its how i ride but the tyres lasted 6000 miles.
Not had any problem with mine ,bullet proof engine
bikers know why dogs stick their heads out of car windows
-Monty-
PostPosted: 22:56 - 29 Jul 2014    Post subject: Reply with quote
Your hint that they are not particularly exciting has not gone unnoticed. But your signature indicates that you used to ride a CB500 - you know what it's like!
Wonko The Sane
PostPosted: 23:11 - 29 Jul 2014    Post subject: Reply with quote
Would you consider the ZZR600 as an all-rounder?
Mine is currently 33bhp restricted but happily plods around all day getting me to and from work but happily jumps at the chance of being opened up - I'm assured that un-restricted the 100bhp is very usable throughout the rev range.
saves having one bike for plodding around on and one for fun.
If you do go for the 600 then a common upgrade is to fit Nissin brakes to the front to improve the braking.
have a google of zzr-international forum, helpful and friendly zzr (all sizes) specific forum
temeluchus
PostPosted: 00:33 - 30 Jul 2014    Post subject: Re: Tell me about the ZZR 1100 Reply with quote
ZZR11 has plenty of go, with a nice rich midrange so all good on that front.
provided you aren't a tool, the zzr is also civilised. Take it easy on the throttle and you'll be ok.
generally pretty reliable. Just dont miss oil changes as some have camshaft finish issues and the gearbox doesnt like old oil. Fuel economy ridden gently should be 45-50mpg on a pootle. Less if ridden harder.
Put touring tyres on, resist the urge to do rolling burnouts and double that is reasonable. It has standard 120/70 and 180/55 17 tyres so a wide range to choose from.
later the better generally but signs of good maintenance and suspension renewal is more important.
mentalboy
PostPosted: 01:45 - 30 Jul 2014    Post subject: Reply with quote
Fastasfuki.
Nowhere's far on a ZZR
Tyres won't see 5K (run it on anything other than a tourer tyre and you'll be lucky to see 4K) Front likely to need replacing at the same time as the rear.
Eats sprockets and chains
Eats brake pads
Get the upgraded 6 pots if you want to stop in a hurry
Stop in a hurry and you'll be sliding down the road
Licence taker
Eats fork oil seals
Cans rot
Eats rear suspension linkage bushes and swing arm bearings
You can sit comfortably bolt upright at 120mph
50mpg if you're a senile old twat - 18 otherwise
Goes for miles without refuelling (if you are former in above line)
Parking can be a pain as it weighs 1/4 of a ton, park it on the wrong camber and you'll need a hand picking it up
Carbs need regular balancing (500 mile intervals according to manual!)
Vibrates like hell if you don't balance carbs regularly
PITA to balance carbs on a weekly basis
Bigger PITA to do valve clearances/shims
Only Zooey Deschanel going down on you will give you a bigger grin Mr. Green
Make mine a Corona.
PostPosted: 07:39 - 30 Jul 2014    Post subject: Reply with quote
Loved my old C version. Bought it cheap (£900) and kept it for a year.
The engine was lovely, the brakes less confidence inpsiring but did the job.
I started to get electrical gremlins in the latter part of my ownerhip which is why I decided to get rid of it. First the fuel pump relay died, then the next fuel pump relay died so I just bypassed it. Then got bad connections in the loom so had to pull just about every connection apart, clean and grease.
Still a very very fast bike, even up against modern machinery. Thumbs Up
_mjs_
PostPosted: 14:14 - 30 Jul 2014    Post subject: Reply with quote
Before my CB5 the only thing I'd ridden was my 4t 125, to me it was a missile! Laughing
Not saying I don't like the ZZR11, but if I wanted a speedbarge I get the ZZR12 for more modern build
quality and looks.
jimspeed
PostPosted: 16:21 - 30 Jul 2014    Post subject: Reply with quote
Heavy bike to move around mate, if you want have a go on my zzr600 when we go on the next trip its lighter than the 11 and still got enough go for me
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
mentalboy
PostPosted: 16:30 - 30 Jul 2014    Post subject: Reply with quote
Mine'll be up for grabs in the next 6 months as I've just started emigration paperwork! Crying or Very sad
Make mine a Corona.
Tarmacsurfer
PostPosted: 18:53 - 30 Jul 2014    Post subject: Reply with quote
Lovely bikes, I've always preferred the C to the D model, less civilised and a bigger grin. Any original suspension will be shot by now, as someone else mentioned - keep on top of oil changes.
I love mine, can't envisage getting rid of it.
I'm immortal. Well, so far.
-Monty-
PostPosted: 20:06 - 30 Jul 2014    Post subject: Reply with quote
Thanks for all the replies so far Thumbs Up
I have considered the 600, yes. From what I have read it seems a good bike, but unfortunately, I am at that age where I require some willy waving. I have actually been pillion on Jimspeed's ZZR600 and it certainly felt as though it had far more go than my 500, even with 2 of us on it. Who knows, by the time November comes around I possibly will have changed my mind anyway Laughing
As for not requiring 2 bikes with the 600... I would actually prefer to have two for the piece of mind that if one refuses to start in the morning, I can still get into work Thumbs Up
temeluchus wrote:
Lots of useful stuff
45-50 MPG ridden gently sounds pretty good to me. Thats only about 10-15 MPG less than my 500 Thumbs Up
And, yes I'm sure I should be able to resist the temptation of rolling burn-outs Laughing
mentalboy wrote:
More useful stuff
Thanks for that, really helpful. I hadn't actually thought about the chain & sprockets & pads to be honest. Brake pads shouldn't be too much of an issue for me as I usually plan ahead so don't need to use brakes too much... usually. Chain & sprockets could get costly though. Won't be an every day bike though so should be alright Thumbs Up
Polarbear wrote:
electrical gremlins
That's a bit concerning for me but I suppose this is possible with any old bike (haven't had any major problems with the 500 yet though). I'm happy to spend a little more on the bike however, if it means I get a well looked after one.
quality and looks.
Oh yes, my 500 felt like a rocket in comparison to my 125 scooter when I first got it. About a year and a half down the line and a 1000 mile trip around Europe, I am hankering for MOAR!
Yes, I have considered the ZZR1200 actually. Personally, I much prefer the looks of the 1100, plus it's cheaper... Possible better build quality on the 1200 is a point to consider though.
Thats a generous offer Jim, thanks Thumbs Up I wouldn't be insured though, so we would have to accept that many kittens may die.
Bit early for me to decide just yet, but let me know when you are selling. I may be interested (won't be until November).
Yes, this is something I was also wary of. Thanks Thumbs Up
_Troy_
PostPosted: 20:12 - 30 Jul 2014    Post subject: Reply with quote
The fact that you simply won't be able to handle the powah is something to consider. This ain't no 500 twin!
Current bike: ZX6R J1
Previous bikes: CLR 125 | GS500 | ZX6R G2 | SV650
-Monty-
PostPosted: 20:40 - 30 Jul 2014    Post subject: Reply with quote
To be fair, I just want to be faster than you and "that guy" on the shit R6.
PostPosted: 20:54 - 30 Jul 2014    Post subject: Reply with quote
R1?
Aff
PostPosted: 21:13 - 30 Jul 2014    Post subject: Reply with quote
'Blade. Obviously.
Electric Bike Project
PostPosted: 21:22 - 30 Jul 2014    Post subject: Reply with quote
Aff wrote:
'Blade. Obviously.
Honda are crap.
Just sayin' Wink
-Monty-
PostPosted: 21:27 - 31 Jul 2014    Post subject: Reply with quote
Paddy. wrote:
Aff wrote:
'Blade. Obviously.
Honda are crap.
Just sayin' Wink
Yeah, to be honest Aff, your 'blade is pretty rubbish. I mean, it barely out accelerates my CB5. It's not like it even sounds that good either.
https://i1346.photobucket.com/albums/p690/monteme0/halftrollface_zpsa5e12b4c.jpeg
Aff
PostPosted: 21:28 - 31 Jul 2014    Post subject: Reply with quote
Sheeit. Trade?
wots
PostPosted: 21:43 - 31 Jul 2014    Post subject: Reply with quote
I think you forgot the other guy that was constantly pushing them along.
Again 'blade, tours beautifully, ride like a hooligan or commute on it with relative comfort and economy (I was surprised). Or as Paddy says R1, great for the long journeys, makes them effortless.
-Monty-
PostPosted: 22:36 - 31 Jul 2014    Post subject: Reply with quote
Ah yes, good ol' Neil on his SV Thumbs Up
What sort of MPG were you getting on the 'blade during the EuroJolly? From what Paddy has said in the past about his R1, it does sound a good option, as does the 'blade. I imagine insurance for both will be rather expensive though, I will have to look into this.
-Monty-
PostPosted: 22:37 - 31 Jul 2014    Post subject: Reply with quote
Aff wrote:
Sheeit. Trade?
I'm willing to, but I feel there should be money my way in addition. Just sayin'
The last post was made 12 years, 88 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 140.68 Kb
