Dishwasher installation.
DrDonnyBrago
PostPosted: 15:24 - 30 Jul 2014    Post subject: Dishwasher installation. Reply with quote
Hi all,
Another dear auntie thread reminded me I have been meaning to install a dishwasher for ages, but been putting it off.
There is a spare water outlet so that isn't an issue, the part I'm not sure about is the waste outlet. Currently have a washing machine installed, the waste water outlet hose runs to a spigot coming from just above the U-bend under the sink (as per picture).
https://www.handymanknowhow.co.uk/plumbing/wastewithspigot221.jpg
It's a rented house, owner is a bit of a cock and I'd rather not replace that single spigot jobby with a double spigot jobby if I don't have to.
I.e. I don't want to use one of these, unless I have to:
https://i.ebayimg.com/00/s/MTQ2MVgxNDYx/z/xBQAAOSww-NTz8HF/$_35.JPG
Ideal would be a Y piece to convert the single spigot into a double spigot, but I can't find one. Is this because they don't exist as they are a bad idea or just because I'm not looking very hard?
Hex
Party Boy
PostPosted: 15:28 - 30 Jul 2014    Post subject: Reply with quote
https://www.ebay.co.uk/itm/Brand-New-Washing-Machine-Dishwasher-Hose-Y-Piece-Splitter-Pipe-Joiner-/140728637838?pt=UK_Irons_Presses&hash=item20c414998e
Like that?
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
DrDonnyBrago
PostPosted: 15:31 - 30 Jul 2014    Post subject: Reply with quote
Hex wrote:
Similar, that is for the clean water inlet, rather than dirty water outlet. Found plenty like that, but none for the outlet which makes me think it must be a stupid idea.
sensi5446
PostPosted: 15:35 - 30 Jul 2014    Post subject: Reply with quote
I had the same under my sink and looked everywhere for a twin outlet so put a hole through the outside wall next to where the sink drain come out and added push fit pipes as a drainage, one going down to the drain, one going through the wall and at an angle, just shoved the drain pipe into that end Smile
Do you have 2 cold water outlets?
I used one of these
https://www.screwfix.com/p/compression-appliance-tee-brass-x-x-15mm-bsp/24030?kpid=24030&cm_mmc=Google-_-Product%20Listing%20Ads-_-Sales%20Tracking-_-sales%20tracking%20url&gclid=Cj0KEQjwr-KeBRCMh92Ax9rNgJ8BEiQA1OVm-LwQe6-BQ05iFLBMjEscDi9VRnr7z8iEmt18_bu8VFoaAs2B8P8HAQ
Hex
Party Boy
What would the difference be?
I'm sure that would fit on to mine would just need to have a screw on the waste pipe connecting to it or screw a pointy end on to the thread?
Raffles
PostPosted: 15:37 - 30 Jul 2014    Post subject: Reply with quote
Hex wrote:
That's an inlet 'Y' piece.
Have one of these Laughing
Hex
Party Boy
PostPosted: 15:39 - 30 Jul 2014    Post subject: Reply with quote
You telling me the water knows to only flow one way lol
Raffles
PostPosted: 15:52 - 30 Jul 2014    Post subject: Reply with quote
You may be able to butcher something like this in but it won't be pretty and may cause problems if you use the dishwasher and the washing machine at the same time.
DrDonnyBrago
PostPosted: 16:11 - 30 Jul 2014    Post subject: Reply with quote
Yeah I have two cold water outlets, there was a dishwasher in there at some point, but the waste outlet spigot, u-bend etc look very new so assume it has been changed to a single.
The screw on y piece wouldn't work with my push on waste hoses.
Don't fancy bodging it, Butchering pieces etc, trying to find an uber simple solution to a fairly simple problem.
Hex
Party Boy
PostPosted: 21:19 - 30 Jul 2014    Post subject: Reply with quote
Are the waste pipes fited to the dishwasher or are they screw on at the dishwasher end?
If so could you not get screw on both ends?
DrDonnyBrago
PostPosted: 23:17 - 30 Jul 2014    Post subject: Reply with quote
The waste pipes connect at a point which is hidden behind plastic etct. Prob not that hard to find out, but as yet I haven't looked. The spigot is push fit too though, so there wouldn't be a simple way of attaching it to the sink pipe without changing something. If I'm changing bits, may as well change to a double spigot.
Cheers for thoughts all, I'll look into what the minimum I can get away with pipe work wise is, prob ask about it here at some point.
Raffles
PostPosted: 14:54 - 31 Jul 2014    Post subject: Reply with quote
Hey up, Doc. I've been on an expedition into my garage this afternoon and guess what I've found?....A 'U' bend c/w double spigots similar to the second image that you posted. It's yours if you want it.
PM your details and I will send it to you as soon as I can get my lazy arse into gear.
alexknight200...
PostPosted: 15:48 - 31 Jul 2014    Post subject: Dishwasher installation Reply with quote
I have mine installed just in front of the sink, any further away and she can't reach the taps. Exclamation
I'll get me coat.
Current stable: Yamaha XVS 650 1996 - Honda Super Magna VF750 1988.
DrDonnyBrago
PostPosted: 17:12 - 31 Jul 2014    Post subject: Reply with quote
Really appreciate the offer Thumbs Up .
The bit I need should only cost £5-10, so probably not much more than the postage, plus I'm aiming to pick one up on the way home tonight.
Thanks again though!
The last post was made 12 years, 59 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.35 - MySQL Queries: 13 - Page Size: 84.13 Kb
