| phlegmatical |
 phlegmatical Two Stroke Sniffer
| Vincent |
 Vincent Banned
 Posted: 23:39 - 31 Jul 2014 Post subject: |
Is it the same if you run it on choke for a few minutes?
Some engines behave a lot differently once warmed up.
What's the mileage  ____________________ Space Is Deep |
| humanbeing |
 humanbeing Nova Slayer
| phlegmatical |
 Posted: 06:11 - 01 Aug 2014 Post subject: |
It only does it when bike is warm and my bike won't run with choke on when it is warm. It has done about 800 miles.
Sorry but where is the mix screw and how much do I adjust it? Is that the screw i adjust for idle speed? If so i have adjusted that already as it was too low and bike kept cutting out but is fine now. I'm not all that technical  |
 Posted: 06:52 - 01 Aug 2014 Post subject: |
Don't piss about with the mixture just yet. It doesn't even fit the symptoms if they are being described correctly. Taking them at face value, your problem seems to lie with the clutch. A better description of the symptoms is required.
This is a manual clutch bike - right?
You're starting it up on choke with the oil cold and riding away normally. do you ride gently when it's cold or do you set off at your normal pace?
How does the bike run on choke? Does it pull well or is it a bit lackluster?
How long from starting cold do you suffer the problem? Is It as soon as the choke comes off?
Once the choke comes off does it pull forwards but slip when you apply throttle or does it just not move at all?
Revving it until it engages is a very poor idea. It'll cause damage and lots of wear and contaminate the oil. Try to avoid this course of action even if it seems like it's curing the symptoms. ____________________ a.k.a 'Geri'
| P.addy |
 P.addy Red Rocket
 Posted: 07:13 - 01 Aug 2014 Post subject: |
When did you last change the oil?
My Keeway had minimal miles and had a horrible clutch judder... was like it was spinning at half speed then a sudden crunch. Chain was slack and oil was essentially tar  |
| phlegmatical |
| P.addy |
 P.addy Red Rocket
| phlegmatical |
| P.addy |
 P.addy Red Rocket
 Posted: 09:33 - 01 Aug 2014 Post subject: |
It is simple as long as you take it slow and read before you do it  |
 Posted: 10:44 - 01 Aug 2014 Post subject: |
So it's a manual clutch bike that rides fine for 5 miles then the clutch refuses to engage without a fight? Most unusual. Change the oil first, use medium quality semi synth 10w30 or whatever grade is recommended. See if the problem persists. The most important thing about changing your oil is to make sure you don't over tighten the sump plug. ____________________ a.k.a 'Geri'
| phlegmatical |
| Aff |
 Aff World Chat Champion
| phlegmatical |
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 12:40 - 01 Aug 2014 Post subject: |
Look for a big nut/cover on the left hand side , it may contain a wire mesh oil filter . Being a new bike you can expect bits of metal in the filter . centrifugal oil filters need cleaning far less . ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| _Iain_ |
 _Iain_ Banned
| phlegmatical |
 Posted: 20:23 - 02 Aug 2014 Post subject: |
As I've said so many times before, if you put your location in your profile you might find someone close by who could take a look. ____________________ a.k.a 'Geri'
| phlegmatical |
| CestrianX |
 CestrianX Renault 5 Driver
The last post was made 12 years, 72 days ago. Instead of replying here, would creating a new thread be more useful? |
