| trevor saxe-coburg-gotha |
| _Iain_ |
 _Iain_ Banned
 Posted: 15:04 - 01 Aug 2014 Post subject: Re: how come 2t bikes are often harder to start? |
| trevor saxe-coburg-gotha wrote: | So why *are* the smokers often more reluctant?? |
They aren't really.
My CR started pretty much first kick every time at the BBQ. Apply around 1/8-1/4 throttle, starter down slowly, big kick and off it goes.
H100 again, full choke, bit of throttle, big kick and it'd usually cough and splutter into life. If it diddn't a 2nd kick would usually get it going.
G's KTM 144 EXC, kickstart down slow, 1/4 throttle, big kick and straight away fired. Took a few attempts to get it going after Nemo fell off it and flooded the motor mind.
Paddy's TTR supermoto thingy? No way could I get that going, that was four stroke. He seemed to do it in a single kick.
I suspect it's most likely lacking in technique, you've got to find that sweet spot on the throttle to get it to fire first kick I found.  ____________________ Please be aware that the above post may be full of complete nonsense.
| N cee thirty |
 N cee thirty Banned
| stevo as b4 |
 Posted: 15:15 - 01 Aug 2014 Post subject: |
What Iain said, and it's kick start 4 strokes that are hard to start never first kickers.
I think it used to take more than 2-3kicks to start even my old CG125 when it had been left a week unused. All my KMX's were often 1st or 2nd kick starters generally, unless they became flooded, I ran out of fuel, or like on my old 200, when I had dirt in the tank causing a mixture of flooding and fuel starvation at times.
I'd love to see some BCF'ers with big 4strokes post up 1st time starts, I bet there's not more than 2-3 at the most!  |
| Baffler186 |
 Baffler186 World Chat Champion
| smegballs |
 smegballs World Chat Champion
| _Iain_ |
 _Iain_ Banned
| Teflon-Mike |
 Posted: 20:10 - 01 Aug 2014 Post subject: |
Theoretically, two-strokes shouldn't start at all!
A piston ported 2T has symmetrical port timing; so piston rises, port's opened, letting charge get sucked into the crank-case; but as the piston falls again... ported by the piston, it will remain open all the way back down again... and everything that got sucked in OUGHT to get squashed back out!
Reasons a two-stroke runs at all, is down to a thing called 'trapping efficiency'; if you design the inlet tract to have better forwards flow than backwards, you get a bit of charge trapped in the crank case and might get the thing to work; add a flap valve, like a pair of fire bellows, though and you can hugely increase this trapping efficiency,
Four-strokes, with positive and asymetric 'poritng' via mechanically controlled valves, dot suffer any where near as much, but, there is an interval at the end of the exhaust stroke and the beginning of the inlet when both valves are open at the same time, and exhaust gas buggering off down the pipe can suck fresh charge with it, or bur it off, before it has a chance to get used.
This gets worse, the more highly tuned an engine is; as there will tend to be a larger interval of 'over-lap' and valves will tend to be pushed further open during it.
Highly tuned 4T's can be a total bastard to start...
So can highly tuned 2T's.
And you aren't really comparing like with like... CRM is a highly tuned race engine... W650 is, err... not!
BUT... and here in I suspect is your problem....
when a 4T is turned off, the piston will tend to stop half way up on the compression stroke, when there is most resistance against it, and the valves are both closed.... your spark plug is the sat, while the bike dormant, in sealed chamber full of oil, fuel and air.
When a 2T is turned off... piston will stop half way up the compression stroke, when there is most resistace against it... BUT, having 'run into the buffer' of compression... a two stroke engine can turn BACKWARDS.. 4T's dont tend to like this, and the resistance of cams and valves and stuff, as well as plain bearings sort of stop it happening, but on a 2T... the piston will hit the compression, then bounce back, and it will stop, when it has vented whatever compression it made, when the exhaust ports open...
This means that your spark plug, when the bike is laid up ISN'T in nice almost hermetically sealed chamber with a little air and a bit of oil and fuel floating around... its open to the atmosphere....
Vented to atmosphere, iron piston rings tend to corrode into the alloy piston grooves, loweing fire up compression, while the spark plug will gain a layer of corrosion.
Usually 2T's due to lower frictional losses will tend, for the same state of tune, to start more readily than a 4T, especially as you can swing them through a couple of cycles for the same kicker effort...
But, if laid up... could probably do with the plug popping out and a quick clean, to make sure it delivers good sparks, and a couple of kicks through while its out, to free up the rings and get a bit of lube on the bearings and bore, before you pop plug back in... and with 'the knack'... ought to start just like it had been running yesterday... Give it a go. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Irn-Bru |
 Irn-Bru World Chat Champion
| Fladdem |
 Fladdem World Chat Champion
 Posted: 22:34 - 01 Aug 2014 Post subject: |
| Irn-Bru wrote: | Many years ago when my brother had an rx50 he could easily start it from cold by hand on the kick start, or by walking and letting the clutch out slowly in 1st. Thinking back it was probably not smart, wonder if a 50 could still break yer wrist? | ~
Used to start my 50 by hand sometimes. I got kick back once when I kept booting it and got frustrated with it, she didn't like that so bruised the bottom of my foot for me. That hurt, can't imagine a bigger bike kicking back.
My cub nevers goes first boot, my MT5 will, in fact tomorrow I last started her 3 months ago, same with the cub, I'll get them both out at the same time and film it for you to compare. We'll see how many kicks it takes each, clearly this will be scientific. ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
I'm having more fun than a well-oiled midget. |
| G |
 G The Voice of Reason
 Posted: 23:24 - 01 Aug 2014 Post subject: Re: how come 2t bikes are often harder to start? |
Remember a 2 stroke needs to get (maybe fresh?) fuel through the cranks and into the expansion chamber.
How's the rings etc?
I've certainly had it where one that's not been used for ages wouldn't fire up without a load of hassle (cue me being towed by a landrover on a pampera), but once it's been going for a bit, been fine.
While 4 strokes are often the opposite - my Husaberg would fire up ok from cold, but I once spent half an hour trying to get it to catch from hot, until I gave up... and took a pampera out, I think . |
| Teflon-Mike |
 Posted: 02:13 - 02 Aug 2014 Post subject: Re: how come 2t bikes are often harder to start? |
| G wrote: | Remember a 2 stroke needs to get (maybe fresh?) fuel through the cranks and into the expansion chamber. |
That's a thought too, innit; Does the CRM drink Pre-Mix or is it force lubed?
Never really think about it, the cota is a Pre-Mix drinks, and its second nature after thirty years to do the pre-start shake, sloshing fuel about the tank to re-mix it, and gauge how much is in the tank.
In 'towlden Deeez.. they used to make up "petroil" with vegetable oil.. I actually have a recipe in my Cota's owner's book for it! It's something like 15cc's of washing up liquid, to 500cc of vegetable oil, then 30cc of oil+detergent to a litre of petrol! Then gave suggestion how to adjust the ratio's if you used mineral oil instead of vegetable oil. Intreguingly,.... IT WORKS
BUT, way back when; you could buy 'Castrol-R', which was a blended vegetable oil based oil for 'total loss lubrication systems'.. Blokes that ran 4-strokes on methanol used to use a little in the fuel like a two-stroke, due to alchohol not having the additives mineral based petrol did to lube valve guides and stuff, or in 'drip feed' total loss lube systems, where it's light enough to burn off...
Allegedly, it has a certain odour, and modern blended two-stroke oils have perfuming agents in them to make them smell a bit like Castrol-R...
HOWEVER... being vegetable based, it was very miscible in methanol; but, in mineral based petrol, it wasn't... it'd 'mix' but it didn't like it much, you get an 'emulsion' and like Salad dressing, left the oil and petrol will separate out... one of the reasons for adding the washing up liquid, was not so much to act as a 'detergent' to help clean away carbon deposits (though apparently it does a little), but to act as an emulsifier and try and keep the oil in suspension in the petrol.
Modern blended, synthetic or semi synthetic mineral based two-stroke oils are a lot better, and are a lot more miscible, but, it's still a mixture, not a solution, the oil dissolved in the petrol, and the lighter fractions will rise to the top of the tank, the heavier ones sink to the bottom.
Hence the two-stroke pre-start shake! Maybe something else you might like to try....
First fuel into the float bowl could be a bit oil rich. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Fladdem |
 Posted: 18:21 - 02 Aug 2014 Post subject: |
Played with the mopeds today, just before the rain came in.
It seems like a fair test in my mind, both are low stressed air-cooled engines, similar capacity and both Honda.
I got my dad to start the cub, he has ridden it more than me and has the knack better than me, equally, I started the MT5 because I have the knack for starting that easier.
I had to put some fuel in out of my TTR 250 tank, into the 50, because I had ran it dry before storing it because I was going to start stripping it down to stick the H100 engine in it.
In all fairness to the cub, it would have gone in two or three kicks but we snapped the kickstarter on the first attempt.
We filmed it, we had about 30 minutes of footage that I edited down to about 9 minutes, if anyone is interested in wasting that much time on two idiots, well three, my uncle, the one who gave me my GPZ turned up and messed about with us.
The results are surprising and brought back my lust for a smoker.
https://www.youtube.com/watch?v=nF7i5AUc5BE&feature=youtu.be ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
| Teflon-Mike |
 Posted: 19:11 - 02 Aug 2014 Post subject: |
How to turn a normally mature, responsible, grumpy middle aged man, into a blithering, irresponsible, grinning idiot.......
"D-a-a-a-d..... I cant get my moped to start!"
I remember vividly, aged about ten, having abandoned my pedal & pop on the drive in a pique, hearing the tones of a tortured two stroke, in the back garden... as I bounded out to find out what had happened, I had a brief glimpse of my Grandad wobbling up the garden path, stood on the saddle, arms akimbo... followed very shortly after by a scream of revs, and a crunch.... I tore up the drive to find out what was wrong, to discover bike wrapped around teh cristmas tree, Pops wreathing on the floor.. clutching his belly... I was about to tear off inside to call an ambulence when he stood up, and stammered.. "S'all right... 'm only laughing!"
Groan-ups... MAD as hatters. Decided it must be something to do with alchohol  ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| P.addy |
 P.addy Red Rocket
| tony_d123 |
 tony_d123 Nitrous Nuisance
| CHR15 |
 CHR15 Turbo nutter bastard
 Posted: 10:19 - 03 Aug 2014 Post subject: |
people dont know how to use a kickstart properly. ____________________ Turbocharged drag thing / project death weapon / GK73A
Ste: I'm not entirely sure how you'd go about verbally abusing someone with a potato but I'm sure it's possible. |
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 21:37 - 03 Aug 2014 Post subject: |
Okay - think I've sussed it. Wheeled 'er out this evening to go for a play on a nearby quad bike course someone's set up (I'm not meant to use it but eh, I'm quick, clean and quiet so...) and was prepared for a bit of a right foot work out due to not riding it for a fortnight (see OP).
Here's what I did: turned tap to 'on', choke lever right down, walk away from bike. Go upstairs, faff around with vape recharger, yell at t'kids for a bit, go for a quick slash, get me clobber on, etc. etc.
So when I come back to the crm it's been a good ten minutes since the tap;s been turned. Started third go. Difference being that previously I wheel it out, turn tap, set choke, kick. Nowt. Nowt again. Nowt, nowt, nowt, etc. etc. THEN it fires. But tonight was different - it's as though the priming time is minutes rather than mere seconds, or something. Dunno.
Obviously it's a bit early to know if simply leaving it with the tap open for a while is "the knack" - but I'm cautiously optimistic that this really is all there is to it. Anyway, in other news, it ran bloody well tonight - and seems to improve with each outing. Smoother, quieter, more tractable in second over the humps and ruts, and just generally a happier feeling bike all round. I am liking. ____________________ "Life is a sexually transmitted disease and the mortality rate is one hundred percent."
Mobylette Type 50 ---> Raleigh Grifter ---> Neval Minsk 125 |
| G |
 Posted: 21:54 - 03 Aug 2014 Post subject: |
4 stroke dirt bikes tend to have 'accelerator pumps' - often you'll give a couple of flicks of the throttle before starting to dump some fuel through.
This gives you an idea - https://www.youtube.com/watch?v=ZbzBbLYeATw .
Oh and (If I haven't said it already and you haven't done it - got a feeling you had) I would strip the carb and clean out each jet indivdually. No need for ultrasonic cleaning generally - as you saw at last year's BBQ, using your mouth and possibly a small bit of plastic from a washing up brush or similar should do it. |
 Posted: 05:30 - 04 Aug 2014 Post subject: |
Yeah carb's been off and blown through. That and the new plug were what cured the stalling problem that was the cause of my three hour journey taken to cover the 10 miles from the seller's place to mine. Incidentally, Mr. Rafferty's in york that did it for me has still yet to give me an invoice for this, despite the fact that I ride in most weeks, buy him a coffee and ask him for the bill. Would've done it myself but you weren't here with headtorch and large canine accomplice, without which my abject spannerphobic tendencies would have led to an inevitably regrettable outcome.  ____________________ "Life is a sexually transmitted disease and the mortality rate is one hundred percent."
The last post was made 12 years, 88 days ago. Instead of replying here, would creating a new thread be more useful? |
