Foreign object in fuel tank.
Cadbury
PostPosted: 05:53 - 04 Aug 2014    Post subject: Foreign object in fuel tank. Reply with quote
So, I'm an idiot -
98 Fazer 600, Full tank of fuel, decided to put some redex in (as I usually do every other tank) pop the fuel cap, unscrew lid from redex, it slipped out of my hands... Plop! Straight in the tank. Any suggestions on the best way to get it out? How much damage will it actually cause in there?
Many thanks.
el_oso
PostPosted: 08:31 - 04 Aug 2014    Post subject: Reply with quote
I'd probably drain the fuel, take the tank off, turn upside down and shake away.
Duke 390
Car: Jeep Wrangler 4.0L
c_dug
PostPosted: 09:18 - 04 Aug 2014    Post subject: Reply with quote
I wouldn't think it would do much damage to be fair, I'd ride this tank of fuel until it is near empty, then do as above.
GeorgeB.
PostPosted: 09:21 - 04 Aug 2014    Post subject: Reply with quote
But won't the higher amount of redex cause damage?
Current: '99 Fazer 600 | '99 Range Rover P38 4.6 HSE
Previous: Keeway TX125 | CBF 125 | CB400SF Project Big One
CBT 04/12/12 | Theory 03/12/13 | MOD 1 06/01/14 | MOD 2 13/01/14
Hetzer
PostPosted: 09:35 - 04 Aug 2014    Post subject: Reply with quote
I think he dropped the cap in, not the bottle.
Baffler186
PostPosted: 09:38 - 04 Aug 2014    Post subject: Reply with quote
I'd get it out as soon as you can if it were me - not that I'd think it could damage something, but more it might float or sink and block your fuel supply or breather or something?
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
Cadbury
PostPosted: 09:40 - 04 Aug 2014    Post subject: Reply with quote
It's just the lid from the bottle, I think it's floating, I can hear it knocking into the sides of the tank. It doesn't want to float its way to the filler hole though Sad
CaNsA
PostPosted: 09:51 - 04 Aug 2014    Post subject: Reply with quote
If the cap was left in there, would the petrol start to break it down?
Tungtvann
PostPosted: 09:54 - 04 Aug 2014    Post subject: Reply with quote
Maybe if it were made of bread. Plastics are pretty resilient to fuels as far as I know.
Aff
PostPosted: 10:00 - 04 Aug 2014    Post subject: Reply with quote
Most are, although I think most bottle caps are made from Polypropylene which will melt fairly fast.
Although I imagine it will probably be HDPE seeing as it has to hold the ATF (Redex) in.
OP why are you putting Redex in your tank?
Electric Bike Project
Aff
PostPosted: 10:29 - 04 Aug 2014    Post subject: Reply with quote
_Iain_ wrote:
As in automatic transmission fluid? Hydraulic oil?
Can't be surely? The last lot of ATF used was in my previous Volvo's front shocks & was fairly thick stuff. The last time I used redex it was very watery, same sort of thickness as white spirit/parrafin.
Could be one of the major components of for sure, and I still don't think it really does anything, but I'm not sure it's 100% ATF.
I read into it a while ago, IIRC it's mostly a petrol/ATF mix then marked up 10 times.
It's fairly common to put 2 stroke or ATF in diesels. It burns hotter, supposedly cleaning injectors and adds some lubricant to the fuel pump.
dydey90
PostPosted: 10:42 - 04 Aug 2014    Post subject: Reply with quote
A quick look on amazon suggests the smallest fishing nets are around 2.5" diameter, which wouldn't fit.
You could make a net using some bent wire and the material from one of those body polisher things that women always seem to keep in the shower?
MaybeGuy
PostPosted: 11:24 - 04 Aug 2014    Post subject: Reply with quote
get it 3/4 full and use chopsticks?
Maybe use a lighter to see where it is in the tank.
PostPosted: 11:28 - 04 Aug 2014    Post subject: Reply with quote
https://www.tecratools.com/media/productImages/22180.jpg
CaNsA
PostPosted: 11:30 - 04 Aug 2014    Post subject: Reply with quote
I was thinking about that, but it depends if you can see the object.
Cadbury
PostPosted: 11:38 - 04 Aug 2014    Post subject: Reply with quote
Got one on order from amazon Thumbs Up hopefully I'll be able to get to it without removing the tank.
joshuaHolden
PostPosted: 14:47 - 04 Aug 2014    Post subject: Reply with quote
I did the same thing except it was my ignition key, fixed it with some chewing gum and a stick, be aware it may be better to use blutack as the chewing gum went very sticky in the petrol but it worked a treat.
Baffler186
PostPosted: 14:53 - 04 Aug 2014    Post subject: Reply with quote
Removing the tank is not that hard - I've done it a couple of times (once to fit a new reg/rectifier). You could then just drain the fuel, open the fuel filler cap, tip tank upside down and rattle the lid out. If it went in, it'll come out!
Robby
Dirty Old Man
PostPosted: 16:21 - 04 Aug 2014    Post subject: Reply with quote
Ignore it. It won't do any harm.
mentalboy
PostPosted: 16:41 - 04 Aug 2014    Post subject: Reply with quote
... just don't make a habit of it, unless you want to sound like a tinker!
Make mine a Corona.
clancy
PostPosted: 22:15 - 04 Aug 2014    Post subject: Reply with quote
Massive thin pliers, like the sorts for getting hose clips off on cars, should fit a thin pair into the tank opening
KLX 300r
Cadbury
PostPosted: 11:23 - 05 Aug 2014    Post subject: Reply with quote
Well, I got it out in the end.
After it tauntingly floated past the tank opening several times, I just couldn't get at it. Took the tank off, drained it, then spent a good 15 minutes trying to jiggle the tank and coax it out.
Thanks for everyone's advice. Lesson learned - don't use Redex Very Happy
ZRX61
Victor Meldrew
PostPosted: 19:00 - 13 Aug 2014    Post subject: Reply with quote
Ignore it... or use the Ovary Snatcher.
They're not one night stands, they're auditions.
sidewinder
PostPosted: 09:50 - 14 Aug 2014    Post subject: Reply with quote
Won't the plastic cap float in the tank? If so just slosh it round till you see it Thumbs Up
The last post was made 11 years, 140 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 125 Kb
