| staningrimsby |
 staningrimsby Renault 5 Driver
 Posted: 20:27 - 03 Aug 2014 Post subject: U-Turn Info |
Just a quick one please folks,
After my Mod 1 failure last week for putting my foot down during the U-Turn I have been racking my brain as to why it happened as other than that everything else was fine I have done the U-turn loads of times with no problems.
The only thing I could think of was that I did my checks prior to moving off then pulled away slowly, checked again before starting the turn, now I am not sure if I was going to slow thus losing balance or I tried turning to soon after checking again losing balance so my question is if I don't do the shoulder check prior to the turn does that go down as a minor or is it a fail ???
As I cant think of any other reason that my foot went down, going out to practice again tomorrow but its on my 125 and its totally different then the 650 I was on but I do want to be ready when I eventually get a re-test date again  ____________________ When you have removed the impossible the improbable however unlikely has to be the truth.
1986 Yamaha DT 80 >> 2009 Honda Varadero XL 125 >> 2003 Suzuki V-Strom 1000 |
| NooBish-AbbZ |
 NooBish-AbbZ Nova Slayer
| malteser273 |
 malteser273 Two Stroke Sniffer
| gavbriggs |
 gavbriggs Crazy Courier
| Boxing |
 Boxing World Chat Champion
 Posted: 20:33 - 03 Aug 2014 Post subject: |
Look ahead rather than at the front wheel / down. Look to where you want to go. It's about planning ahead, and you won't lose balance, if that makes sense.  |
| staningrimsby |
| map |
 map Mr Calendar
 Posted: 20:36 - 03 Aug 2014 Post subject: |
Many threads on here to help with u turn.
Like this one.
Best advice is to look where you're going, not at the wheel.
Best of luck. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| Wildmalta |
 Wildmalta Two Stroke Sniffer
| staningrimsby |
 Posted: 20:56 - 03 Aug 2014 Post subject: |
I don't get chance to practice on the big bike Im sad to say, the next time I ride it is on re-test day  ____________________ When you have removed the impossible the improbable however unlikely has to be the truth.
| staningrimsby |
| Wonko The Sane |
 Wonko The Sane World Chat Champion
 Posted: 21:23 - 03 Aug 2014 Post subject: |
Your vara is a small twin with a fair bit of lazy 'power' (by power I mean the ability to move forward)
when practising for my tests I was setting off from the brake stop line to do my run in 2nd without my instructor realising
I was also able to set off on my vara in 1st or 2nd just slipping the clutch a bit. The bike's low weight helps.
With the 600+cc bike you're able to move it around on tick over with the clutch being slipped a bit, however when you want to add the power in the bike doesn't pick up and move forward straight away, it takes a moment or two for the engine to spin up and the bike to get on with it,
My guess is, where on the vara you can just add a bit of throttle and go the bigger bike is struggling for a moment causing you to put your foot down.
What you need to do is, while still slipping the clutch, add some power in before the turn so that it's there ready for you to use, controlling the bike's speed on the clutch (and a dab of rear brake if needed) this way you're not waiting for the engine to get ready, it's there for you to use as little or as much as you need on the clutch
hope that makes sense / helps ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
They're also on Facebook https://www.facebook.com/pages/Focus-Rider-Training/196832923734251 |
| staningrimsby |
 Posted: 21:30 - 03 Aug 2014 Post subject: |
I know what your saying Daffyd I really need to find a nice steady RPM range before I start moving then control the bike from there with the clutch and the rear brake.
Its not the best of bike Im learning on though sime Chinese machine called WK 650i, the gears are awful on it takes ages to clunk through them for a bike that's only 2 years old as well  ____________________ When you have removed the impossible the improbable however unlikely has to be the truth.
| Wonko The Sane |
| mailee |
 mailee Spanner Monkey
| Llama-Farmer |
 Llama-Farmer World Chat Champion
| staningrimsby |
 Posted: 10:04 - 04 Aug 2014 Post subject: |
Well Guys I thought I would pop out for a couple of hours on my baby Vara this morning before everyone got up and practice a few u-turns.
I started off in a pub car park using the width of 3 bays which is roughly 7.5 mtrs, then moved to the road where we did our CBT u-turns then once again back to a car park in Cleethorpes, all told I must have done around 60 u-turns and not an issue with any of them .
Going to go out again later just hoping I don't bottle it on re test day. ____________________ When you have removed the impossible the improbable however unlikely has to be the truth.
| dydey90 |
 dydey90 World Chat Champion
| Pol Anorl |
 Pol Anorl Banned
 Posted: 11:59 - 04 Aug 2014 Post subject: |
Its the whole check mirrors then turn round to face the front and clutch and throttle and brake and soo much shit!!
in the real world you say fuck it, pin the throttle spin the rear wheel around. job done. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
20:30:37 Pyro.: I don't sort of like men, I take every advantage to choke on dick.
Jewlio Iglesias: You live in Liverpool - Chances are, the front door has already been kicked off the hinges |
| staningrimsby |
 Posted: 19:46 - 04 Aug 2014 Post subject: |
Well Guys and Gals,
Been out for a couple of hours tonight to try and fathom out the problem I had on my Mod 1 test, I started in a car park again and had rather a lot of attempts (all good may I add).
Then I went on to the street and various other car parks still all going well , so it was killing me as why was I so bad on the test I have done well over 100 U-turns today on my 125 and all have been perfect. Whilst this is a good thing its annoying not knowing why it went pear shaped last week.
So on the way home I had to nip to Morrisons still thinking what went wrong ??? then I wondered was it because the fence of at the test centre was in front of me and it was another obstacle I was faced with that I had not experienced ??? As I was leaving Morrisons I saw the entrance that the wagons go through (2 huge gates), I measured the road with my tape measure a good 8 meters.
So I measured away 6.5 meters from the kerb (I realise I am allowed 7.5 but thought if I can do it in 6.5 then the test centre should have acres of room) and placed a cone then placed another cone about 8 meters from the first. So with the gate in front of me it simulated the U-turn area at the test centre, also it was on a bit of a hill which meant when I went back up if I didn't have enough revs it made me power out rather than put my foot down
https://i600.photobucket.com/albums/tt88/staningrimsby/Motorbikes/Honda%20Varadero%20125%20v9/U-TurnPractice.jpg
All in all I have done over 100 U-turns today with not a single error, just hoping its the same when my re-test date comes through. ____________________ When you have removed the impossible the improbable however unlikely has to be the truth.
| Howling TerrorOutOfOffice |
| gavbriggs |
| parkmoy |
 parkmoy Scooby Slapper
The last post was made 12 years, 31 days ago. Instead of replying here, would creating a new thread be more useful? |
