Honda CBR 125 '11 Gear selector lever being funky.
RockandGrohl
PostPosted: 00:21 - 04 Aug 2014    Post subject: Honda CBR 125 '11 Gear selector lever being funky. Reply with quote
I'm finding it really hard to change gear, well much harder than it should be, and today I managed to change from 4th to Neutral at 50mph which wasn't much fun.
It feels like, imagine there's a point at the top of the lever's movement, where it'll clunk into the next gear. It feels like most of the time, recently, I've been struggling to reach that point, like the gear lever is -just- before the point and won't physically move any higher. Sometimes if I wiggle my foot while pulling up I can get there, but by then I've lost any forward momentum while my engine has been disengaged.
A lot of the time if I change gear up and don't wiggle, I just let release the clutch, move foot back down and pull on the throttle again (all at once) like a normal gear change, it will do.... hard to explain... I'll move half a gear up, and then I get it dropping back down a gear again with the sudden jump in revs.
All this behaviour happens mostly when I'm at a higher revs - accelerating from a 30 into a national speed limit section, for instance.
Can anyone shed some insight? Thanks.
DrSnoosnoo
PostPosted: 11:07 - 04 Aug 2014    Post subject: Reply with quote
Adjust your gear selector. Did you know you can do this? Set it lower slightly and it should sort your problems.
Aff
PostPosted: 11:09 - 04 Aug 2014    Post subject: Reply with quote
And check your clutch is adjusted properly.
Electric Bike Project
gavcarter
PostPosted: 11:22 - 04 Aug 2014    Post subject: Reply with quote
clean and grease the lever and linkages, especially the pivot points
CBRMAN94
PostPosted: 00:14 - 05 Aug 2014    Post subject: Reply with quote
Check your chain isn't too tight/slack. CBR125 gearboxes can be very sensitive to it and i've had a few false neutrals caused by it. Also i don't think the selector can be adjusted
Honda CBR-RW6 (Sold) - Kawasaki GPZ500s (Sold) - Honda CG125 (Project) - Honda CB750 Cafe racer (Project) - Yamaha FZR400RR
InquisitionCh...
PostPosted: 10:29 - 05 Aug 2014    Post subject: Reply with quote
Ive had this too on my '07 CBR125. From 5th, I cant get it down to 4th and below if I brake hard beforehand. It can be a pain but i find gently letting the clutch in and out to the biting point while trying to shift up or down. Seems to just pop into the gear you want.
Ive had new tyres recently so I doubt its my chain. Ill take it to my local shop and see what they say Smile
RockandGrohl
PostPosted: 11:31 - 05 Aug 2014    Post subject: Reply with quote
Yeah sometimes I get this with changing my gear downwards, if I'm braking, changing down feels spongy, like there's no feedback. My gears will change down with the occasional false neutral (maybe once a fortnight?) but there's rarely a satisfying clunk.
The last post was made 12 years, 73 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.72 - MySQL Queries: 13 - Page Size: 53.66 Kb
