Ban Surface Dressing Roads
FriendlyEllis
PostPosted: 06:02 - 05 Aug 2014    Post subject: Ban Surface Dressing Roads Reply with quote
You know.... Country road...lovely day..... Oh no...... They've smeared it in tar and spread piles of gravel all over it.
Stone chips and heart stopping bends!!
Sign the petition....maybe! Very Happy
https://epetitions.direct.gov.uk/petitions/67408
Honda CB600F Hornet 2013 -> Kawasaki Z1000SX ABS Tourer 2015
Moo.
PostPosted: 07:40 - 05 Aug 2014    Post subject: Reply with quote
Saw they,d written about this in the MCN paper too. Hate the stuff and those ridges you get soon after..
A2 Passed 18/6/10
grr666
I agree, these roads are lethal for cyclists (motor and otherwise) and not great for
the water based paints we have on our cars now either.
The front of my car looks like I spend all my time trying to push people along down the road.
So it's ok if it damages our vehicles and causes accidents just so long as it saves them a few quid
doing the roads properly.
andyscooter
PostPosted: 07:43 - 05 Aug 2014    Post subject: Reply with quote
i just give the roads a miss for a few days
there is always signs saying whats being done
doggone
PostPosted: 07:53 - 05 Aug 2014    Post subject: Reply with quote
It's an important maintenance task, which seals any surface cracks and prevents water getting in and creating potholes.
A 'proper' layer of tarmac is not a durable or grippy wearing surface. The tar and grit top layer is only unpleasant to travel on for a couple of days. It is worse if they are trying to do it in hot weather though.
PostPosted: 08:01 - 05 Aug 2014    Post subject: Reply with quote
It works much better in hot weather than it does when it's cold and wet.
OP, have you got experience and knowledge with road construction and so have a viable suggestion for what would be better than surface dressing?
If surface dressing wasn't done and then rather predictably the condition of the roads got worse, I'd be willing to bet that online petition people would be the first to be bawwing their eyes out. Rolling Eyes
Shinigami
PostPosted: 09:07 - 05 Aug 2014    Post subject: Reply with quote
at least they've put something down, we have holes as big as a car on the roads here Laughing ...including on the motorways
iooi
PostPosted: 09:47 - 05 Aug 2014    Post subject: Reply with quote
doggone wrote:
A 'proper' layer of tarmac is not a durable or grippy wearing surface. .
So if that's the case.... Why do they not surface dress ALL new road surfaces then....... Embarassed
Funny but round here due to the Tour De Farce we got most of the route re-laid with lovely new smooth tarmac.... Not a hint of surface dressing.
kramdra
PostPosted: 09:58 - 05 Aug 2014    Post subject: Reply with quote
Bleh, I dont like it, but poor obs! Ive hit it several times doing 70mph after forgetting the loose chippings sign.
I will say that the roads they have done this year and last, they are quite nice now the loose grit is mostly gone. They are not falling apart as I expected, after seeing the roads a couple years before.
The Artist
PostPosted: 10:05 - 05 Aug 2014    Post subject: Reply with quote
I don't know the exact costs involved but surface dressing is going to be an order of magnitude cheaper than fresh tarmac and it isn't that bad. They don't tend to do it on main roads anyway.
clancy
PostPosted: 10:06 - 05 Aug 2014    Post subject: Reply with quote
Oh really... not durable and grippy?
And it is extremely rare to find tarmac being used anywhere in the UK anymore it's basically all asphalt
Anyway, this surface dressing is not cheap which is why I don't understand why they do it. The best thing to do is relay the surface or surface and binder if it's damaged already. This can be done in a very small time scale so it's not like that's a real issue. Far better durability and value for money for road repairs
KLX 300r
smithyithy
PostPosted: 10:21 - 05 Aug 2014    Post subject: Reply with quote
Surface dressing is around £8/m2, asphalt (45mm, no binder) is around £50/m2.
Plus if you're inlaying, the old surface has to be planed out.
TM is also cheaper as it can be trafficked sooner.
Yes it's annoying, but it's cheap, and a quick fix.
Also once it's swept, you have a proper grippy surface almost immediately, unlike asphalt that needs the top layer to wear off before the stones are exposed.
Ideally we'd relay all roads with HRA (hot rolled asphalt), that's the older, louder asphalt you find on parts of the motorway, cause it lasts for up to 20 years and is bloody tough, but due to noise and other silly environmental issues we have yo use SMA / thin wearing course now which is the newer asphalt that barely lasts 8 years without peeling apart.
You might be glad to know that the Highways Agency are trying yo reduce the amount of antiskid we use on new schemes now due to the cost and wear of it, instead we're opting for asphalt with a higher PSV (polished stone value) for things like slip roads and approaches to roundabouts etc.
It's a very technical industry and not always a simple case of 'sign this online form to ban a cost-effective road maintenance technique because it's slightly inconvenient' lol
MarkJ
PostPosted: 10:26 - 05 Aug 2014    Post subject: Reply with quote
A few roads around the Glossop/Snake Pass area were done years ago. The road that connects Woodhead Pass to Glossop was done, and there are a few corners where all the chippings have been taken up by the cars, so you get two shiney tram tracks on some corners with bugger all grip in the wet Thumbs Down
It's OK on straights I suppose, but no fun when it's just been laid.
Rowey
PostPosted: 10:28 - 05 Aug 2014    Post subject: Reply with quote
Aren't they meant to use a roller to embed the chippings in to the tar? A quick sweep after to clear the loose bits, and there'd be no problem.
They're just lazy, or saving money and expect the traffic to do it for them.
ZX6R C6F.
PostPosted: 10:29 - 05 Aug 2014    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=287899&highlight=surface+dressing
chickenstrip
PostPosted: 11:17 - 05 Aug 2014    Post subject: Reply with quote
I don't know enough about surfacing and repair techniques to comment really. It is really annoying when you go to one of your favourite roads only to find this surface dressing has been done, but it does seem to eventually settle into a nice surface. But it takes more than a couple of days I'd say.
But this petition's wording is a bit pathetic. It's just a general uninformed whinge, presents no facts or statistics to show why it shouldn't be used, and doesn't really give any reason for stopping the technique other than " I don't like it! Crying or Very sad "
NooBish-AbbZ
PostPosted: 11:45 - 05 Aug 2014    Post subject: Reply with quote
We've had one done near us recently. Avoided it for a week or so and the surface isn't too bad now; still take it a bit easy though.
However, when wanting to overtake, the surface in the middle of the road is still terrible.
SV650S - Feb '14-March '19
XJ6N- Apr '19 -Present
malteser273
PostPosted: 11:46 - 05 Aug 2014    Post subject: Reply with quote
I think I can see both sides, its cheap, quick and after its settled the roads are usually pretty good.
but it does seem like it takes a couple of weeks for it to get properly swept. Its like they do half a job and expect the rest of us to finish it off for them
Honda Hornet 600
FriendlyEllis
PostPosted: 12:43 - 05 Aug 2014    Post subject: Reply with quote
Surface dressing isn't the best option. It's the cheapest. If they need resurfacing they should grind it and re tarmac properly. I'd rather them close them for a week or 2 for proper repair, than have weeks of nervous riding afterwards because of the banks/strips of gravel.
Islander
PostPosted: 12:46 - 05 Aug 2014    Post subject: Reply with quote
They've just done about a mile of the single track that leads up to our house and it's turned a damaged road with a badly cracked surface with incipient potholes into a decent road again.
Local authority budgets have been cut to the bone - they simply can't afford to plane the old surface on and replace it with new - this method keeps the roads usable and provides decent grip.
I won't be signing what is basically a NIMBY whinge. I like my roads to be maintained thanks. Thumbs Up
FriendlyEllis
PostPosted: 12:52 - 05 Aug 2014    Post subject: Reply with quote
It's not NIMBY because nobody is saying don't repair roads in my area. Just not using piles of gravel. You're right, a repaired road is better than none at all.
Perhaps if they just rolled and swept them afterwards?
doggone
PostPosted: 13:04 - 05 Aug 2014    Post subject: Reply with quote
Exactly, reality is if they are forced to practically rebuild the surface agian they will only be able to afford to get around about 10% of what can be done reasonably successfully now.
We hear the same winge every year because they have to do it when it's warm and dry - so people think it must be a deliberate tactic to delay the summertime pleasure jaunt.
smithyithy
PostPosted: 13:23 - 05 Aug 2014    Post subject: Reply with quote
Again, it's down to cost.. Traffic management makes up a decent bulk of maintenance schemes, they already save by surface dressing in a day or 2 with a partial closure as opposed to a full closure that inlaying usually requires.
And again, part of the saving is that the traffic roll the surface, which saves on time and TM costs. Then they come back and sweep it once, not 5 times. It's a 'bare minimum' treatment, but as mentioned correctly above - any treatment is better than no treatment.
Islander
PostPosted: 13:32 - 05 Aug 2014    Post subject: Reply with quote
Our lot sweep the road a couple of days after the surface dressing is applied. If they don't then a call to report it as dangerous gets them moving.
Maybe we're just lucky?
The last post was made 12 years, 32 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 130.98 Kb
