| Pol Anorl |
 Pol Anorl Banned
 Posted: 11:40 - 05 Aug 2014 Post subject: front brake a bit sharp |
front brake on my fazer 600 is pretty damn sharp, its either no brakes or full brakes which hurts when my man berries kiss the tank
Any ideas why?
i have adjustable levers but they don't do a lot, plenty of pressure on the lever. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
20:30:37 Pyro.: I don't sort of like men, I take every advantage to choke on dick.
Jewlio Iglesias: You live in Liverpool - Chances are, the front door has already been kicked off the hinges |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 11:43 - 05 Aug 2014 Post subject: |
Don't pull so hard?
I heard a little bit of WD40 on the disks would work well.
Grip the tank more with your knees to stop unwanted man berries/tank interface. ____________________ My Flickr |
| Pol Anorl |
 Pol Anorl Banned
 Posted: 11:56 - 05 Aug 2014 Post subject: |
there is no too hard lol, its tiny bit of movement and nothing nothing nothing STOP! ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| Wafer_Thin_Ham |
| Pol Anorl |
 Pol Anorl Banned
 Posted: 12:02 - 05 Aug 2014 Post subject: |
the pads are decent! £24 each ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| Wafer_Thin_Ham |
| _Iain_ |
 _Iain_ Banned
| el_oso |
 el_oso World Chat Champion
| Pol Anorl |
 Pol Anorl Banned
| RhynoCZ |
 RhynoCZ Super Spammer
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 17:25 - 05 Aug 2014 Post subject: |
So you have just fitted new pads?
How far out were the pistons with the old ones in?
How shitted were they?
How much crap have you shoved back in the caliper, when you pushed piston's back in to get the new pads in?
If the pistons are shitted up having been stuck out in the elements for gawd knows how long; then get poked back in side, taking crap with them, two or three things happen;
1) pistons loath to move when you first start braking... 'stiction', bit like pre-load on suspension, means you have to put a certain force on the piston to get it to move against the disc... that then sets the 'minimum' braking force... and you get a sharp take up all or nothig feel from it.
2) Stiction will be increased, cos you have seals rubbing on crudded up 'rough' portion of the piston that was out in the elements.... If a floating caliper (dont think blue-spots are though) again, you get stiction on the float-pins, and again, lack of lube and or crud will increase how much force you have to apply before the brakes take up, and give braking.
3) Deformation of the seals, the square section sort of trapezoiding, the one face in contact with the piston dragged out with it, the parallel face staying in the groove, is all that 'returns' the piston after you relieve braking pressure. If you have dragged a load of crap into the seal rebates, then they don't have the room to flex, and the piston wont be retuned as far, reducing running clearance, again, causing a sharp take-up, also causing more 'stiction' as the piston is being pressed through the seal more to reach the pad, as seal isn't moving so far, and or, crud increases 'stiffness' of the rubber.
MOST BRAKE FAILURES OCCUR AFTER PAD CHANGES for these sorts of reasons, so personally, I would back up, revisit what you done, pop the new pads, check you haven't glazed them braking too hard on a new unbroken pad, then look at the pistons and seals, with a big bowl of soapy water and a toothbrush to clean the piston seals areas; pump pistons out, look at surfaces, and possibly, overhaul the callipers if at all 'iffy'. Possibly rough up the pad surface with coarse sand-paper if they have been glazed.
Beyond that, if brakes good... then you have either got a soft race or sports pad in there, that's not so ideal for road use; or it's your 'feel' on the controls, as others have suggested. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| temeluchus |
| RhynoCZ |
 Posted: 17:37 - 05 Aug 2014 Post subject: |
| Teflon-Mike wrote: | Beyond that, if brakes good... then you have either got a soft race or sports pad in there, that's not so ideal for road use; or it's your 'feel' on the controls, as others have suggested. |
Mike, may I ask you a question? When I had the Tokico six-pots, the brake, even when it worked, was running quite cold. Now, with the Nissin four-pots, not sure what pads are there, the front brake gets very hot and takes quite a while to cool down, it crackles as the temp goes down, a bit like a stove. The front brake is perfect, but I only wonder, could certain pads cause more heat?  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| talkToTheHat |
 talkToTheHat World Chat Champion
| G |
 G The Voice of Reason
 Posted: 23:56 - 05 Aug 2014 Post subject: |
Yamaha typically makes pretty sharp brakes.
An R6 with braided hoses would stoppy with your little finger easily if desired - only a few mm of travel to VERY hard braking.
Never found it to be a problem because I can modulate the force in my right hand .
But yes, you could always get some poorly performing pads if you have potato-hand-sydrome . |
| Pol Anorl |
 Pol Anorl Banned
 Posted: 11:32 - 07 Aug 2014 Post subject: |
Issue appears to be with the lever :S
when riding to the mot yesterday id put my fingers on and around the lever when braking and pulled the lever up aswell as in and i had progressive braking, but just pulling it in whilst the lever is in the middle its all or nothing so something may be catching. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| Kickstart |
 Kickstart The Oracle
| biggeeman |
 biggeeman Scooby Slapper
 Posted: 23:26 - 07 Aug 2014 Post subject: |
I have shite pads if u want them think weetabix make them.
It's for the Yamaha r6 fz1 r1 caliper that common one seriously u can have them full of meat sumomoto I believe they are think they stock Yamaha issue pads? You can have them for free  ____________________ lol your funny |
| Pol Anorl |
 Pol Anorl Banned
| Wafer_Thin_Ham |
| Pol Anorl |
 Pol Anorl Banned
| Wafer_Thin_Ham |
 Posted: 21:16 - 08 Aug 2014 Post subject: |
| Robby |
 Robby Dirty Old Man
| Pol Anorl |
 Pol Anorl Banned
 Posted: 15:07 - 09 Aug 2014 Post subject: |
definitely still the lever ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| _Iain_ |
 _Iain_ Banned
The last post was made 12 years, 65 days ago. Instead of replying here, would creating a new thread be more useful? |
